Supplements
LBKA (formerly punkncat)
Quoted: 2208 Post(s)
Liked 960 Times
Supplements
When I first started riding, I was in weight loss mode, and took off well over 40 lbs within a few months. I noted that since I wasn't eating right, I was eating to loose weight, not to provide energy, that about 10 miles into a ride, I would just crash. I began to eat better, and saw a pretty immediate difference in my energy levels, but still seemed to be lacking. On the suggestion of a friend, I started taking a protein based supplement, as well as various vitamins that were suggested both by a member here (salts) as well as an energy blend that was recommended by the health store.
I have noticed a tremendous increase in my energy and strength. The muscleature on my injured leg has increased significantly over the past couple of weeks, and I can feel a nice power gain from it. I have also noted that I am putting on weight again. I am pretty certain that comes more from reduced riding. The weather has been pretty crappy the past two weeks. Muscle also weighs more than fat, so it just goes to follow that as I get stronger I will come to a point to gain weight.
All in all, and to get to the point.....do any of you others take any manner of supplements as an aid to your "workout"? If so, what are you taking? Should I be looking at supplements with creatine, protein, ect.? At what point, taking these, will the weight gain from them (the protein in particular) outweigh the advantage in accelerated muscle build?
SLO-1
Bikes: '09 BMC Road Racer SL01
i just take protein but thats mostly from habit from my weight lifting days. i've also noticed that recently i'm getting leaner but weighing more. i think its muscle mass as well.
Always take a good quality multivitamin and a good quality protein consisting of protein concentrates and/or protein isolates. Don't believe the saying that "protein is protein" because it's just not true. Some proteins are filtered down more than others, some get absorbed into the body faster than others and some get used by the body more efficiently. Like casein protein, it's low quality, absorbs very slowly (which is why the more serious lifters take it at night). Also, on a good quality protein you will not gain sloppy weight, the opposite is true. You can lean out on protein because the body will burn more calories trying to break it down than is actually in it. Also, it will make you feel full, almost acting as an appetite supressant. Now the vitamins. I don't care if you take Flintstones chewables, it's better than nothing. As you're riding or working out your body is using the vitamins and minerals as fuel and they need to be replenished so it doesn't start eating itself. Good luck.
Jon
Jon
Putting weight on? It's likely that the weight is fat and not muscle. It takes tons of work and calories to add muscle weight.
You won't gain weight simply from taking a protein supplement. I would just use this as an aid in muscle recovery.
I use Gaspari Nutrition's MyoFusion. Tastes really good to. I used to take WaxyMaize as a carb, but found it to do nothing but make me gain weight.
There's no secret to this stuff and people waste so much money on it.
I eat carbide.
Bikes: Lots. Van Dessel and Squid Dealer
Quoted: 1326 Post(s)
Liked 1,307 Times
I use some offerings from Hammer Nutrition. Everything I have used has worked well for me. Mainly I use their Daily Insurance Caps as a multi-vit. Also - PSA Caps, Endurolytes, etc
PSIMET Wheels, PSIMET Racing, PSIMET Neutral Race Support, and 11 Jackson Coffee
Podcast - YouTube Channel
Video about PSIMET Wheels
Liked 960 Times
Nick,
I would have to go look at the bag to be certain, but something along the lines of wheybolic 60 from GNC. In addition I am taking an energy/recovery pre-post workout blend. Once again I would have to look at the package to be sure what the name was, but it is various Vitamin B, creatine, antioxidents, etc. I also take calcium, magnesium, potassium, and a multivitamin (which doesn't contain enough of the salts).
You are likely right, that I am picking up fat. About two weeks ago I changed my eating habits a bit and the weather has been pretty crappy the past couple of days. As far as the energy increase, it very well may be a placebo effect, I think it's working, and it is, but the increased muscle build is very noticable. Your mention of the creatine causing the muscle to hold water would account for that I suppose?
Bikes: 2009 Cannondale CAAD9-6 2014 Trek Domaine 5.9
A good whole food multivitamin is a good base. Add two tablespoons of cod liver oil, digestive enzimes and pro biotics and thats your foundation. the digestive enzymes help your body better use the food you consume. The pro biotics replace the good bacteria in your digestive tract. During a ride you'll need something lke Psimet said above, and after the workout you have about an hour to replace what your body has just used up, so a good quality lean protien, low glycemic carbohydrate, and some of the good, healthy fats (the Omega 3, 6, 9) would be the best balanced meal. Example: fish, salad, serving of fruit or fruit smoothie.
If you don't take in some fuel when you ride, you will bonk out. So pick a hammer product, cytomax, or something else like that. Plain water is good for hydration, but it won't replace what you are using up during the ride. Amounts vary per individual and body weight as to how much fluid you should consume per hour on a ride.
And, don't forget sleep. Your body must rest in order to recover properly. That means good quality sleep each night. Perhaps a Co-Q 10 before bed too. Your body rebulds cells each day, and cells die every day. The new cells can only be made out of what you put in your body, so put crap in, get crap. You really are what you eat.
Just my opinions, which are parroting opinions of Doctors and cycling coaches. To each his own.
Fly on the wall
Bikes: a few
Hmm nobody has spoken for it yet, so I guess I'll chime in.
I'm a believer in the whole foods diet (not the store, but I like that place too). Its the philosophy of cooking your own food and learning where you body gets its fuel from (calcium, potassium, good fats, carbs, etc...). One of my favorite post run/ride snacks is a glass of chocolate milk and a banana. Personally, I feel that people underrate how helpful a wholesome mostly from scratch diet can be.
Before I get flamed, I should point out that I don't have a problem with all these work out foods, supplements, and pills, I just think they are overrated. Imo, the majority of people would better benefit from a natural diet.
p.s. I use the span of cliff products as needed on long hauls. Cliff gels for runs over 13 mi, random fruit and cliff bars (I suppose I should try shots too) for longer rides.
Should Be More Popular
Quoted: 22724 Post(s)
Liked 9,090 Times
IMO the majority of supplements are designed to lighten the buyer by lightening his/her wallet.
Just eat a well balanced diet.
For on-the-bike nutrition there are many options, just be sure to stay hydrated and replace some electrolytes especially on rides longer than 2-3 hours.
SLO-1
I do take a multi-vitamin and some protein post workout
IMO post workout is he most important time to get a good protein source and Whey is one of the more fast acting proteins I know of
I'm hypertensive so I take:
-Chromium Picolinate 400mg
-Vitamin E 400IU
-Vitamin C 1000mg
-Niacin 500mg
-L-Arginine 500mg
-Fish oil/Omega 3 2000mg
-Multivitamin w/ plant sterols
-Calcium 600mg + D
-Vitamin E 400IU
-Vitamin C 1000mg
-Niacin 500mg
-L-Arginine 500mg
-Calcium 600mg + D
Liked 9,090 Times
Just because it's a "vitamin" and "natural" does not mean it's all good.
Just sayin'.
Cat 6
Quoted: 500 Post(s)
Liked 184 Times
If you're old with bad knees like me (mostly caused from prior extra poundage), MSM and Gelatin are helpful. My knees used to lock up. Now I have no issues.
72 Frejus (for sale), Holdsworth Record (for sale), special CNC & Gitane Interclub / 74 Italvega NR (for sale) / c80 French / 82 Raleigh Intl MkII f&f (for sale)/ 83 Trek 620 (for sale)/ 84 Bruce Gordon Chinook (for sale)/ 85 Ron Cooper / 87 Centurion IM MV (for sale) / 03 Casati Dardo / 08 BF IRO / 09 Dogma FPX / 09 Giant TCX0 / 10 Vassago Fisticuff
well hello there
Quoted: 503 Post(s)
Liked 339 Times
I personally have not noticed any difference that a general multi vitamin makes in any aspect of cycling.
Liked 9,090 Times
If you eat a balanced diet, you probably don't "need" any supplement for cycling.
If you have arthritis, glucosamine and maybe MSM are reasonable to try.
If you have mutiple risk factors for heart disease or stroke, taking an aspirin daily is a good idea....but this has nothing to do with cycling anyway.
ボケ
Bikes: Cannondale CAAD 9
I drink a smoothie with Savas "Weight Down" soy protein after a ride. I probably get enough carbs (really ought to check properly one day), but I don't get nearly enough protein in my diet. Seems to be working for (or at least not hurting) me - I'm getting faster and losing weight.
I eat carbide.
Liked 1,307 Times
I'm getting fatter and not losing weight.
SLO-1
when i started cycling i started getting sick all the time. always had a runny nose, stuffy nose, fevers about twice a month. i started taking a multivitamin and i stopped getting sick. i hadn't been sick for probably 5 years prior to cycling and haven't been sick in about 4 months now. it might be a fluke but i'm going to keep taking the vitamins.
Liked 9,090 Times
Bikes: Rawlings Drakkar, Specialized Roubaix, Pivot, Challenge Trike, Tandem
When my friend was diagnosed with rectal and kidney cancer they asked him whether he took vitamins and to stop if he did.
Vitamin use is being discouraged by many doctors. Not sure the link between the vitamins that come in the bottles and cancer is established by many doctors seem to think so.
That includes the orthopedic doctor I go to.
Liked 9,090 Times
^^ only one I know of with good science is that a study in smokers showed that taking beta-carotene INCREASED the risk of lung cancer.
Fly on the wall
Bikes: a few
Buy The Joy of Cooking, its pretty much the Cyclist's Bible for the kitchen!
--> I'd say around half of the stuff in there is simple enough. One of the trickier skills is browning stuff on the stovetop, because success is very dependent on your heat. Baking or "one pot wonders" are a good starting point.
And... to learn to like new foods, you should introduce them bit by bit into what you eat. E.g. onions. try them raw on chili, cooked with stirfry, caramelized on a burger, fried in an onion ring, etc... eventually you'll learn to like and even want the the taste in certain foods.
Shameless shill I know, but I'm all about promoting food diversity.
stevelewis
Training & Nutrition
20
03-12-16 12:53 PM
breadbin
16
10-15-14 10:33 AM
