front deraileur touching crank arm grr
Bikes: 2010 Specialized Allez Steel| IRO Mark V fixed gear
I noticed today that my front deraileur is touching my crank arm every revolution when i pedal. This only happens when my compact crank is on the biggest cog. can i adjust this? or should i take it back to the lbs? (trek 2.1 is only 2 weeks old).
I don't have a compact-anything and my legs already rubs the fat water bottle. Hope the "compactness" is really worth it.
Simple, bring the FD cage "in" a quarter turn of the adjusting screw at a time until no rub and chain still shifts OK.
Bikes: Bianchi, Miyata, Dahon, Rossin
Liked 5 Times
https://www.bikeforums.net/showpost.p...93&postcount=7
the DIY method,
or since 2 weeks should be covered by a "free tune up" from the LBS, go get it checked by them.
the DIY method,
Food for thought: if you aren't dead by 2050, you and your entire family will be within a few years from starvation. Now that is a cruel gift to leave for your offspring. ;)
https://sanfrancisco.ibtimes.com/arti...ger-photos.htm
Super Moderator
Quoted: 1174 Post(s)
Liked 935 Times
Good ! That's the first step to being your own mechanic which is the way to go.
Have bike. Will travel.
Bikes: '06 Orbea Orca, '03 Rocky Mountain Vertex 70, '05 Surly Steamroller, '06 Fetish Fixation
