Scratched seatstays no more
I've devised a simple measure in response to Toronto's cast steel post+ring bike posts: Cotton twine wrapped around my right seatstay, then soaked with anti-corrosion spray. If this ever becomes the latest hipster trend, I take credit for coming up with it.
what or why is your seat stay getting scrated? if you wanted a cheap and easy way to protect your frame use a punctured spare tube and wrap it around, alot less time consuming and will hold up to the elements.
also if your gonna make your bike look so ugly alteast use reflective tape,
apocryphal sobriquet
I kind of like the look. +1 on the shellac though. Be careful the twine doesn't unwind into the rear wheel. I can envision a scenario where the twine gets tangled up in the cog causing the chain to jump off :-(
Bikes: Waterford RST-22, Bob Jackson World Tour, Ritchey Breakaway Cross, Soma Saga, De Bernardi SL, Specialized Sequoia
Liked 6 Times
I would be concerned about the string absorbing moisture and leading to rust.
Bikes: 05 Trek 5200, 07 Trek 520, 99 GT Karakoram, 08 Surly 1X1
Bike posts are a challenge. I've used old tubes and zip ties.
I would be a little concerned that your twine would eventually unravel.
my legs are carbon
A totally unrelated post, but how are the regular length presta valves with the deep V rims? still manageable?
Unwinding: Impossible from either end of the twine; Possible if abrasion caused a break somewhere in the middle.
Rust: The seatstay had some scratches, but not down to metal.
Hates the MTA!
Bikes: Vintage Nishiki road hybrid
I don't see the problem with scratches though. Just means that there is less chance of having the bike stolen.
Didn't make it
Metal tubes I don't want scratched I use pipe insulation sleeves.
Foam or closed cell foam at the hardware store.
The soft type can be carried in a bag.
Never tried it on a bike before.
