Am I gonna die tragically young?
Old 05-14-10, 03:21 PM
Brimstone
Or will I ripe and ripe then rot and rot?
Considering options for the top end of a brand-spankin'-new MuXl Sport '08:
Option 1. $32 Aber Hallo! + $55 Ergon GC3
https://www.thorusa.com/dahon/technical/aberhallo.htm
https://www.amazon.com/ERGON-GRIPS-FU...869143&sr=1-15
Option 2. $32 Aber Hallo! + stock Ergon grips + $40 Ergon GC3 bar ends
https://www.ergon-bike.com/us/en/shop...ry/spare-parts
Option 3. stock bar + stock Ergon grips + $15 Titec L-bends + $6 Lizard skins
https://www.pricepoint.com/detail/140...-End-Grips.htm
https://www.amazon.com/Titec-L-bends/...3869926&sr=1-1
Option 4. $32 Aber Hallo! + stock Ergon grips + $20 Origin-8 Bullhorn bar sawed in half + $6 Lizard skins
https://www.amazon.com/Origin-8-Bullh...3870478&sr=1-6
Yes, bullhorn cut in two at the midpoint. Each half locked in place by the Aber Hallo!.
Pros:
- Could leave a space for the Aber Hallo! QR lever between the halves allowing tight quick fold
- Could easily mount stock grips, grips shift and brake levers
- Could separate bar halves for easier suitcase packing
- It's rad
Cons:
- Potential early death
Maybe to strengthen the cut I could put grip lockrings and/or barend plugs on either side of it.
Anybody done this (and lived to tell a tale)?
Side question: Should I pay to have a documented preride mechanic check and active the Dahon "lifetime frame warranty"? I can tighten my own spokes.
Brimstone is offline
Old 05-14-10, 04:02 PM
SesameCrunch
Eschew Obfuscation
SesameCrunch's Avatar
Bikes: 2005 Fuji Professional, 2002 Lemond Zurich, Folders - Strida, Merc, Dahon, Downtube, Recumbent folder
I think it's OK to cut the bar in half, but use a "sleeve" in addition to the Aber Hallo to join the mid section. Good idea!
SesameCrunch is offline
Old 05-15-10, 01:05 AM
snafu21
snafu21's Avatar
Bikes: None.
My only 3 euros worth is that space down by the hub with the bike folded might be very tight. (Although I don't have a Mu to check.) Swapping out the stock flat bars on my D7 for riser bars hampers the fold. Even having the bike computer in the wrong place stops the magnets locking.
snafu21 is offline
Old 05-15-10, 09:06 AM
invisiblehand
Part-time epistemologist
invisiblehand's Avatar
Bikes: Jamis Nova, Bike Friday triplet, Bike Friday NWT, STRIDA, Austro Daimler Vent Noir, Hollands Tourer
Quoted: 122 Post(s)
Liked 3 Times in 3 Posts
I don't think that you can keep the split bars level with a single brace. You need an inner sleeve to make it work. This is what Bike FRiday does. Mind you, there is an additional problem regarding the inner diameter of the bar at the mounting point. If you really want to go with the split bars, I would just pick up one from Bike Friday. They will also split a bar if you send them one. Although they probably cannot guarantee that the inner diameter will match their sleeves.
Alternatively, if you can find an outer sleeve with the correct inner diameter -- 26.0 or 25.4 mm -- then it might work too.
A narrative on bicycle driving.
invisiblehand is offline
Old 05-16-10, 07:41 PM
Foldable Two
Foldable Two's Avatar
Location: Vancouver, Washington and Ocean Shores, Washington, USA
Bikes: 2 - 2007 Custom Bike Fridays, 2 - 2009 Bike Friday Pocket 8's, Gravity 29'er SS, 2 - 8-spd Windsor City Bikes, 1973 Raleigh 20 & a 1964 Schwinn Tiger
In any event, keep riding - you'll live longer. That's my opinion. :>)
Foldable Two is offline
DLBroox
Folding Bikes
24
04-15-18 10:35 AM
Eric91Z
Hybrid Bicycles
13
03-19-18 09:19 AM
Atakuweh
Hybrid Bicycles
20
08-01-16 08:27 AM
knightblaze
Hybrid Bicycles
5
06-03-15 10:39 AM
kamtsa
Bicycle Mechanics
2
12-23-09 12:49 PM
