52/39 = compact?
Smarter Than He Looks
Bikes: Shopping
52/39 = compact?
Is a 52/39 crankset a compact?
When I started shopping for my first roadbike, I did a little research and decided with my age, weight, fitness level and no desire to race that a Compact crankset would be a good way to go for me.
I ended getting a Scott Speedster S40, and went with the Compact instead of the Triple.
So I've been riding the bike for a little over a week and am very happy with my choice. We've got some challenging hills in the area and I've been able to manage them. Maybe a little lower gear would be nice, but not critical. And since I'm still getting comfortable with descending, the tallest gear is plenty.
It was after today's ride that I actually noticed my crankset is 52/39, not the 50(or 48)/34 I expected for a compact! I just checked the Scott webpage, and sure enough they claim the Speedster S40 comes in either Compact 18spd or Triple 27 spd, and spec the compact as 52/39. Check it out: https://scottusa.com/us_en/product/16.../speedster_s40
I'm not complaining, because as I said I'm okay with the 39 for local climbs. But isn't 52/39 a standard road double? Of course I haven't measured; maybe my bike has the smaller (110mm?) bolt circle.
Still can't climb
Quoted: 12 Post(s)
Liked 6 Times
not a compact. i have a 52/39 double. perfect for rolling hills. the climbing doesn't require anything less than 39/25 because no matter how tough the steepest bits are, they are never long. The downhill doesn't require anything bigger because before i run out of gears the descent if finished.
coasting, few quotes are worthy of him, and of those, even fewer printable in a family forum......quote 3alarmer
No @coasting, you should stay 100% as you are right now, don't change a thing....quote Heathpack
Bikes: Specialized Tarmac SL2, Specialized Tarmac SL, Giant TCR Composite, Specialized StumpJumper Expert HT
It can be but almost certainly is not. Compact refers to the bolt circle diameter. A "standard" is 130 (campy is 135) and compact is 110. The smallest inner chainring you can get on a 130BCD crank is a 38 although 39 is more typical these days, whereas 42 used to be typical. A compact 110BCD crank often comes with a 34 or 36 inner ring. The outer ring on a compact is usually a 50 so that the jump from the inner to outer ring is not too large.
Bikes: CAAD9-1, Windsor Cliff 29er
Yes, I said that it almost certainly is not. It is possible to get "standard" sized chainrings for a compact crank but they are uncommon and the chance of a bike coming with one is virtually nil.
Bikes: Shopping
Thanks for the feedback. Like I said, as it turns out it's not a problem, just odd that they would advertise it as a compact.
Bikes: 2009 Cannondale CAAD9-7
50/34 is the "normal" compact as far as tooth count...
i went with the 52/39 and i didn't feel i needed that 34 tooth ring... if i want to later i can just go to a 27-28 out back... there are some pretty steep hills in my area but i've managed them all so far aside from one...
As far as 50/34 being a "normal" compact, my Giant TCR came with a 50/36.
serious cyclist
Bikes: S1, R2, P2
Quoted: 9334 Post(s)
Liked 3,679 Times
Bikes: 08 Schwinn Madison
Sorry for the thread hijack, but I am in the market for a road bike which I am planning on racing in the future. Is there a big downside to a compact crank when racing? I really dont want to have to upgrade the crank, and would rather just buy a bike w/o a compact crank from the start if I know it will keep me from performing lower than I possibly could. Thanks a lot
Sua Ku
Bikes: Trek 5200, BMC SLC01, BMC SSX, Specialized FSR, Holdsworth Criterium
Sua Ku
Not tying to be smart. There are some advantages of a standard. I have time trialed using my compact on very flat courses, I guess I'm just weak!
serious cyclist
Bikes: S1, R2, P2
Liked 3,679 Times
Glimmers of form
Bikes: Cannondale SystemSix 3, Specialized Stumpjumper M4 Comp
Bikes: Surly LHT, Specialized Rockhopper, Nashbar Touring (old), Specialized Stumpjumper (older), Nishiki Tourer (model unknown)
Not exactly. Compact= old school standard crank BCD with smaller rings.
Compact as defined by the late great Sheldon Brown: A double-chainring crankset that permits the use of smaller chainrings than will fit with the common 130 mm B.C.D.. Most "compact double" cranks use the old standard 110 mm B.C.D. which permits the use of chainrings as small as 33 teeth (more commonly, 34 or 36 teeth.)
Compact crank sets usually come with a 50 tooth chainring, and will normally go with an 11 or 12 tooth top sprocket in back.
110 mm B.C.D. double cranks with full-sized (52-42, 52-40, etc.) were common in the late'70s and early '80s, but they had become nearly extinct for double chainrings. The rebirth of this format, with smaller rings, was pioneered by Tyler Hamilton who used one of these in the 2003 Tour de France
Bikes: Shopping
OP here...
I measured, and my bolt circle diameter is 130mm, so even more definitely not a compact. Wonder why Scott claims it is....
It's also possible that the shop that build it up swapped the part for whatever reason
Northern Rider
Quoted: 115 Post(s)
Liked 811 Times
I had my 9-speed regular drivetrain swapped out to a 10-speed compact last winter. Out of curiosity I compared the 2 setups with the Sheldon Brown gear calculator and this is what I got: (compact on the right).
With the new 11 and 12-tooth cogs I am getting a greater proportional advantage at the top end of the range than at the bottom with the same size 25-tooth cog, despite the compact setup. I tried it in hilly country just last week - no serious complaints but on a 13% gradient I was hoping for a greater advantage at the low end. The message being to take a close look at the rear cassette as well as the compact crank when making this decision.
