BMX handlebars
BMX handlebars
I have a Cannondale Bad Boy which I believe comes with a 31.8 diameter flatbar. I would like to change it to something more like a BMX handlebar, because it will provide a lot more rise. Before knowing that there were substantial differences in diameters, I got a BMX bar which I thing may be a 22mm bar. I don't think a shim would be prudent here, but I was wondering if anyone had any ideas on how I could do this. Are there BMX clamps that will work on a mountain bike setup like the bad boy? Alternatively, are there any, more professional "tubes" for lack of a better word that could serve as a shim here?
On the other hand, are there any BMX style bars that could fit a 31.8 mm bar?
I suspect I will get some flack on the stupidity of my predicament, but any positive input would be greatly appreciated.
MTBabruni
Bikes: 02' Specialized Hardrock Pro Disc,09' Eastern BMX
Correct me if im wrong. But cant he just slap on a BMX stem and put bars on?
I abubacad your sister
Bikes: Sunday Model-c full custom,Sunday second wave full custom ,Supercross RCR Full custom bmx race cruiser
Why would you want to do that
Your imaginary friend.
Bikes: A sweet Quamen ATL custom, GT Mach 2
Get a race stem or something like that. Looks like a mtb stem for the most part. It is a 1-1/8 it will work.
Every passing minute is another chance to turn it all around.
Live To Ride Ride To Live
Bikes: Fit flow
yeah the fork steerer should be standard size, just swap to a bmx stem.
BMX For Life
my pedals are to big
Bikes: 20" bmx, and a 75' gitane
Ha! Well, mainly beucase the bike is a little small for me, I am using it for a commuter, and the BMX handle mbars make so much sense. It allows me to sit up straight (which is important as i am riding about 15 miles a day), and, as a guy who is 6'1" and 235 lbs, nothing is more durable than a BMX setup in my mind.
Finally, how awesome would it be to have a full sized comfort bike that still looked like a BMX? In a land of single speed hipster kids, I would be happy to stand out a little.
This is the way of the future. Drop down bars are really not functional with commuting or casual cycling.
I recently put BMX bars on my single speed commuter bike. I will never go back.
Likes For markpemble:
Quoted: 1074 Post(s)
Liked 295 Times
Sitting straight up is generally not such a hot idea for longer rides as it puts more weight on your butt and makes it more difficult pedal effectively.
And increases air drag.
Seems like the Bad boy is listed as having an 1 1/8" steerer, which would make swapping in another stem with the bar clamp diameter of your choice easy.
Although I wouldn't hesitate to use shims.
Should be something on this list that'll work:https://www.amazon.com/s/ref=nb_sb_n...ebar+shim+31.8
Likes For dabac:
Quoted: 1632 Post(s)
Liked 2,725 Times
https://www.amazon.com/Wake-Mountain...MS013M7W1JQFRD
You will probably need longer cables also.
Old Rider
My '90's Giant mtb with 9 inch bmx bars
I needed a stem adapter but all you need is a bmx stem, bars and longer cables.
I'm looking for some low rise (4-5 inch) bars but they are hard to find.
Likes For jan230:
your bar is the newer oversize, 31.8 is 1.25" essentially.. BMX bars are 7/8" tube at the clamp (& all the tubing) 22.2 mm
Machined shims are made you want one with a 22.2 inside and a 31.8 outside to continue using the stem you have..
the difference, in radius , so machined shim thickness is 4.775 mm [1/2 9.55.. in combined difference of 2 diameters..]
Bikes: Cannondale BAD BOY 1 (2018)
Quoted: 5 Post(s)
I used be a BMX rider exclusively. Now that I'm older, I got a Cannondale Bad boy 1 recently. Then...I see your post. You might have tickled something in me.
Aluminum Ally
Bmx bars on a fixie
It's all about ride position and ergos. Bmx bars are great for a more upright riding position.
On a freewheel bike it is nice to be able to stand on your pedals and be able to stand up straight. To do this your crank arms would be parallel to the ground. One foot in front and one in back. For this, I prefer tall bars, up to 9 inch rise.
On a fixed gear when you stand on your pedals they are moving with means at your lowest point you are dropping down six inches because your standing on your down pedal and bending your leg on the top pedal, rising up to that horizontal crank position, and repeating on the other side. Average riding position about 3 inches lower than a standing coast. For this reason up to six inch rise handlebars are good for an upright riding position on a fixie.
Standard bmx bars clamp at 22.2mm for which many bmx stems are available. Aluminum bmx bars such as elevn or box have a clamp at 31.8mm for which your stem will work but they usually pitch too far forward. Truvativ Husselfelt stems are great and are cheaper then the box or elevn stems. The aluminum bars are rated to support a lower weight but they are rated for doing stunts and jumps, for commuting or track riding they support an adult just fine. I prefer these because bmx bars are a lot of metal and the aluminum add a lot less weight than the steel.
Sorry for rambling, but I tend to over analyze things. Anyway, I hope that helps.
55+ Club,...
Bikes: 9+,...
Quoted: 1146 Post(s)
Liked 882 Times
Old and rusty
Bikes: 1983 Lotus, 1989 Haro Escape, Quax muni, KHS?, Nishiki Olympic 12
Quoted: 66 Post(s)
Liked 111 Times
It was a useful thought. And something I’m looking to do.
Some aluminum 5 or 6” BMX bars would be perfect on this.
Dirty Heathen
Quoted: 895 Post(s)
Liked 942 Times
Makes for a very fun bike to ride!
Likes For Ironfish653:
Aluminum Ally
55+ Club,...
Bikes: 9+,...
Liked 882 Times
Aluminum Ally
Quoted: 408 Post(s)
Liked 184 Times
We forget upon joining that a newer member might have similar questions we have long since had answered and will, through no fault of their own, reply. I have oft benefitted from old posts. Perhaps the members offended have their bike shorts on too tight...LOL!!
Likes For Chuck Naill:
