Question for riders w/ 04 Mavic Ksyrium SSC SL
Hopefully someone can help me w/ this very annoying problem that is happening to the front wheel of this wheelset. For some background I bought this set about 3 weeks ago. Everything was perfectly fine for about 2 rides then the problem started. The front wheel started to creak and make a ton of noise when I was hammering uphill in the drops or on the hoods or sprinting on flat terrain. I took it to my regular shop for inspection in which they tightened the hub and shot some Tri-Flow where the spokes meet the hub. The problem was sloved for about 2 hours then it started all over again. Today I took the wheel to the shop where I bought them and they said they would inspect and call Mavic to get their advice in which I should have the wheel back tomorrow. Has this happened to anyone w/ this set and if so how was it fixed? It is very annoying to the point where it is an embarassment to ride. Thanks for the help!
I'm 148 lbs of legs and lungs.
"The bicycle has a soul. If you are able to love it as it deserves, it will give you emotions you will never forget." -Mario Cipollini
No kidding? I guess I will if the problem is not fixed when I get the wheel back. Thanks alot!
