OK... S-Works Owners?
Texas Fight!
So I'm looking really seriously at getting an '08 S-Works Tarmac SL, like tomorrow. I've heard bad things about the S-Works crankset, though. Since you can't really swap it out for anything (or if you can, the options are limited to that and the Cannondale cranks AFAIK), how good/bad are they?
Are they any better with different chainrings?
Thanks!
Thanks!
CPM M4
Bikes: Light.
Thanks!
Thanks!
Ten tenths.
Ten tenths.
CPM M4
Bikes: Light.
Action Potential
Bikes: Specialized Ruby S-works 2008, Specialized Safire FSR Expert 2008
My S-works Ruby (WSD Roubaix) threw its chain non stop.
FSA chainrings (courtesy of my LBS) fixed the problem.
It's VERY easy to use a different crankset. I'm doing it myself on an 07 SL. Just have your shop call up Specialized (they don't have it on thier dealer website) and ask them to send out a bb30 adaptor. It's just a little sleeve that you put into the frame. You don't even have to press it in... it just slips in there. Then you can run whatever crank you want. Just be aware, it is Italian threaded (they first made them for Quickstep, who runs Campy of course).
Another option would be to run the SRAM red BB30 crankset, which is out now. Or you can wait a couple months and there will be a handful of FSA cranks out in BB30 as well.
BTW, if you get a specialied crankset that has 175mm arms and want to get rid of it... PM me. I had a 172.5 and always run 175mm cranks.... that's why I ditched mine.
Get on a cross bike.... you'll like it ;)
Thanks!
Thanks!
Bikes: 03 Lemond, 08 S-works Tarmac SL
I have a campy record on mine with no issues. If you buy the module there may be an issue but I don't know?
Module is BB30. So if you don't want to use a BB30 crankset you have to get teh adaptor from specialized. It costs like $12. Then you can put whatever you want on it.
Unless Boonen's bike has some custom BB construction, it can be done.
https://www.roadcyclinguk.com/news/article/mps/uan/2895
Bikes: Specialized Allez Elite, BMC SLC01
The crank is fine but the chain rings are rubbish. The problem will be solved if you switch out the chain rings for other ones.
Bikes: Specialized Tarmac SL2, Specialized Tarmac SL, Giant TCR Composite, Specialized StumpJumper Expert HT
Thanks!
Thanks!
CPM M4
Bikes: Light.
Ten tenths.
Ten tenths.
Bikes: Too many
I think Campy has BB30 adapter cups for UT in 2009. On their website there is some sort of cryptic reference to a part number for cups meant for "oversized bottom brackets."
Texas Fight!
Matt... It comes in 2 versions. Boonen's bike has the standard (Italian or English) BB cups. The module (or complete bike, as I'm probably buying) has a completely different BB.
Anyways, now that I know I can either swap chainrings or put on a SRAM Red crank, I'm going for it.
