700 x 25 tube in a 700 x 23 tire
I was in a pinch and all I had was a 700 x 25 tube, my tire size is 700 x 23, is this bad? doesn't seem ideal but doesn't seem to far off
Liked 644 Times
You're exactly right: not ideal but not too far off. As long as you didn't pinch the inner tube under the tire bead you'll be fine.
Given my choice I'd prefer to use a slightly undersized inner tube than a slightly oversized one.
cab horn
Bikes: 1987 Bianchi Campione
Liked 29 Times
Numbers only get you so far, it's what happens when you put the tube into your specific tire that counts.
Bikes: Specialized Allez (2007); Fuji Finest (2002); Trek 1100 (1994); Giant Iguana
Its probably a tad thicker after being inflated inside the tire. You may find it more durable! I ran 28's inside 25 tires and got a pretty good life out of the tube.
Bikes: Iron Monkey: a junkyard steel 26" slick-tired city bike. Grey Fox: A Trek 7x00 frame, painted, with everything built, from spokes up. Jet Jaguar: A 92 Cannondale R900 frame, powder coated matte black with red and aluminum highlights.
It's probably going to catch fire and explode.
Space Dust
Bikes: Old DF
It seems that the general consensus is clear but I might as well add my two cents for statistics' sake. I agree you should be absolutely fine with a 25 tube inside of a 23 tire, as long as you follow basic tire replacing methods (even bead along rim, no pinched tube between tire + rim, etc.).
Bikes: 1983 Dawes Galaxy, 2006 Raleigh Airlite, 1982 Sun Solo (fixed)
I always end up buying something like 700x20-28c anyway, and always seems to be fine
A group for all Dawes Galaxy owners to give and recieve information about them
https://flickr.com/groups/dawes_galaxy/
i jam my thumbs up and back into the tubes. this way i can point my fingers straight out in front to split the wind and attain an even more aero profile, and the usual fixed gear - zen - connectedness feeling through the drivetrain is multiplied ten fold because my thumbs become one with the tubing.
back in the saddle
Bikes: Raleigh Olympian, Trek 400, 500, 1500, 6700, Madone 6.9, Sekai 2400, Schwinn Passage, KOM, Super Letour, Nishiki Sport, Vision R45, Bike E, Volae Team
I'm always surprised by how uptight everyone gets ove tubes. Blow one up out of the tire and you realize how much they can expand and 'adapt'. I have 26X1.75 thornproof tubes in my 700x37 tires on my bad weather commuter and they have been bulletproof for over 2 years. If it can be stuffed or stetched in w/o pinching it will be fine.
Space Dust
Bikes: Old DF
![Big Grin](images/smilies/biggrin.gif)
Liked 83 Times
On my hybrid I changed from 700x38c to 700x25c tires. In so doing, I managed to rip the stem off the new 25mm tube for the rear tire. And through poor planning I didn't have another one on hand. I managed to cram the old 38mm tube into the 25mm rear tire, and it's still there today (months later).
It was a monumental task getting the Armadillo with wire bead onto the rim with such a big tube inside, but it finally worked out. Next, I expected to flat out in no time, or maybe blow the tire off the rim. But no, it worked out fine. I'm sure it's less than ideal toting around the extra weight, and if I ever had to change a flat again I would just substitute in a new appropriately sized tube, but for now it's ok.
