Six Bike Hardtail Shootout
Bikes: 1979 Centurion Super Le Manns, 2009 Trek Madone 5.2
Looking at buying a hardtail. In this price range, these seem to be the contenders. They will be used more for distance jaunts/light offroad use rather than hardcore mountain biking over redwoods and off cliffs. Are they all about equal and you can't go wrong with any of them, or does one model do what I want noticeably better than the others?
What a dope I am... forgot to list the bikes.
Kona Caldera https://www.konaworld.com/09_caldera_en.cfm
Specialized Rockhopper Expert Disc https://www.specialized.com/us/en/bc/...=39224&eid=107
Trek 6500 https://www.trekbikes.com/us/en/bikes...6_series/6500/
Felt Q720 https://www.feltracing.com/09-catalog...s/09-q720.aspx
Cannondale F4 with Caffeine https://www.cannondale.com/bikes/09/cusa/model-9FS4.html
Jamis Dakota Sport https://www.jamisbikes.com/usa/thebik...port_spec.html
Thoughts anyone?
Thoughts anyone?
Bikes: 2008 Tarmac Elite, 2002 Cannondale Cyclocross
I am a roadie thinking of getting my 1st hard tail and considering several bikes from the list above as well. would be very interesting to read your opinions, characteristics of the bikes and so on.
thx
thx
in order for me to offer opinions on those bikes i would need to know something about them. im not a bikeopedia. im not going to cross shop 6 bikes for you. and im not the only one here who feels this way.
prices and forks would be a good start.
I added links to my first post so you can see all the info very quickly. Here are the primary stats:
Kona Caldera $1000 - RockShox Tora XC 100mm Travel Fork
Specialized Rockhopper Expert Disk $1100 - Rock Shox Tora SLite, 100mm
Trek 6500 $1150 - RockShox Tora SL Coil w/rebound 100mm
Felt Q720 $1000 - RockShox Dart 2 100mm
Cannondale F4 $1120 - HeadShok Super Fatty w/ DL, 80 mm
Jamis Dakota Sport $1150 - Rock Shox Tora SL Coil 100mm
It would appear Kona gives you the most bang for the buck.
Perhaps I should ask what are equivalant forks among the big brands. Fox, Rockshox, Marzocchi, Manitou, Magura, RST, Suntour, and Mozo. Meaning a Rockshox Tora is equal to a Marzocchi??? Any suggestions or links to learning stuff about shocks?
Very nicely done.
Okay...
The Tora is a quality, serviceable,adjustable, upgradeable fork. That's nice because completly changing a fork for a better one is really a big chunk of change. With maintenance, a Tora will serve you until you can afford to be pretty picky about your fork.
So I'd immediatly narrow down choices to the ones with Toras. I like the Kona. The spec looks solid. I've personally owned the predecessor to the Caldera called the Cinder Cone and I will tell you those guys know how to put a hardtail together. I still have that frame and it doesn't give up much to my Banshee hardtail.
The Caldera- my recco is to ask to try one size down from what the salesperson says fits you. Make sure the seatpost can be extended high enough without going past max. Consider getting the smaller size if you plan on getting into the technical side of riding. These frames are capable of much more than straight cross country grinding.
Okay...
Creamy pack filling
Bikes: Trek 8000, Co-Motion tandem, Co-motion Espresso, Yeti Cross, 9Zero7 Fat Bike
Can you test ride each bike? Each will have a different ride Characteristic and that should help you narrow it down. I owned a 95 Kona AA and it was a great riding bike but the paint chipped easily. I still have and ride my Cannondale CAD3 which has over 10,000 miles on the frame. My main ride now is an 09 Trek 8000 and it is a fast/great riding bike. Try going to MTBR.com and see what people have written about these bikes and there components.
-F
Peloton Shelter Dog
-F
