Feel a click sometimes when I pedal
So I rode maybe 10 miles today and I noticed there was a weird click that I could hear and feel when I pedal that happened maybe about every 2 minutes or so about 5 miles through the ride.
I could not tell if it felt like a lock ring slipping, nothing like the cranks going from 12 o'clock to 6 or anything....
My chain tension is a bit looser than it should be and I will try and fix that tomorrow. Also I rode through some dirt and small almost sand like pebbles and it was damp/wet. I don't think I felt any weird click until after I road a small amount in that area... but could coincidence.
Also I can't seem to force it to happen. It doesn't seem to matter if I pedal with just one foot or the other apply a lot of pressure or a little to the drive train. I do NOT notice it if I just hop off the bike and spin the wheel. I feel it more in the cranks than in the pedal when I am riding.
What do you think it is?
Bikes: Bianchi San Jose, fixed
Loose chainring bolt is my first guess.
Second is a stiff link in the chain. (not much you can do about this)
Possibly a third could be the bottom bracket, depending on how old it is.
It's all new. Kind of felt like it was in the BB to me, but I really don't know what I am talking about.
abides and rides
My first thought was a stiff link too, and you can do something about that. You have to take the chain off, bend all of the links until you find the culprit/s (if any), then you can bend the chain back and forth laterally on the pin of the stiff link to loosen it up.
Otherwise it could be the classic "cog and lockring aren't tightened down properly".
Well I think it's sand and and crap from my last ride stuck to the chain, crank, cog, and between the crank and the bottom bracket. I think that is mostly what I feel when I pedal is a piece of crap in or around the BB.
I unfortunately do not have a tool to take the cranks off to get at the bottom bracket to attempt to look at it and clean it, but I can see with a flashlight there is some junk down between crank and BB. Are small rocks and sand really that dangerous to a bike?
Bikes: Schwin Twin, Rayleigh sports (1968), Bianchi (dont know year or type), Green fixed - built to my own desires, Cannondale CAAD9, Schwinn ss build, Fugi something-or-other.
if it is a stiff link, cant you use a chain tool and change out the link or pin?
They should be able to go over on the spot, and there is a chance the wont even charge you for it, because of how quick it is to check and fix.
diamandgeezer
Bikes: Kona Kula Deluxe, Singlespeeded Ridgeback MX3
![Smilie](images/smilies/smile.gif)
You still need to do it the normal way if you're actually connecting two links, but if they are stuck then push the link apart by half a turn or so, and it should be fine.
I generally find that cheap chains (BMX ones in particular) need this treatment, while more expensive 9 and 8 speed ones don't.
I hope that helps, and that it was clear enough (it really needs a diagram).
