crank pin for Peugeot
Bikes: Peugeot, Raleigh
My local bike shop is trying but to no avail in locating a 7.5 crank pin for my Peugeot. He also mentioned a 8.0 and a 8.5 Anyone know where I can locate one for puchase? Thanks in advance
What??? Only 2 wheels?
Quoted: 1225 Post(s)
Liked 658 Times
7.5? As in 7.5mm diameter? Which Peugeot uses that? The Nervar crank on my UO-8 came with a 9mm.
Have you checked with Harris Cyclery, Newton, MA (https://sheldonbrown.com/harris/)?
Real cyclists use toe clips.
jimmuller
jimmuller
jimmuller, Thanks for the head's up on the Harris Cyclery. Looking at their inventory for crank pins, it seems you are correct. I'm gonna bring this to my bike shop guy's attention. He trying to help me get this bike on the road. Again thanks and I'll let you know how it turns out, julesray
Liked 658 Times
When you do find the right size, make sure the lbs guy knows how to put them in. DO NOT try to tighten them by tightening the nut. That will strip the threads. Hammering works if you support the crank underneath so you aren't hammering onto the bearings. A press is the best way to tighten them. Then you can put the nut on to act as a retainer.
jimmuller
jimmuller
Don't mean to hijack this thread but the Harris website shows they have French and Swiss BB cups in stock. Yowser!
Novist senior member
I'm upgrading a peugeot to cotterless. im me if yo want the pins from the old crank.
I received the crank pin from Harris cyclery and brought to my lbs. I got the bicycle back last Thursday............It rides Great.....I rode N.Y.C. on Saturday and Sunday.........What a joy to be back on a classic bicycle. Thanks for all the replys....................ride hard...with joy
Liked 658 Times
Check the pins again. They have been known to loosen up.
jimmuller
jimmuller
I take the S.I. ferry and ride either the west side or east side. Go over the Williamsburg bridge, ride around a little........back to N.Y.CV. Central Park........back down to the ferry. The bicycle continues to ride smooth as silk............What should I look for? Feel for? ......Thanks for the advice
Liked 658 Times
With regards the cotter pins loosening up? Oh, just put a wrench (10mm, I think) on the nut and see if it has loosened. Don't over-tighten it, because the nut isn't meant to tighten it, only to keep it from coming out. After a ride or two it should stop loosening if it is loosening at all. But you don't want to ride with it loose. That will deform the pin and it will never sit right again, which means you'll need to file it flat very carefully(!) and very little or get another. You be able to tell if it has a problem because the crank arm will move on the spindle as the pedal goes over the top. If the bike shop installed it right you shouldn't have a problem, but it is good to check it when it is new.
Enjoy the bike!
Enjoy the bike!
jimmuller
jimmuller
wclarkin
6
05-05-17 01:36 AM
Michael Shaw
4
10-29-10 03:22 PM
