shamal rim cracked, question!
so as u can see, theres very lil tiny crack spot on my 1994 shamal rim.
the tension feels the same as before. i put superglue on them.
do u think its still rideable??
Nobody in their right mind will say this is 100% safe to ride. There is no way of telling what damage has been done to the rim, especially from a picture and the risk is too great.
My advice - new contemporary wall hanging named "my lucky escape".
Liked 1,102 Times
The picture isn't real difinitive but it looks like the crack is in the nipple, not in the rim wall itself. Is this correct? Is the "nipple" I see in the picture a separate item or part of the rim?
Superglue won't help. However, if you're really anxious to keep that rim, I wonder if a metal shop that does aluminum welding would be able to put in a spot of whatever to shore it up some.
You can simulate what would happen if it broke through by completely untensioning the spoke but that might cause other problems.
cdr
(Grouchy)
the nipple on this wheel normally resides inside the rim and has started to pull through, causing the outer rim wall to crack. eventually it will pull all the way through if the wheel continues to be ridden.
