Best Beginner Clipless Pedals
Hey all, quick question. I am a beginner, mainly touring for fitness. I have a '87 specialized sirrus and love it. The only issue is that I am sporting basic platform pedals with toe clips and straps and really don't care for it much. It is so cumbersome getting into and out of them, and I am embarassed to say I have found myself on the ground in front of a crowd on two separate occasions.
My question is, what clipless pedal system is the best value. I am not looking to break the bank nor am I a competitive racer. I am looking to spend $100 +/- 25 (keeping in mind I still have to buy shoes).
Thanks!
Thanks!
Bikes: Surly Cross-Check, '85 Giant road bike (unrecogizable fixed-gear conversion
https://mikesbikes.com/product/shiman...6490-qc129.htm
You can probably find them cheaper than $60. Wellgo also makes some dual sided clipless, for less but I think the Shimanos's work a bit better and are a little nicer.
What you want are dual sided SPD and keep the tension loose. Stick with mtb shoes since you can walk in them much easier than road shoes.
BTW, if these are "beginner" pedals then I must still be learning after using them for almost six years.
Also, I used to fall all the time with clips and straps, but the only time I've fallen with clipless was the result of failed trackstands on my fixed gear.
Look Keo Easy and Shimano R540 are both available around $40 or so from the various online UK dealers. Either will work just fine for you. There's nothing "entry level" or "beginner" about pedals that cost more than $100.
Fixed-gear roadie
Bikes: 2008 Masi Speciale Fixed
I got a great deal on my 105s, with shoes the whole setup came in around $150. They're my first clipless pedals, I'm really happy with them.
Delusional Laserbrain
Bikes: 2008 Specialized Tricross, 1993 Giant Iguana rebuild w/ singlespeed drive train
I love eggbeater pedals. They are simple to get in and out of and look cool.
This is the Candy 3 (which used to be called the Candy SL) but there are other models too. And each model is offered at several price/ quality levels.
Candy 1 is $60
Candy 2 is $90
Candy 3 is $120
Candy 11 is $375
Candy 1 is $60
Candy 2 is $90
Candy 3 is $120
Candy 11 is $375
My first pedals were Crank Brothers Quattro. They were easy to get in and out of. Next ones were look style pedals. They're even easier.
I wouldn't worry about getting anything that is specifically made to have low tension. You'll get used to pedals in no time.
I would think about what kind of cycling you want to do long term, get the appropriate style of pedals and shoes, and get used to them. If you start on one type and then switch later on you'll just have to go through the learning process twice.
The main road systems are Look and Shimano SPD-SL. They are similar in design but not compatible. They both give you a very stable platform and efficient power transfer but the cleats protrude from the shoes and make them hard to walk in. Nobody else make the shimano style but there are several cheaper Look knockoffs like Exustar and Nashbar.
Shimano SPD is the most popular mountain/touring/spin class/etc. type pedal. They are nice because the small cleats can be completely recessed into the shoe for easy walking and many pedals are 2 sided so you can always step in without having to flip the pedal. Downsides are that the small cleats can be tricky to lock in and depending on pedal and shoe design not give as much stability or support as road pedals. SPD pedals are made by Shimano and just about everyone else so there are about a billion different designs.
Time, Crank Bros, and Speedplay all make pedals with proprietary cleat systems, but I have never tried them so I will let others point out their pros and cons.
From what you describe of your current riding, the Shimano A520 sounds like the best fit.
Good luck.
Good luck.
Bikes: 08 Gaint TCR Advanced, 87 Specialized Sirrus, 07 G Fisher HiFi, 05 G Fisher Tass
Thanks!
Thanks!
Upgrading my engine
https://www.performancebike.com/bikes...8#ReviewHeader
Cheap and easy. Call me crazy, but I think the LOOK-type pedals are easier to clip in to than the SPD-SLs.
forget the concept of beginner clipless pedals. think about the type of system you want long term and buy it now. then you dont have to buy twice when you think you're ready for the next level.
the biggest decision for you is mountain style or road style, which will dictate what shoes you buy and whether or not you'll be able to walk in the shoes.
I always thought the main road system was Speedplay. Ask several different people, you always seem to get several different answers I suppose!
I agree that Shimano SPD's seem to be a good beginner pedal as well. I'd definitely prefer the "mountain" style pedal as you can walk around in them normally. They're very popular, and they let you adjust the release tension.
I'm not a big fan of the Crankbrothers, whether Eggbeaters or anything else. They're ok, but they have a reputation for being unreliable (though they just came out with new versions that are supposed to be more reliable). I found personally that they leaked grease all over the spindle...seemed to be a regular thing with the pedals, not a manufacturing defect, and it's something that didn't really happen with my other pedals.
I like my Time (ATAC) Control Z's. All the "ATAC"'s are compatible with each other. No weird oil leaking out of them (yet at least), they seem sturdy, good float...like them.
When people ask me which pedals to get, I recommend either the Shimano SPD's or one of the Time ATAC's.
There's no "I" in "win"
Bikes: 2008 CAAD9 R6
i wouldn't suggest the Look Keo Easy, i have them and i personally feel like they were a mistake. granted they were good to get me used to clipless but it already time to change them, their not adjustable. its become a problem because now that im used to clipless i want something that holds me in tighter.
The Shimano m520s were my first clipless pedals, and I've since put thousands of miles on them. I have friends who also like the eggbeater pedals.
Personal preference, I would stick with mountain style pedals (like the m520) over road style (like LOOK pedals), because the cleats are easier to walk in.
