Spoke Calculator
Tilting with windmills
Bikes: Many
Spoke Calculator
Anyone know a good spoke calc that will work with older hubs and new rims? I have a NOS set of Chorus 8 sp hubs and an older D/A set of hubs I want to lace to modern rims.
Bianchi Goddess
Quoted: 2967 Post(s)
Liked 3,045 Times
Hello Wylie? hhmmm not sure I have been through there. anyway.. tha only spoke calcu;lator I ever used was the "Wheelsmith" system back in the early '90s. I have seen losts of post on here directing others to different sites. you may have to measure own hubs though and plug in the values. we had to do that for a year or two when 'freehubs' first came out. try the search forum with things like spoke length or wheel buliding.
Sugar "Kane" Kowalczyk
Bikes: Klein
The Spocalc spreadsheet has Chorus and Dura-Ace hubs and recent rims. Plus there's the option to enter your own data.
Cat 6
Quoted: 500 Post(s)
Liked 184 Times
I've used spocalc with old 8s Record/Chorus hubs and 72xx/74xx DA, so I can add relevant experience here.
72 Frejus (for sale), Holdsworth Record (for sale), special CNC & Gitane Interclub / 74 Italvega NR (for sale) / c80 French / 82 Raleigh Intl MkII f&f (for sale)/ 83 Trek 620 (for sale)/ 84 Bruce Gordon Chinook (for sale)/ 85 Ron Cooper / 87 Centurion IM MV (for sale) / 03 Casati Dardo / 08 BF IRO / 09 Dogma FPX / 09 Giant TCX0 / 10 Vassago Fisticuff
If I own it, I ride it
Quoted: 594 Post(s)
Liked 666 Times
A +1 for Spocalc. However it has been my experience that you need to subtract 1-2mm from the length provided.
Quoted: 413 Post(s)
Liked 111 Times
All Campy and Shimano....and everything else with 39mm front hub flanges and 44/45mm rear flanges take essentialy the same length spoke.
Quoted: 242 Post(s)
Liked 353 Times
I wonder if such a thing still exists? It really wouldn't matter the age of components as long as you have all of the dimensions
I’ve had good luck with https://leonard.io/edd/ but I highly recommended seeking multiple sources and double checking all measurements yourself.
Data for current production rims should be easily obtained, a cheap caliper is very good for taking necessary hub measurements .
https://www.harborfreight.com/hand-t...per-63664.html
Quoted: 1118 Post(s)
Liked 1,346 Times
If it's the system you are referencing, I used it as a mechanic back then too. It was a "calculator" and 2 rods to get rim diameter. I had to use calipers to measure all of the hub dimensions. Needed number of holes and cross pattern.
(my pencil used long ago to correct Jobst's maths):
Likes For oneclick:
Bianchi Goddess
Liked 3,045 Times
Quoted: 409 Post(s)
Liked 599 Times
Spocalc 2022 works fine for me with no adjustments if component dimensions are selected from the program lists. Correct info in gets correct info out. Rounding up decimal length has also been best in my experience. I've done several sets of wheels with the 2022 version, all with different hubs and rims. Absolutely no complaint !
I did speak with a gentleman who had problems with it. He calculated for 2x and tried to lace 3x and the spokes were too short.
Have a nice day
Charlie
Have a nice day
Charlie
aged to perfection
Quoted: 862 Post(s)
Liked 1,297 Times
I have had good luck with CD50 Spokcalc and it has an extensive database of rims and hubs.
always good to independently measure ERD
/markp
/markp
Bikes: Franklin Frames Custom, Rivendell Bombadil
Quoted: 126 Post(s)
Liked 216 Times
I think https://spokelengthcalculator.com/ uses the spocalc database but it's in an easier to use format. It has mostly older parts listed. That said, measuring your own hubs and rims is not only easy, but necessary as you can't take anything published for granted. Plus, two people can measure the same hub and rim and they'll get slightly different results. It's usually not enough to change your spoke length though, given your dealing with 1mm or 2mm increments and not cutting them to exact numbers.
I've found that the above calculator, DT and Musson's all give very similar results. Musson has done an about face in his latest update about rounding spokes up or down, so when in doubt I go with DT's recommendation.
Liked 1,346 Times
I remember a printed card thingy with (two) sliding scales in a kind of envelope with open ends - you used one scale for the rim, another for the hub, and there were some correction factors or notes or something printed on the outer envelope.
A Bike Warehouse item?
Quoted: 1845 Post(s)
Liked 3,474 Times
It does illustrate one advantage of building a wheel 4x ... it doesn't really matter how big the hub flange is.
Steve in Peoria
Liked 1,346 Times
