Campagnolo Crown Race Replacement?
Quoted: 1633 Post(s)
Liked 2,256 Times
Can just the crown race be purchased for a 1" steerer? It is for my 83 Colnago. If not, was there a difference in the crown races used between head sets? I would think the NR and SR would use the same and maybe other, new head sets.
I am stripping it down and found the crown race was broken. I suppose it would work if the crack is located toward the rear, but I am thinking it should be replaced. I did not feel the crack prior to dismantling when rotating the fork.
Bianchi Goddess
Quoted: 2973 Post(s)
Liked 3,081 Times
well if it is apart and broke I would fix it. I think the only difference between NR and SR was alloy cups and nuts (but still steel races). you may find a Miche, Ofmega or Gipemme will fit too alot of those were copies of early campy.
Sugar "Kane" Kowalczyk
Si se Puede!!!....Ahuevo!
I have a stack of varies HS parts that I'll check to see if any might work if you'll interested.
Ese dicho que me han dicho que tú has dicho que yo he dicho, ese dicho no lo he dicho, porque si lo hubiera dicho, ese dicho estaría bien dicho por haberlo dicho yo.
Old fart
Quoted: 3618 Post(s)
Liked 3,458 Times
You *could* use an NR crown race with an SR headset if your steer tube was long enough and you didn't mind the extra metal hanging out, but not vice-versa.
juneeaa memba!
Bikes: Crap. The box is not big enough...
Quoted: 13 Post(s)
Know someone with a mill or maybe a lathe? A good machinist could make a copy (have to use a hard alloy, though). If you have one made, you may as well have 50 made and sell 48 on eBay, because it is a common problem. (the 49th? send it to me, for the idea!)
Liked 2,256 Times
JohnDThompson: Good info of SR vs. NR. Using the NR would decrease the number opf thread engagement with the locking nut. What is the difference in stack height? The NR looks harder to break from interferance fit.
When I measured the difference in ID of the race and the OD of the fork, there was as much as .005 difference. I guess the paint build up added to the OD and caused the failure on installation. Once cleaned up it was closer to the .002 interference number.
gr23932: The ID is 26.40 mm. The OAHeight is 7.73 mm and the bearings are the standard Campy 4.76 mm.
Luker, I do know a great machinest who is very reasonable. What do you think a good price would be? I could reverse engineer the dimensions and sell them too!
Great State of Varmint
Liked 15 Times
Most people just bought a Tange Levin. Same headset, in effect. Every bit as good as the old Campy, just cost 1/3rd as much and didn't say 'Campagnolo.' Still in production. Hunt around. I've seen them offered for as little as $20.00
Old fart
Liked 3,458 Times
Yes, the NR crown race is quite resistant to cracking vis-a-vis the SR. At Trek we broke dozens, maybe hundreds of SR crown races installing them on forks. I can't recall ever breaking an NR race, though.
Re: machining a new race -- this could be done, but it will need to be hardened as well or it will wear out in short order.
Old fart
Liked 3,458 Times
The "Levin" is a great headset, but it's more like the Campy "Pista" headset than the "Strata." It uses smaller balls (5/32" vs 3/16" in the Campy Strata) so it is marginally less durable than the Campy Strata, and the stack height is a few mm less than the Strata.
The cost of machining this by a local shop would be so high, it would be less expensive to buy a NOS SR/NR headset
Quoted: 3471 Post(s)
Liked 2,845 Times
When set up for production, the cost drops, in even "reasonable" batches the cost climbs fast. If Velo Orange was interested, they could probably have someone make up some that would be at a final reasonable cost, Going to be hard to get it below $15. to $20. which is outrageous but not.
For steerer size, Campagnolo has a Passa/no passa tool. Too big, and it will crack a crown race in no time.
Liked 2,256 Times
My thoughts were to just replace the SR crown race with an NR crown race. The stack height would only change based on the difference between the two parts.
My machinest only charges $25/hour. The secondary costs would be of concern and there would not be significant reduction in batch without using a full CNC set up. Sounds like an opportunity for a good Chinese sourced product!
Good to know the difference in the Levin. It was tempting until you pointed out the diff.
So where did Trek get the replacement crown races they broke? Robbed full HS sets? Was the solutions so cost effective that corrective action was not required?
I haven't seen any opportunities to purchase just the crown race. Hence my initial thought of buying a used NR HS and just using the CR.
Liked 2,845 Times
Liked 2,845 Times
Old fart
Liked 3,458 Times
At the time, Trek was the largest importer of Campagnolo parts in North America. Getting replacements wasn't a problem.
Liked 2,256 Times
Indents? Worst case, I can use the same CR. I cannot feel the crack with my finger nail, so I really think it would be low risk for reuse. As stated, I think it broke on installation. I did not detect any "index" steering prior to disassembly.
Bikes: +/-2000 Alp d'Huez (Dura Ace/Ultegra) Alloy Synapse disc (Ultegra), '84 de Rosa Eddie Merckx Super Prestige (Modified with 10sp Record mechs), Carbon Synapse disc (SRAM Red), '80-something Trek 540 (7sp AccuShift), Serotta Fierte (Ultegra)
Quoted: 30 Post(s)
<At Trek we broke dozens, maybe hundreds of SR crown races installing them on forks>
did the Trek folks ever try heating the races before installing them? not enough to ruin the temper, just enough to get them to expand a few thousandths...we used to heat aluminum cases to set bearings, or crank throws to fit bosses, when I worked on BMW motorcycles...
Quoted: 556 Post(s)
Liked 133 Times
Holy cow. This thread was from 09. Did you ever get your crown race repaired, SJX426? Hope so.
(I happen to need a NR crown race, Dbakl. Can I drop you a PM if the OP doesn't? )
Quoted: 86 Post(s)
new aftermarket crown races are pretty inexpensive in my experience. i would invest in one and see if it works. i would just make sure that i got one with the correct inside diameter. of course this assumes that originality is not an overriding factor.
MIKE is my name!
Bikes: hans lutz, , puch mistral ultima,2x Austro Daimler Smoked chrome Ultima,Austro Daimler Mixte,Austro Daimler 531 mixte, flying arrow,F Moser,
Quoted: 7 Post(s)
Liked 21 Times
Ok, making a new one could be done,
have to grind and polish the race....and then harden it, thats easy, which would mean it is a good quality steel,
but then it would rust.
i know a forum member that could do it but it is up to them to step forward,
