Wheel shifted in fork
Hello,
I had a blow out yesterday and I replaced the tube and tire. After putting the wheel back on, I noticed the entire wheel is sitting a bit off in the fork. It's too far to the right while sitting on the bike.
Does anybody have any idea what might be wrong?
I should mention I did mess with the stem nut trying to adjust the handlebars.
thanks for the help.
Bikes: '07 Pista, '09 Fantom Cross Uno, '8? Miyata, '67 Stingray, '0? Zoo mod trials, Tallbike, Chopper, '73 Schwinn Collegiate, '67 Triumph Chopper, '69 CB350, '58 BSA Spitfire, '73 CB450
Just loosen up your quick release or axle nuts, adjust and tighten back up.
I suspect you've both bent the wheel and your handlebars have twisted with respect to the fork. The wheel should be trued and the handlebars re-aligned. The second can often be done simply by holding the front wheel between your legs while you give the bars a good twist, but it is better to loosen your stem first and re-tighten after adjustment. For quill stems, it's just a matter of loosening the expander bolt and retightening after adjustment, but for a clamp-type stem on a threadless fork, you have to loosen the clamp screws, adjust, preload the top bolt to remove the play from the bearings, and re-tighten the clamp screws.
- Mark
Just to follow up. The entire wheel is shifted to the right. If I look at the bike from the front, the tire is straight up and down, but shifted 1 inch to the left of the handlebars.
If it were out of true, wouldn't just part of it, be shifted?
Liked 8 Times
Always have the wheel on the ground with the full weight of the bicycle on the axle before tightening the quick-release or axle nuts.
Confirm that the rim is equal distant from both fork legs.
Standing over the bike frame turn the wheel so that the tire and rim are centered under the frame's down tube.
With the wheel centered on the frame if the handlebar and stem are not centered over the wheel you need to rotate the handlebar relative to the wheel. If the fork and stem are of the threaded type you can probably just use a bit of force to re-align the stem. If the fork and stem are threadless you will need to loosen the stem pinch bolts slightly, re-set the stem compression cap pre-load, and re-torque the stem pinch bolts. Instructions can be found at https://www.parktool.com.
Al
Al
Can you take a picture and upload it?
Smiling and Waving
Bikes: -
How does the bike ride no-hands?The forks might be bent.Also sounds like your handlebars are a bit crooked.That's an easy adjustment to remedy.
You can try loosing the nut on the wheel(opposite the side thats rubbing the brake).Eyeball the wheel straight and tighten it back up.
Sorry, but these pictures are just too dark and distant to tell much of anything.
Your bars appear definitely "tweaked" (easily fixed as others have said), but I would guess you've either got a bent wheel or bent fork also. How the wheels sits in the fork - whether offset laterally or tilted with respect to fork plane - is what you need to determine if it is fork, wheel, or both. Reversing the wheel in the fork will tell you a lot - if nothing changes, then it's the fork, but if the error shifts to the other side, that indicates wheel.
I'd bet your LBS could diagnose it in a matter of seconds.
- Mark
- Mark
Check your quick release spring. If you removed it when you did the flat repair, it may have been put on backwards, causing it to wrap around the axle and skew the wheel. The small end of the spring goes in toward the axle.
cat person
Bikes: Nashbar Race SIS (1987), Kestrel Talon (2007), Trek Fuel EX 9.5 (2007)
Smiling and Waving
Bikes: -
If the fork was bent it wouldn't have changed when you flipped the wheel.
It's not the axle.It would have been closer to the left fork(the exact opposite),not closer to the right after reversing it.
Are you sure the axle is seating properly in the fork drop outs?
BTW the wheel in the example picure(with the CF GIRVIN forks) is definately crooked in the forks.You can see that it is visually closer to the right fork.Is yours crooked in the forks like that?Physically measure it with a ruler.
2 B Frank w/U
Bikes: 1963,1965,1968 and 1971 Raleigh Sports
Wordbiker wrote-
thebikeguy wrote-
+1 on both of those replies.There's something wonky going on there.
Because I know you were all dying to know... I put my wheel on another bike, and it was straight as an arrrow. So, it would appear as most of you suggested, the fork of my original bike was bent.
Thanks for all your help.
