Go Back  Bike Forums > Bike Forums > Training & Nutrition
Speed converted to Watts
Training & Nutrition Learn how to develop a training schedule that's good for you. What should you eat and drink on your ride? Learn everything you need to know about training and nutrition here.
Old 02-23-10, 02:25 PM
Cyclist75354986865
Quoted: 45 Post(s)
I have a Kurt Kinetic trainer that I use for most of my interval training. I don't have the funds for a power meter but I noticed they have a power computer which convert speed to watts. I've know watts are more accurate than heart rate because the heart doesn't give immediate feed back. The pdf file they show on the site has hugh jumps in watts from one speed to another. So my question is if anyone is using this or something like it in their training?
Cyclist75354986865 is offline
Old 02-23-10, 03:06 PM
Al Bundy
Quoted: 10 Post(s)
Liked 4 Times in 4 Posts
In principle something like a kurt kinetic or cycleops - basically one of the better trainers has a fixed relationship between speed and power. Allegedly these units are reproducible enough that they use a basic equation and its good for all units. However, a better idea, and one of which I am particularly fond, would be to get some friendly racer with a power meter and ask him to calibrate it for you. I've been thinking of doing it, but havent had the spare time to pursue it.
If you put a speed sensor on his back wheel and just take a note of the speed versus the power reading, then you can make an easy look up table or curve on a chart. Wait till the trainer is warmed up as the fluid trainers seem to change a bit at first.
then all you need is a speed sensor on your back wheel and you can easily do direct power measurements.
Al Bundy is offline
Old 02-23-10, 06:36 PM
tadawdy
Faster than yesterday
Calibrating it with a friend's powertap is a good idea. I've seen others here remark that the KK equation is within +/- 3% or so, but not a bad idea to confirm if possible. I'm not so worried; speed here should be constant after the unit is warm, unlike the road. So higher speed means higher power.
As for the large jumps in power from one speed to another, that's the way power works. It isn't linear. If you look at the KK equation, you'll see that it has exponents. These are a little steep at higher powers, though.
The general equation for air resistance is: 0.5 * air density* drag coefficient* cross-sectional area* (velocity squared). That velocity-squared term is the one that'll change the most on the road.
Basically when you're training to get faster, you have to increase your power by a lot to go just a bit faster. To increase your speed by, say 5% (20 to 21 mph), you have to increase power by about 10%...to get to 23 mph (15% increase), it's about a third.
200 17.6 225 18.6 250 19.6 275 20.4 300 21.3 325 22 350 22.7 375 23.4 400 24.1 425 24.7 450 25.3 475 25.8 500 26.4 525 26.9 550 27.4
I used Excel and the KK equation to make a little power chart, to give me a rough idea of what I'm doing (Watts vs. mph). This also illustrates how steep the resistance gets at higher levels. I couldn't find the numbers that KK uses for the rider weight, etc (i know the slope is 0.1), but analytic cycling puts 500 W at about 30 mph. They do seem to diverge. Not that you'll probably be spending that much time at 500 W, but the power needed here is probably higher than on the road.
tadawdy is offline
Old 02-24-10, 02:54 PM
Cyclist75354986865
Quoted: 45 Post(s)
Thanks for the info, extremely helpful. The only thing I see hard about it is staying in an exact speed/watts range for training intervals.
Old 03-01-10, 12:55 PM
hshearer
hshearer's Avatar
If you stay in the same gear and maintain your cadence, that's a steady effort. By knowing your gear ratio and cadence, you can calculate your speed (see the Holy Texts: https://www.sheldonbrown.com/gears/). By knowing your speed, you can use Kurt's formula to calculate your watts.
Even if you don't have a cadence meter, you can just count from time to time with a watch during your longer intervals. It's not a bad idea to develop a feel for a steady cadence.
hshearer is offline
RyanArf
Road Cycling
18
06-05-14 08:31 PM
TexMac
Road Cycling
22
04-30-14 03:14 AM
simonaway427
3
01-03-14 07:51 AM
cappuccino911
3
10-17-10 07:10 AM
Gav888
45
01-30-10 12:26 AM
