Cobra Tubes
Fresh Garbage
Cobra Tubes
https://www.flybikesbmx.com/en/news/post_1001
Yo, how many of you would use these tubes?
I posted this here because I was thinking about how we have to go though the trouble of removing the rear wheel and messing with chain tension when all the work is done. Now, if these tubes actually do a good job, all that is pretty much done with.
If only they were with Presta valves.
a.k.a. QUADZILLA
Bikes: Super Pista, Basso, Big Dummy
Certainly would be a cleaner tube swap…but it's not really that much of a hassle to take the wheel off and adjust chain tension. I've changed a rear tube during a race in under 5 minutes. That is an awesome idea though. If they weren't any more expensive than what I normally get (you know, proper size with presta valves with removable valve cores) I would surely give 'em a try. I don't think I'd pay any more for them though.
Fresh Garbage
I know it's not a huge hassle, but there have been days where I forgot my wrench at home.
Bikes: IRO mark V
wait so is the only advantage that you don't have to take your wheel off???
Is it really that hard to take a wheel off?
META
Bikes: Gary Fisher Aquila (retired), Specialized Allez Sport (in parts), Cannondale R500, HP Velotechnic Street Machine, Dented Blue Fixed Gear (retired), Seven Tsunami SSFG, Specialized Stumpjumper Comp Hardtail (alloy version)
It's really not that difficult to take a wheel off.
and you're probably better off getting a Hutchinson Road Tubeless kit from Stan's than going about this route. With the extra weight of a Deep-V you need to shed some weight at the rim anyway.
Elitest Murray Owner
Bikes: 1972 Columbia Tourist Expert III, Columbia Roadster
Trying to replace a tube without removing the wheel sounds fantastically frustrating...
Can you imagine trying to hook the end of the tube over the valve with the tire in place?
Framebuilder
Quoted: 8 Post(s)
Somebody still makes these?
Specialized tried out this idea about 10 yrs ago, called it the "dirt worm". The idea was faster tube changes during a race and, Suprise! They were more of a hassle than removing the wheel.....I think they only sold them for one year.
I think it's more geared for the fellows who have standard bolts (nuts?) instead of QR. I could see it being easier then carrying around a wrench or whatnot. But meh.
Low car diet
Bikes: 2006 Windsor Dover w/105, 2007 GT Avalanche w/XT, 1995 Trek 820 setup for touring, 201? Yeah single-speed folder, 199? Huffy tandem.
It's not that bad. Sometimes if I have a rear flat, rather than removing the wheel I'll remove one bead of the tire, pull the tube to the side, find the hole, patch it, and reinstall the tube and tire. This is with full fenders and a rack with a wide pannier support area.
