Threaded to Threadless adapter?
Skidmaster General
Anyone have any experience with these? (Link) I'm thinking of getting one since there seem to be many more openface threadless stems then openface quill stems.
thanks
thanks
Bikes: Surly Cross-Check, '85 Giant road bike (unrecogizable fixed-gear conversion
You might be able to find one cheaper than $11 plus $9 shipping.
I use one and it works great. You can put threadless headset spacers on them to improve the look.
Guest
Posts: n/a
Quoted: Post(s)
same as everyone, no problems, good buy. check nashbar and performance
https://tinyurl.com/345f9a
redonkulous
Bikes: 2001 GT GTB
yup.. used one for a bit, was successful in bridging the gap between handlebars and bike.
the thing is, I feel like it has negative characteristics from both types of stems.... doesnt look as good as a quill stem, not as stiff as threadless, as heavy as both put together.. etc
Guest
Posts: n/a
Quoted: Post(s)
cab horn
Bikes: 1987 Bianchi Campione
Quoted: 42 Post(s)
Liked 28 Times
2) How is aesthetics negative from both types of stems?
3) Stiffness, yawn
Perineal Pressurized
Nitto makes a very nice one, shame it's mostly covered up when in use.
This is Africa, 1943. War spits out its violence overhead and the sandy graveyard swallows it up. Her name is King Nine, B-25, medium bomber, Twelfth Air Force. On a hot, still morning she took off from Tunisia to bomb the southern tip of Italy. An errant piece of flak tore a hole in a wing tank and, like a wounded bird, this is where she landed, not to return on this day, or any other day.
Glad i came across this thread. I almost picked up one of these earlier this week to put a cinelli alter stem on bike. I just assumed they were junk cause i'd never heard a word spoken about them.
newbie question. Do I need a threadless headset to use this? Basically I want to get a threadless stem to use with my stock threaded headset and fork.
¡Senor Member!
no, matic, this thing goes into your threaded headset so you can hook up a threadless style stem to it.
so, basically, this is what (all) you need to do what you're saying. good luck.
Bikes: windsor hour, fly bikes pantera, custom lowrider, hoffman ep flatland bike, eastern hercules.
So I have a really rad track fork I want to put on my gf bike. The thing is she is riding a 51cm frame and the fork is for a 46 cm frame.
Could I get this adapter, use a 1 inch threadless headset, no spacers and a 1 inch threadless stem?
Basically I want to use this adapter as more of a steer tube extender. Anyone see this done or done it themselves?
645f44
https://www.chainreactioncycles.com/M...x?ModelID=3970
moving target
i use a profile design adapter, have no ill feelings towards it. good luck with what ever option you choose.
70mm4$!n!
Bikes: Sworks E5, ritte Bosberg
hello
I'm pretty sure they make 1" converters as well....for 1" threadless stems.
In fact, aren't most converters designed for 1" stems and you have to use a shim if using a 1 & 1/8" stem...?
or tarckeemoon, depending
Bikes: Davidson Impulse, Merckx Titanium AX, Bruce Gordon Rock & Road, Cross Check custom build, On-One Il Pomino, Shawver Cycles cross, Zion 737, Mercian Vincitore, Brompton S1L, Charge Juicer
...or get a Salsa SUL quill stem
moving target
you know i have always wanted to say that, but yes alot of the adapters are 1 inch and come with a shim. check nashbars site for an example. i have a 1 inch stem adapter with a 1-1/8 stem with a shim tucked in there. all together it bolted up tighter than a virgin on prom night
All around nice guy
Bikes: THE KIND WITH TWO WHEELS AND ONE GEAR
Converter=adapter, I have used a 1" to 1" adapter with a Cinelli Alter and it was fresher than a virgin in a fridgerator(that ones for you court)
