Tire Liners - Must have for the commuter?
How many of you use tire liners? I do and I haven't had a flat for about 2 years. The last time I had a flat it was because of a thorn that went though the side of the tire.
I put a pair of Mr. Tuffy on all my bikes and it believe it is very important especially if your bike is a commuter. These tire liners are cheap and can last for 15-20 years as some people keep on changing them from bike to bike.
Many say that they slow the bike down a bit though I haven't really noticed this nor do I understand why since they practically weight nothing but then again I ride a hybrid/commuter that is always loaded with stuff.
Bikes: Bruce Gordon BLT, Cannondale parts bike, Ecodyne recumbent trike, Counterpoint Opus 2, miyata 1000
I tried tire liners for a while. Then I just started getting a better grade of tire.
cowboy, steel horse, etc
Bikes: everywhere
Quoted: 12899 Post(s)
Liked 7,824 Times
I can't live without tire liners. I ride on some nasty streets. I once tried some Armadillos, but got a couple of flats and eventually gashed 'em well before the tread wore out.
I do have a set of sewups for pleasure rides. I have to remind myself to avoid glass...
I go over the Sepulveda Pass which runs over the Santa Monica Mountains- it is total wilderness between suburbs of Los Angeles- and the road is horrible. Glass, rocks, sheet metal. Grrrrr.
I spent $30 on gators.... flat within a month. I need to get to work- not fix a flat everyday. So I called Scwalbe because their website didn't have much for 23/700 (I know- part of the problem). The guy said they have a new 23 size tire I would like- but they are $75. I have had it for a month and no problems so far.
This is the one for the 25:
https://www.everybicycletire.com/shop...dd-folding-622
You gonna eat that?
I use them on some bikes, not on others.
I'm not touching the wheels or tires on my '66 Raleigh 3-speed. One tire is still original I think. I've run it through all kinds of stuff and not flat yet, knock wood.
Fairweather Bike Commuter
Bikes: 2008 Jamis Satellite
I bought a pair for my bike (a Jamis Satellite). I only got around to putting one in the rear wheel. I didn't notice any increased rolling resistance. I strippid the threads on a pedal arm and had to bring it into the shop. Lo and behold the guy there noticed the tire had to be replaced, also. The little slice probably occurred before I put the tire liner in, however. I didn't ask if the tire liner was re-installed, I was just happy to get my bike out of drydock. Performance Bike was offering a buy one item get one 10% off, so I bought a pair of 700x23 Gatorskin tires. They're in my room waiting to be put on!
Bikes: Avanti ventura, Fuga Track Bike
isnt it considered bad luck to talk about flats?
oh dear.. now i just jynx'd myself
JRA.
Bikes: '07 IRO Mark V, '01 Cannondale Jekyll 3000, '07 Rivendell Atlantis
I've found tire liners to be way more of a pain than they're worth. Granted I'm sure they've changed/improved the design since but I even saw a tire liner wear through a tube once causing a flat...
Personally I'll go for a high quality tire. I've had great luck with armadillos. Not so great luck with Gatorskins. And pretty good luck with Panaracer Pasela Tourguards. I've been riding Schwalbe Marathon winters since about mid-december and haven't had any issues there either.
I haven't had a flat in a few years... *knocks on wood* most of that riding done at 28c Armadillos.
2009 Bike Friday Season Tikit (commuting folder)
2007 Rivendell Atlantis (touring, general riding, errand runner, stuff hauler)
2007 IRO Mark V (SS)
2006 Rockhopper Comp Disc (Icebike)
multimodal commuter
Quoted: 1908 Post(s)
Liked 574 Times
I go for high quality tires and tire liners. I mean, what the heck. I hate flat tires. I had about ten or twelve flats in 2008, but none since November or so.
Señior Member
Bikes: Windsor Fens, Giant Seek 0 (2014, Alfine 8 + discs)
Quoted: 446 Post(s)
Liked 8 Times
I use the cheapest tires I can buy with no liners and flat no more than once a year or so. it totally depends on your conditions. There are almost no road hazards on my route. For the last 2 years the only flats I've had have been my fault (screwed up the tire or tube mounting it, or used a bad rim strip), not due to road hazard punctures.
Work: the 8 hours that separates bike rides.
Freewheelin' Fred
Bikes: Surly Cross Check
So far I've found that my 'dillos and my Hard Case Lites are good enough. But that's only after 3 months (about 700 miles).
My commute is almost all city/suburban streets, but there's occasionally some nasty stuff in the bike lanes.
aka: Mike J.
When I used to live in SoCal I ran the thicker "thorn proof" tubes. And I don't mean those flatless solid foam style tubes, I mean the ones that are just made out of thicker rubber.
I've used tire liners before and learned to not like them. They're a hassle to change a flat with, they tend to slide around to the sides after awhile, and assorted other stuff I've seen while changing tires and tubes that people being in to the shop I seasonally help out at.
Good tires, good tubes, both help a lot.
It really comes down to your personal commute route and how you ride. If tire liners work for you then more power to ya. The only way to really know if to give them a try.
edit to add: https://www.sheldonbrown.com/flats.html
Talks about the thorn proof tubes and also some about tire liners.
Hypocritical Cyclist
Bikes: 07 Surly Steamroller, 1984 Ross 290s
I've used them, they help especially when commuting on skinny tires. It still better to have a good quality tire though, especially one w/ a good sidewall.
On another note I rode home due to Mr. Tuffy's once. I dropped my chain and burned a hole in my rear tire, and rode about 10 miles home on the liner and a tube patch!!
I don't like liners myself. I use thorn resist tubes (thicker rubber) and Marathon Plus tires.
Real Men Ride Ordinaries
Quoted: 17 Post(s)
Not essential in the slightest. Convenient though. Then again, my record for changing a flat on the road was just under two minutes (and with a frame pump no less), so while it is a hassle, it won't stop me from getting to work.
bikes are sexy
Bikes: [2008 specialized allez tripple], [2006 Specialized hardrock sport], [1998 Robinson Rebel], [1980's vintage schwinn ministing], [2008 specialized epic comp] - [2009 origin8 scout 29er], [2005 KHS DJ200]
for what its worth, the first day i had slime self sealing tire liners i got a flat. i just buy good tires and line my tubes with old tubes cut down the center.
I believe that properly installed tire liners are a life saver. The only problem (though I myself have not experienced this) is rolling resistance. I wonder how though since tire liners weight only a few ounces. It would just like haveing a slightly thicker tire, no?
Bikes: Trek Portland/Gary Fisher Hoo Koo E Koo/LeMond Versailles
I use them all the time in both the road bike and the mountain bike. In this area we have too many goat heads and it doesn't matter what kind of tire you use, the tube needs some armor or it is going to get a hole in it.
nashcommguy
Bikes: Commuters: Fuji Delray road, Fuji Discovery mtb...Touring: Softride Traveler...Road: C-dale SR300
The SMPs have more 'rolling resistance' than a comparable regular thickness tire, but as I was running airless it seemed to me like I'd been set free. Can't imagine that tire liners would contribute to rolling resistance as they're on the inside and don't affect the tire/road contact point. Would think that has more to do w/psi and tire width.
I've always wanted to try airless tires but I have heard so many bad things about them such as how they feel really mushy and how they are hell to put on even for the LBS. losing 3 mph seem to be quite a lot even for an under 10mi ride and especially for moderate paced riders like me who probably average around 13 or 14mph.
nashcommguy
But, this was around the time I gave the SMPs a try and have never looked back. My pacing is 15-18mph, but w/t airless it was more like 13-15mph. My commute took 10-15 mins longer w/t airless(I've got a hilly commute), but feel that I'm a stronger rider now as a result of 'fighting' those tires for that time period. And was 'flat-free' for 3 years.
kipuka explorer
Bikes: 1994 Trek 820, 2004 Fuji Absolute, 2005 Jamis Nova, 1977 Schwinn Scrambler 36/36
Never tried tire liners, since I only average about 1 flat per year. Low mileage and Continental 4-seasons. As always YMMV
-=- '05 Jamis Nova -=- '04 Fuji Absolute -=- '94 Trek 820 -=- '77 Schwinn Scrambler 36/36 -=-
Friends don't let friends use brifters.
Bikes: 2008 Dawes Haymaker 20XX Leader LD515 TotoCycling Road Bike
Quoted: 27 Post(s)
Liked 32 Times
Every bicycle I have had in the past 6 years has had tire liners. On my old Diamond Back the nipples stuck out a little bit so if I ran a really high tire pressure without a liner the inner tube would occasionally pinch the sharp edge of the nipple and get develop a small hole. On the newer wheel sets I have the nipples are either much smoother or recessed a bit so that it is not a problem. I use the tire liner for a little extra security though.
Gray Haired Commuter
I had a pair on a recumbent but I ended up taking off the back one--I just didn't like the feel when cornering. Fast forward a few years, and I found my recumbent, which had been stolen eight months before, sitting for sale in front of an LBS. That airless tire was still on the front and was looking bad. (not enough evidence to recover because I lost the receipt but I betcha Judge Judy would have given it back!)
