View Poll Results: Too much slack in timing chain?
Yes
33
97.06%
No
1
2.94%
Voters: 34. You may not vote on this poll
well hello there
Quoted: 503 Post(s)
Liked 339 Times
Is there too much slack in this timing chain?
And if so, does it need adjustment or replacement?
It's a couple years old and never adjusted, but always well cared for.
hors category
Quoted: 8 Post(s)
Liked 5 Times
It probably just needs to be adjusted via the eccentric. A close up of the timing ring teeth to the right of the crank arm (power stroke) would make it easier to tell just how worn the chain may be.
However, you can check chain wear the same way you would on your drive chain by using a ruler or chain checker. If the pin-to-pin distance over 12 links is more than 1/8" of inch past the 12" mark or beyond 75% worn on the chain checker, the chain should be replaced... unless you've decided to run the chain and chain rings until they're toast (10k or more), and then replace the whole shebang.
well hello there
Quoted: 503 Post(s)
Liked 339 Times
hors category
Quoted: 8 Post(s)
Liked 5 Times
The portions of the timing rings you've photographed don't look bad at all. However, I'd still go ahead and check the sync chain for wear with a ruler or chain checker. While you're at it, and based on what I'm seeing on your chain rings in the background, you might want to check the wear on your drive-side chain too.
Bikes: Giant TCR, Santana Team Scandium, Co-Motion Equator, Giant NRS Carbon
I've noticed some of the chain checkers seem to not be so accurate. Usually it's the one's with moving parts. I've seen many that would say a chain was half worn out when it was new. The ones that are just a plate of metal that slide in between the links (one piece) seem to be more accurate to me. I prefer using either one of these or the ruler method.
Two at a time is more fun
Bikes: 2006 Burley Tosa
I replaced the timing chain on our tandem recently and found that about half of it had exceeded the wear indicator and the other half hadn't. I determined that it was beneficial to check the chain in numerous points along its' length.
Out of all the things I've lost, I miss my mind the most.
well hello there
Quoted: 503 Post(s)
Liked 339 Times
Thanks for the responses.
And I notice that 24 of you think there is too much slack in the timing chain and only ONE of you thinks there is NOT too much slack. Let's here from our loan ranger!
Bikes: 2016 Salsa Warbird Carbon, 2014 Felt Edict 9, 2008 Cannondale Road Tandem
Bikes: Cannondale RT1000; Santana Ti 700; Co-Motion Speedster, Co-Motion Cappuccino
I would think a timing chain as loose os yours would be in danger of jumping off, especially when riding at a higher cadence or hitting a bump. Has anyone had this happen?
Quoted: 77 Post(s)
Liked 19 Times
D-r-o-o-p-y chain. Agree on adjusting eccentric a bit.
Looks loose enough to jump off in case of hitting a big bump or loading/unloading inside a vehicle.
Time for a change.
Liked 5 Times
Once you find out how to adjust the Timing chain- You may find that you have a slack point and a tight spot in the chain. This can be adjusted out by setting the Timing chainrings to take it out- but providing no bent Bottom bracket crank or anything else bent- The easy cure is to change the chainrings to some better quality ones that run true and in a perfect circle. When I got the Tandem- I had the tight/slack in the chain and it took a lot of time to correct. Then on changing the timing chain- I replaced the rings with Middleburn rings and perfect from the time of fitting them. I Cannot visibly see or feel any variation in the chain tautness- even three years after putting the quality chain rings on.
Spike Milligan
Spike Milligan
hors category
Quoted: 8 Post(s)
Liked 5 Times
https://www.middleburn.co.uk/
MTBTandems.com just up the road from us is one of two US distributors. Having fondled the hardware extensively, I can confirm the quality, fit, and finish is top flight. Last time I checked they were still more dialed in to the off-road crowd, more so than the road bike community. Definitely one of better choices for an off-road tandem that needs a cross-over crankset.
hors category
Quoted: 8 Post(s)
Liked 5 Times
Send an email to alex@mtbtandems.com
He can give you the latest on what they're offering that might work for road tandems. Again, they're primarily an off-road component supplier.
