23c Tire for Skidding
Hella Raw
Anyone have anyone suggestions for a 700x23 rear tire that lasts as long as my 28 rando?
Hella Raw
Comanche Racing
Bikes: Presto NJS build, Specialized Allez Pro w/ full Dura Ace and Ksyrium SLs, 1990something Specialized Sirrus
the best skidding tire i have used is panaracer t-serv messenger. i donno if it comes in 23, mine were 25. I got them for free but ended up loving them. lasted a while and actually stopped me pretty well when I skidded...
Bikes: Surly Steamroller, Schwinn Continental II
the less contact, width wise, your rear wheel has with the ground the more force there will be on the point of contact. This is why you inflate 20/23X700C tires to higher pressures than 700X28C tires. A 700X20C will wear a whole lot faster than a 700X38C. I doubt you'll find a 23 that lasts as long as a 28.
Hella Raw
Tarck bike dot com
Bikes: Fuji tarck '08
I mean the sidewalls will stand up if you keep your pressure up and on the wearing it just gets stupid when it's absolutely squaaare
Riding Engineer
Bikes: Kiyo Kiyo Kiyo
You might not like the Pana-T-serv's tread patterns. I think those were identical to Pasera. And, that tread pattern flips up sharp-fragments so they go "vertical" on the tire for some people. ...
The bus, Gus
death from your left
Bikes: scott CR1 rase rig, special__ed langster commuter masheen
those panaracer tires are both boat anchors at 310g each
