put WD-40 on my pitlock skewers (DOH!)
so i was putting on my new pitlock skewers but didn't have any grease. i called the lbs and they said wd-40 would be fine. i posted on the general forum and people said to grease them asap.
can i ride my bike to the lbs to get grease without doing damage?
how should i clean the wd-40 off the skewers?
should i try to clean out the hubs also? how would i do that?
thanks!
--Matt
thanks!
--Matt
rebmeM roineS
Liked 348 Times
Right. Those aren't surfaces that are normally in motion. Nothing will go wrong in the short run. In the long run, a little bit of lube (WD-40 isn't lube) will go a long way.
Mad Furyan
Bikes: 02 Cannondale Jekyll,06 Santa Cruz Heckler, 06 Specialized Roubaix Pro, 09 Santa Cruz Blur LT2
thanks!
--Matt
thanks!
--Matt
WD-40 is actually WaterDisplacer-40 - and yes, they tried 39 other formulas before they found that one. I wouldn't worry about removing the WD-40, since it doesn't "stick" well anyway. If you are super concerned about it, you could use automotive brake cleaner on a cloth - that will take it off.
LF for the accentdeprived
You're way too anal with this.
I'm pretty sure that leaving it as it is for half a year wd cause zero problem.
Riding through a whole winter w/o removing the wheel and with only one splash of WD-40 wd probably cause corrosion and seizing but even that's not certain.
I drink your MILKSHAKE
Bikes: 2003 Specialized Rockhopper FSR Comp, 1999 Specialized Hardrock Comp FS, 1971 Schwinn Varsity
They were right
Don't bother going to the bike shop to buy their overpriced grease. Go to your local hardware store and grab a tub or tube of Marine Trailer Bearing Grease (Big thread as to why here, but please don't reply to it)
Any degreaser will work. Spray onto a rag and wipe it off. Don't spray into your hubs
As long as you weren't a complete genius and sprayed the WD-40 directly into your hub bearings you should be fine. If you're talking about the hub body itself just wipe it off. If, on the other hand you were a complete chucklehead and blasted WD-40 into the bearings you now get to overhaul them because WD-40 loves to eat grease.
