MEN ONLY.... Cold Weather Problems.
Commander, UFO Bike
If adult discussions about anatomy offend you, you don't want to read any further. If not, scroll down.
Ok. So, you're not offended about frank discussions about male anatomy. Good.
I'm having a problem with the boys freezing during my nightly commute home when the conditions are cold and dry (wet, and I'll run for the local transit system). I'm not doing as well $$ this year, and I'm trying to keep my expenses down.
Anybody got suggestions on how to keep the twins happy on a budget?
Thanks
K'Tesh
Thanks
K'Tesh
Quoted: 52 Post(s)
Liked 17 Times
When I've had problems in that area it's been frequently due to the wind cutting through my clothes. You may need to add a wind resistant layer.
Pedal faster not harder.
Bikes: Ummmm...Cannondale F4000..Ummmmm...Yeti ARC-X Cyclocross..Ummmm...Rocky Mountain Vertex TO with a BionX PL350 Electric Conversion...Ummmmm..Rocky Mountain Cardiac..Ummmm..thats it for now I think. I'd have to go look in the basement to be sure.
It's a common problem for male cross country skiers. There are undergarments with an additional area of windproofing at the dangleberries location. That said I have never experienced this problem while cycling. I find the padding in my cycling shorts provides insulation and additional wind protection above and beyond my long undies and what ever tights or pants I wear. You didn't mention what you do wear. If you do wear traditional padded cycling shorts you could look into buying a larger pair of boxer brief style cross country skiing wind briefs that would slip over your cycling shorts. See above photo.
Bikes: Jamis Coda
I haven't tried it yet, due to the weather not being quite cold enough on my rides yet, but I've heard that using a sock as an insulating layer in the front of your shorts can help quite a bit. I'd think this may work well, as it would keep the tight, wind chilled portion of the shorts away from the subject area. i'd think some thick wool would be in order, in this case.
6 miles per taco, w00t!
Bikes: Jamis Coda
As this is second hand knowledge, I'm not entirely sure, but the way I read it, it sounded like it was put down as a flat layer, like a woman's maxipad. However, if you current riding conditions warrant, try it both ways and report back. I would think that adding an extra external insulating layer while allowing the body to contribute warmth would work best, compared to isolating the unit from the body's heat.
Older than dirt
Bikes: Too darn many.. latest count is 11
Ok, 'll try to take a more serious tone here, although I will admit the first thought wasn't so serious
Are you wearing loose fitting clothing? My thought here is that unless you're wearing something that keeps the dangly bits tucked up tighter to the core of your body then they're probably indeed getting chilled. I wear briefs that Target sells billed as "Cycling briefs" which are thicker than the tighty whities you normally buy, and they have no hole for escape. They come in black, and run $8-9$ for two pairs in the stores. No issues here in sub 20 degree.
As I posted , I noticed LesMcLuff's comment below.. Yes, the wind seems to howl through the seams of my fleece lined bibs... I've noticed that numbing affect.. For cyclists' , Nashbar has had underdrawers specially for riding.. Only time of the year I don't go commando, and it's keeps ones parts warm... The only time I find a need for this lower level base layer is when it's below about 35...
Pray for the Dead and Fight like Hell for the Living
^ Since January 1, 2012
Commander, UFO Bike
Older than dirt
Ok, but what underneath? Because sweatpants really don't afford much protection, and if you're going commando underneath it may be a lot of the issue. While nature will pull the boys closer to the core when cold, sometimes they need some help
CRIKEY!!!!!!!
Bikes: several
Quoted: 1602 Post(s)
Liked 690 Times
You could just eliminate the source of the problem alltogether. Since you're on a budget your local vet should be able to eliminate the offending appendage very affordably.
Lou at Foxwear makes a great pair of warm, wind resistant, and water resistant over pants for $104.50. They are well worth the money, and will last a long, long, time. I was wearing mine in extremely windy conditions with temps of -15c and was toasty warm. I was totally surprised at the warmth of the pants. It's a one time investment for many years of comfortable cycling.
He also makes super warm long johns too.
https://www.foxwear.net/products_pants.html
Cotton sweatpants as a thermal insulator.. This guy must have grown up in the Arctic...
Hot in China
Bikes: Giant Lava
How about a plastic daiper liner from the old days worn under the sweat pants? This would provide a good wind barrier, and plastic is good at trapping the air around the body and jewels, so the heat that is there wont escape.
This solution would have the further advantage of being within most budgets.
It would, however, also prevent the water from sweat from escaping, and may provide excellent conditions for the proliferation of crotch-rot.
Swings and roundabouts.
z
z
Señior Member
Bikes: Windsor Fens, Giant Seek 0 (2014, Alfine 8 + discs)
Quoted: 446 Post(s)
Liked 8 Times
At very cold temps (below about 0*F) I generally wear bike shorts, then thermal underwear, then my standard lined running pants, which do stop the wind. That's worked for me pretty well. I've tried stuffing in a wool sock between the shorts and the underwear. It helps some. I only go that far below about -10*F.
Work: the 8 hours that separates bike rides.
Been Around Awhile
Bikes: Vaterland and Ragazzi
Quoted: 12 Post(s)
Liked 1,568 Times
Sidenote:
I learned years ago, the hard way, about the advantages of plastic buttons over zippers at very low temperatures.
xtrajack
Bikes: Kona fire mountain/xtracycle,Univega landrover fs,Nishiki custom sport Ross professional super gran tour Schwinn Mesa (future Xtracycle donor bike)
I am a Fred. I hadn't noticed an issue. I wear briefs, longjohns, and Carhartt work pants. I have been playing with the idea of using my Rainmates as a windbreaker for my legs.
I generally don't ride below 0F (on purpose anyway)
hamster with funny pants
Cheaper than that, I've read about how good an insulator newspaper is (as Human Car mentions), but never tried it. If you're only looking for a temporary measure, that might be good to try first.
Back in my long distance running days,i found that on even cooler summer days,blood tends to go to parts doing the work(legs,heart) and leaves hands and the boys to fend for themselves. More than once i've stopped at wash rooms and stuffed some paper towels down there when running.I've even seen them hand out heated face cloths along the route on some runs for that purpose on cold runs.I use a wool sock just stuffed in there,takes care of that problem perfectly and packs light when not needed.
Bikes: Yes
Quoted: 3271 Post(s)
Liked 4,002 Times
I wear bike shorts and then a pair of thin non-padded tights, and that's been plenty warm for anything above 30. (I didn't ride on those few days in the 20's, so I don't know about that.) If you're intent on staying Fredly, jeans might be good enough. Or you could wear bike shorts under your sweatpants. No one would have to know.
