Bottom Bracket Spindle Length
Bikes: Late 80s Japanese Bianchi
i have a cup and cone bottom bracket and i want to switch to sealed bearing on my geared road bike...i'm not sure of my current spindle length but it works fine with my Shimano Sante cranks...but i was wondering, is it bad to have a spindle length that's too long? what are the downsides? from what i can tell, i should be using anywhere between 109-112mm with Sante...but would it be bad if i used 113 or 115?
Bikes: Trek 1000, two mtbs and working on a fixie for commuting.
There will be premature wear on your drivetrain when you are using the big cogs.
Quoted: 1572 Post(s)
Liked 644 Times
What are you using for a shifter?
Your less-than-ideal chain line may rub a bit more in some gear combinations. Assuming you are using a friction front shifter you should be able to trim out the rub.
good to know...i also rarely use larger cogs, but it's always a possibility i suppose. i'm using indexed, Shimano SIS, used to be paired with a Light Action derailer. i was contemplating switching to friction mode for a while though.
since i don't know the precise spindle length i should use for Sante cranks (and can't find it anywhere, at least not in my searches around here and the interwebs), what general guidelines can i use? i can measure my current spindle length and see what my current clearances are and what not.
