You know what this sound is???
Bikes: Scott SR20
my new bike makes a new noise I've never heard before. It makes a click down near, or in, the crank when I pedal. I took it to the LBS and the guy put some teflon in there which helped when I'm just pedaling around but when I get on it, get out of the saddle, or go up hill, or just apply more pressure it starts to make this click noise again...any clues to what this is or could be?
it always sounds like it's coming from the crank but it could be literally anywhere, handlebars, stem bolts, skewers, axle caps, pedals, bottom bracket
this is why it sometimes takes a long time to find
Still can't climb
you're going to have fun looking for the source, that is unless you go nuts before you find it.
I tool off the crank arm and cleaned and greased it and the clicking disapeared.
coasting, few quotes are worthy of him, and of those, even fewer printable in a family forum......quote 3alarmer
No @coasting, you should stay 100% as you are right now, don't change a thing....quote Heathpack
Liked 9,456 Times
I've had two kinds of clicks in my bottom bracket area in the few months that I've had the bike - both would happen at a specific part of the part of the pedal stroke under a lot of effort, but they sounded a little different.
The duller-sounding clicking was in the BB after water worked its way in on a wet ride. Pulling the BB, cleaning and regreasing made it go away.
The sharper-sounding clicking was the from some loose chainring bolts. Tightening made it go away.
Liked 278 Times
A friend of mine had a clicking noise at one time...we were getting ready to take the bottom bracket apart when he noticed that the cadence sensor and magnet on the arm and chainstay were too close together and hitting each other everytime he pedals.
Bikes: BMC RM01
Funny, the clicking noise I get is from my knee. Happens at the same spot every revolution of the crank. A little oil and I'm good to go. I did have a click on the right side of my crank and it would happen at the same spot , but only when I was putting extra pressure on the pedal. It turned out to be loose chainring bolts. Before I took them all out and cleaned and applied some loctite blue to the threads I thought it was the bottom bracket even though it is relatively new. Little sounds like this are really annoying and awfully difficult to nail down.
Bikes: Bianchi, Miyata, Dahon, Rossin
Liked 5 Times
solution:
![](https://images.appleinsider.com/nano-06-1.gif)
Food for thought: if you aren't dead by 2050, you and your entire family will be within a few years from starvation. Now that is a cruel gift to leave for your offspring. ;)
https://sanfrancisco.ibtimes.com/arti...ger-photos.htm
Bikes: BF Pocket Rocket Pro, Bianchi Infinito CV
I had a similar issue with my rig - intermittent clicking - fairly random, but definitely related to the amount of force applied to the pedals. Eventually I tightened up the hanger bolt on my rear derailleur - problem solved.
HTH
HTH
Bikes: Specialized
Could be a number of things. I'm inclined to scope the pedals first, especially given your repro steps...I've had inexpensive pedals (Forte) have spindle creek/ticks when standing up on them...My Looks, Ritcheys, and Speedplay's never had the noise...Second spot would be the bottom bracket or cranks...from there, it becomes a lot trickier. Since you're saying it happens under load, I don't think it can be too far from the pedal train in general.
Bikes: Cervelo S1, Giant OCR3
Custom User Title
Bikes: 2006 Marin Stelvio, 1990s Steve Bauer, Marin Palisades Trail
I had a nasty little clicking sound a couple years ago.
after a complete frame tear down and rebuild with fresh grease it was still there.
moved onto the hubs, turned out to be a weak pawl spring in the freehub.
the way sounds resound through frames, it's hard to tell where they come from.
Nonsense
Bikes: Affirmative
Liked 541 Times
For what it's worth, I had a click I could have sworn was one day the derailleur, one day the BB, and another the pedals. I took off the pedals tonight and lubed the bearings and threads. No more clicking! SO pleased.
In addition to other good comments, it's very typical sound associated with cog not being tight enough. Could also be something as simple as the cable tip "clicking" on your frame as you pedal. Easiest potential fix - check cable tip location and make sure they are not coming in contact with frame.
