converting...
converting...
...my old panasonic to fixie, i want to do a flip-flop hub but am not set on it. need some suggestions on the parts i need....which need to be reasonably inexpensive as i have house projects that take priority.....or so my wife says.....
heres the bike stripped down waiting for final touches...and a good cleaning....
![](https://img.photobucket.com/albums/v645/drumsnotjames/IMG_0475.jpg)
Bicycle User
Bikes: Felt F1x
That's an awesome bike, people on this forum hate on conversions but I think they're sweet. If I were you I would just thread on a fixed sprocket and be done with it, later if you really can't get used to fixed riding then swap your old hub out for a flip flop hub. How big are your chain rings up front?
Bikes: 2005 Specialized Hardrock Sport, 1970's Miyata Liberty ala fixed gear
Formula hubs are cheep and haven't failed me after 2 years of use in all weather, snow/ice included. What sort of part suggestions are you looking for? Your post wasn't explicitly clear as to what you wanted, so if you wanted guidance : https://sheldonbrown.com/fixed/index.html.
Quoted: 110 Post(s)
Agreed- take your rear wheel in to the LBS and get it redished and have them put on a cog with some loctite. It will only cost ~$30 for all parts and labor. Then throw it on your bike, get a chain, and ride! People here hate on this setup, but if you don't want to immediately spend at least $100 on a wheelset, plus new tires and tubes for the 700 wheels instead of your 27" (which I'm assuming this has), then this setup will work fine.
I"ve been running the exact setup for over 2000 miles and had no problems with it- you just can't expect to do sick skidzzzz- use a front brake.
At least it'll help you decide on whether or not you like fixed riding. Then you can go out and blow $700 on a track bike. Just make sure you RUN A FRONT BRAKE.
+1 on the formula hubs
Real Men Ride Ordinaries
Quoted: 17 Post(s)
It's best to run a rear brake as well with this setup. Redundancy is always a good thing, since backpedaling can not be counted on to stop you, you could benefit from a backup in case your front brake breaks (break brakes). It's a bit paranoid, but sometimes that's a good thing.
extra bitter
How to you "thread on a fixed sprocket"? You can modify your freewheel to be "fixed", but to thread on a cog you need a hub with threads.
Edit: Operator caught my typo above. The threads are of course for a freewheel, not a cassette.
on Baby Charlie Concept~
i say if you're going to ride your bike after you convert more than you would even touch your bike now = convert it~ dont let your bike sit there and rust~
Bicycle User
Bikes: Felt F1x
Step two:thread on fixed sprocket
+1 on J.B. weld btw
cab horn
Bikes: 1987 Bianchi Campione
Quoted: 42 Post(s)
Liked 28 Times
Half of you people have no idea what you're talking about. That bike does not have "cassette threads", there's no such thing. He either has a freewheel, which threads on - or you don't (cassette). If you have a freewheel then you can throw a fixed cog on there and run a suicide setup. Respacing and redishing may not be necessary depending on the chainline.
Just because you haven't had problems doesn't mean you should start suggesting this setup to others. Especially if you're backpedalling/skidding.
extra bitter
I obviously mistyped above -- cassettes are for freehubs as operator noted. But if the OP does go with the existing hub (assuming it's threaded), simply gluing on a cog just isn't a good plan. At the very least, there should also be a bb lockring outboard of the cog, but even this isn't a very reliable setup as you're still working in the same thread direction. It's fine to go this route as long as you have a contingency plan -- without getting into a big argument about whether brakeless setups make sense at all, a brake is even more important as a failsafe with "suicide" hubs.
Quoted: 17 Post(s)
That's something else entirely though.
Back to the OP, I suggest just buying a new fixed gear rear wheel. Unless your budget is really tight, it's the easiest way.
havent been in the forums lately, thanks for all your input and help, i'm probably going to end up just updating the wheels and crank with a flip-flop (fixie/ss) hub with the help of a friend who has an extra wheelset he doesnt need. i'll try and post pics after but it may be a while cuz unfortunately money is still an issue lol
