Post your Moots!
Post your Moots!
I don't have a Moots, but I want one...a lot. So everyone post up your Moots! There is a post your ti thread, but that is mostly full of litespeeds, with only a few Moots. I just want to see how you all have built up your moots, and whether or not they ride as nice as they seem.
I ... mmmmuuussst ... have ... MMMMOOOOOTSSSSS!
Thanks...I tried carbon cages but I liked the look of King Ti cages mo betta. If I recall, in that pic it was at 13.8lbs...since then lost a little weight on the steerer trim and then back up a now since I've added a Hydrotail with two more cages.
Here's a pretty high/rough estimate from WrenchScience...biggest difference is mine is a Vamoots SL which was slightly more expensive and now discontinued.
Bike Parts: Model:
Frame Moots Vamoots Titanium 48.50 51.80 TRD 2.88lbs
Fork Reynolds Ouzo Pro | Carbon | Carbon C 43.00 445.00g
Brake Set Campagnolo Record-D 11 Skeleton | Black 282.00g
Brake Shift Campagnolo Record 11 QS Ergopower 338.00g
Cable Campagnolo Stainless | 120.00g
Housing Campagnolo Campagnolo | Black 160.00g
Crank Campagnolo Record 11 Carbon 175.00 39-53 699.00g
Bottom Bracket Campagnolo Record | Aluminum | Silver 52.00g
Front Derailleur Campagnolo Record 11 QS 75.00g
Cassette Campagnolo Record 11 | Steel/Titanium | 12-25 201.00g
Rear Derailleur Campagnolo Record 11 | S 179.00g
Chain Campagnolo Record 11 242.00g
Wheelset Lightweight Standard III 12 spoke Carbon Rim Carbon TUB 1060.00g
Skewer Set Salsa Titanium flip-off | Black | Titanium 85.00g
Rim Tape Velox Cloth Rim Tape 15.00g
Tire Set Vittoria Corsa EVO CX | All Black | TUB | TUB | 21.00 540.00g
Pedal SpeedPlay X/1 Ti | Black/Ti 150.00g
Headset Chris King NoThread Set | Black 126.00g
Stem Moots Open Road Ti | Brushed Titanium | 100.00 | 6.00 145.00g
Handlebar Zipp SLC2 Carbon (Ergo) | ERGO | Black | Carbon 190.00g
Handlebar Tape Deda Elementi Soft Touch | Black Carbon 15.00g
Seatpost Moots Ti Titanium 280mm Setback 280.00g
Saddle Fizik Arione CX Carbon | Black 159.00g
Bike Weight: 15.62lbs Bike Sub-Total: $11,851.22
Total Price: $11,851.22
Bike Parts: Model:
Shoebomber
Bikes: 2008 Canyon CF Pro w/ Chorus, 2005 Moots Vamoots w/ Ultegra, 1988 Cannondale commuter
There are a few changes, but you get the idea.
1. The wheels have been swapped to Campy and are now on my Canyon.
2. Speedplay --> Keo carbons
3. The stem is the next to go as the Garmin mount isn't a fan of the shape. I'm thinking a simple 3T alloy.
If I had to do it all over again I'd probably order a compact, but this bike has been good to me.
