Running separate wheelsets
Old 04-15-08, 11:12 AM
xfimpg
xfimpg's Avatar
Bikes: RichardZEP
Quoted: 21 Post(s)
Hi Everyone,
If you're running separate wheelsets and the cassettes are of different gearing - 11/25 and 11/32 - what are the chances you'll need to adjust your derailleur everytime you swap wheelsets?
Using an 8-speed triple.
Thanks
Mike
xfimpg is offline
Old 04-15-08, 11:26 AM
urbanknight
Over the hill
urbanknight's Avatar
Quoted: 1016 Post(s)
Liked 1,246 Times in 710 Posts
If your chain length and rear derailleur is set up to handle the 32, you shouldn't have any problems.
urbanknight is offline
Old 04-15-08, 11:42 AM
mike_khad1
Commuter Animal
mike_khad1's Avatar
Bikes: 2006 Burley Hudson, 2008 Specialized Globe
Seems to me your chain will be too long when you have the 11/25 wheelset on.
mike_khad1 is offline
Old 04-15-08, 01:41 PM
Bill Kapaun
Really Old Senior Member
Bill Kapaun's Avatar
Bikes: 87 RockHopper,2008 Specialized Globe. Both upgraded to 9 speeds. 2019 Giant Explore E+3
Quoted: 1820 Post(s)
Liked 1,309 Times in 902 Posts
You did say "TRIPLE", so there shouldn't be any problem if you are set up for the 11-32 and it currently works correctly. Chain length wouldn't be any different than if you were taking off in 3rd gear (or so).
Any adjustment required would be because the cassettes weren't centered the same from the DS locknut.
Thin shims/spacers could adjust that dimension if needed.
Bill Kapaun is offline
Old 04-15-08, 02:07 PM
well biked
well biked's Avatar
Quoted: 143 Post(s)
Liked 164 Times in 90 Posts
Another thing to think about is rim width, if you're using different model rims. If they're not the same width, you'd likely need to adjust the brakes every time you switch wheels-
well biked is offline
Old 04-15-08, 04:00 PM
Retro Grouch
Retro Grouch's Avatar
Quoted: 1572 Post(s)
Liked 644 Times in 365 Posts
Nope. The little/little gear combination doesn't change so, if the chain wasn't too long with one it won't be too long with the other.
Retro Grouch is offline
Old 04-18-08, 08:33 AM
mike_khad1
Commuter Animal
mike_khad1's Avatar
You're right - my bad
Old 04-18-08, 10:08 AM
xfimpg
xfimpg's Avatar
Bikes: RichardZEP
Quoted: 21 Post(s)
np
xfimpg is offline
