Where can I find a 45 tooth chainring
Bikes: litespeed classic/cannondale caad3
that is also Campagnolo ten speed compatible. I need this for junior gearing, and none of my local bike shops have been any help. The closest I could find online has 46 teeth (https://www.poshbikes.com/product.php?id=161), but with that still puts me over the roll out limit with a 12 tooth cassette. Does anyone even make this size chainring, or do I need to do something else to make the gear roll out without changing my cassette? I'm trying to keep the cost as low as possible, and any help would be appreciated.
what do you think I've been doing for the past 45 minutes.... none of those results are 135mm bcd and compatible with a ten speed chain
Here are two chainrings, its going to cost about 40 bucks for a new chainring. Thats the one thing that sucks about Campagnolo, the cost and lack of readily available components.
Stronglight Zicral 135mm 45T 33.93
https://www.ribblecycles.co.uk/sp/roa...ng/STROCHRI500
TA 135mm 45T 39.47
https://www.ribblecycles.co.uk/sp/roa...pd/TAAACHRI350
TA 135mm 45T 39.47
Go to the Salsa cycles website. They have a 45t chainring that will work. It says that it can only be used for 1-9 speed, however, it can be used for a ten speed.
The only difference between this chainring and a regular chainring is that the Salsa chainring has no ramps or pins which helps with shifting. Even though this is true you will not be able to tell a difference.
Bottom line: buy the salsa chainring. you wont be disappointed. I had this same problem not too long ago, and I am very pleased with this chainring.
here is a link: https://salsacycles.com/chainrings.html
It's ALL base...
Yes they are. I guess it would just be easier for the OP to buy a new 130 BCD crank or just go with the 52-14.
OP: unless you have some extra bucks to spend then I would just block out gears for this season and save your money for one of the choices above.
i need a 45t 135bdc ring as well (for fixed gear)
give these guys a call:
https://www.cycleunderground.com.au/chainringdesigns.htm
A little North of Hell
Quoted: 71 Post(s)
waiting...
Gebhardt: english link is not working.
https://www.gebhardt.cz/cs/silnicni-c...standard.aspx#
https://www.velosolo.co.uk/gebchainring.html
Carpe Diem
Bikes: 2007 CAAD9; 2014 CAADX; PedalForce CG1
Juniors shouldn't be using Campagnolo.
More seriously though. I can't find one.
"When you are chewing the bars at the business end of a 90 mile road race you really dont care what gear you have hanging from your bike so long as it works."
ΛΧΑ ΔΞ179 - 15% off your first Hammer Nutrition order!
TA 135mm 45T 39.47
TA 135mm 45T 39.47
Probably easier just to get the right cassette: Miche here, or Mirage/Centaur will be less of a hassle, and worth a few extra bucks.
Bikes: Specialized Tarmac SL2, Specialized Tarmac SL, Giant TCR Composite, Specialized StumpJumper Expert HT
This is like the third junior gearing thread in two days.
Bikes: 2006 Cannondale CAAD8
with lances comeback i am sure there is going to be another influx of new cyclists. besides the 99'ers i guess there ill be the 09'ers.
