syntace bullhorn
Bikes: 2008 Mercier Kilo TT
Not sure if this answers your question, but I thought the Syntace Stratos bullhorn drop length were measured in millimeters from the clamp to the horns (instead of angle?), for example, the deepest drop one is 400mm. Here's a 400mm on my bike:
![](https://www.pixelparlor.com/images/bikeforums/zip_bike43.jpg)
matters cryptozoological
Bikes: 2005 Specialized Hardrock Sport, 1970's Miyata Liberty ala fixed gear
The ones furthest back are the 15 degree's I think. I would imagine they are measured in the following manner: put the center of a circle at the center of a pair of bars level with the ground, define angle zero to be parallel with the ground also, so angle 15 (or -15) is a 15 degree arc down from degree zero.
Bikes: See Signature
I prefer a shorter stem for my bullhorns compared to my drops. Right now it's a 80mm (bullhorns) vs 110mm (drops). No rise/drop on either. All this depends on your comfort level though as pointed out by fuggers.
out of shape
this is good common sense, although the amount your stem length changes depends on many factors— there isn't a fixed rule of thumb.
