Really wide drop bars?
Bikes: '08 Surly Cross-Check, 2011 Redline Conquest Pro, 2012 Spesh FSR Comp EVO, 2015 Trek Domane 6.2 disc
Liked 8 Times
After much flip-flopping about what my next bike would be, I've finally decided to build a commuter/rando bike around the Surly LHT frame. Currently I'm riding a street converted MTB for my commuter and the flat bars are pretty wide (23" end-to-end). I'm really comfortable on this setup because my arms are straight from my shoulders when I'm on my bar-ends. The problem comes when looking for really wide drop bars for a road bike: Nobody makes a bar that wide. I've seen the Nitto Noodle up to a 48cm, but that's been the top width I can find. The usual "big" 44 and 45cm bars just don't cut it for me.
Does anyone make a 50cm drop bar for us Sasquatch sized riders?
"I feel like my world was classier before I found cyclocross."
- Mandi M.
- Mandi M.
Bikes: 2010 Surly LHT (main rider and do-everything bike), 2011 Bike Friday NWT (back-up bike and multi-modal)
Would a flared-out "mountain bike-style" drop like the On-One Midge bars work?
Liked 8 Times
They look good for the width on the drop portion, but the 37.5cm "top" sounds a little limiting.
What I did see on the On-One page is a better description of the geometry on the Nitto Noodle bars, and I think that a 48cm might work with those. They have a similar top to the Nitto Rando, and that's really the comfort position I'm looking for; riding on the hoods or tops. The drops are nice for pulling up long seated hills, but I don't spend tons of time there.
- Mandi M.
- Mandi M.
Holy crap! ... you want a FIFTY?...good luck, dude! Nitto Noodles come in 48's and I have several pair....they are heat treated because of the leverage a big dude could put on 'em....they are nice and wide, though and fit a larger framed bike/rider very well....
I own my dream bike, a 2023 DirtySixer MkII 3xl
...and also a 2006 R-14 66cm Waterford road bike, my former dream bike :)
.....I can't believe I used the word "dude" twice in above post...
POWERCRANK addict
google threw up
48cm nitto noodle
48cm soma fabrications major taylor track bar
48cm soma fabrications 456 track bar
48cm nitto noodle
shameless POWERCRANK plug
Recommended reading for all cyclists - Cyclecraft - Effective Cycling
Condor Cycles - quite possibly the best bike shop in London
Don't run red lights, wear a helmet, use hand signals, get some cycle lights(front and rear) and, FFS, don't run red lights!
Out fishing with Annie on his lap, a cigar in one hand and a ginger ale in the other, watching the sunset.
Bikes: Techna Wheelchair and a Sun EZ 3 Recumbent Trike
Liked 24 Times
I think if you want 50CM, you are going to have to go custom. That'll be HUGE $$! Try a 48, you might well find it works well.
. “He who fights with monsters might take care lest he thereby become a monster. And if you gaze for long into an abyss, the abyss gazes also into you.”- Fredrick Nietzsche
"We can judge the heart of a man by his treatment of animals." - Immanuel Kant
Liked 24 Times
This is the widest off the shelf bar I could find....at Harris
HB105 46 cm & HB106 48 cm $44.95 buy button (Wider sizes heat treated for extra strength)
Very nicely finished, made in Japan drop bars with Italian size 26 mm centers.
No flats, bumps nor grooves. The special characteristic of the Noodle Bar is that the tops have a backward sweep that puts the corners about 1 cm farther back than a standard traditional "Mæs" bend
Silver, 4° flare out, flat hand perch, and the top curves back a bit The width of this bar does not include the flare outs of the ends of the bar.
Reach is 96 mm, Drop is 140 mm. Available in 42 cm, 44 cm for $44.95.
Also available in extra wide 46 or 48 cm widths for $64.95
The wider sizes are more expensive because they're heat treated for extra strength.
https://sheldonbrown.com/harris/handl...handlebarsdrop
Liked 8 Times
Sometimes it's tough being Sasquatch.
- Mandi M.
- Mandi M.
www.markreynoldsfund.org
Bikes: 1993 Titanium Miyata Elevation 8000, Scattante XRL
I would say try the on-one midge bar. It has the most comfortable position on the hoods I have ever had. Love them.
Mudu93
Please donate to the Mark Reynolds Memorial First Bike Fund at www.markreynoldsfund.org
Mudu93
Bikes: Lemond Chambery/Cannondale R-900/Trek 8000 MTB/Burley Duet tandem
Hmmmm, my mtb bars are 23 across, my shoulders are 23 across, but my roadie bars are 18.5 center to center and 19.5 outside to outside. Both are very comfortable.
What is the conversion for myh bars to cm, anybody?
Liked 24 Times
48 cm=18.89" center-center
Salsa Bell Lap come in 48, and have additional flare outwards on the drops. So, they're even wider. The drop portion is also shallow, and the 'hoods' portion is nice and flat, so they're really, really comfy.
I have shoulders that are so broad that people accuse me of having implants. At club rides, quite often people say 'man, you're fun to draft'. Those Bell Laps are wide enough for me, so they should be for you too.
Bikes: Steel geared. Steel Fix.
I have 48's and find them very comfortable. I'm sure the OP would be okay on 50's if he could find them... Its just the finding them... Get them custom bent at an engineering shop, while you're there get 100 of the b*ggers done and sell them on ebay. I'm sure you'd make a fortune
Oh Thanx! I was using .254 but not getting the correct number
Wow. 48 Hunh? They came stock on my Lemond Tourmalet 57 cm. They are much wider than the bars that came on my 58 Cannondale.
Felt awkward at first but VERY Comfy, especially while standing!
I think that Nito Dirt Drops have a width of about 52 at the ends. I believe that they were discontinued by Nito. You may have to get used or new old stock. I think that the Dirt Drop ends flair out a bit. I have several Nito 48 cm Noodles and I love them.
1971 Raleigh International,1973 World Voyager, Mike Melton tourer, 1970's Gitane Tour de France, 1983 720 Trek, 1985 Paramount, 1990 Paramount, 1995 Merlin Road, Heron Road, Rivendell Atlantis
Bikes: 2001 Giant OCR w/105-10spd, Schwinn High-Plains Built for Commute plus 3 Others in Various Stages of Rebuild/Repair
but the only way your likely to find them is on a complete bridgestone MB-1... one sold on ebay the other day for about a grand...
In response to some of the more reasonable postings above, I really like the 44cm noodles that i have. That little swing back from the stem is really comfortable. My only gripe is that i would have like to use my clip on aerobars on the bike I had them on originally but because of the stem sleeve the set I have wouldn't fit. But that's a pretty minor gripe.
Liked 24 Times
Dang, I make mention of the On-One Midge bars in the very first response to CliftonGK1, and there's like 3-4 more responses later on down the thread
Oh, and I like the Salsa Moto Ace Bell Lap bar, too. Real nice feel on the Surly Cross-Check COMPLETE that I test rode, and if I had the money to get a custom built Cross-Check, I'd keep that bar.
