strength of those rear cargo platforms?
crunchy phascist
so,i've seen alot of pictures from europe of people hitching a ride on a bike sitting sideways on the rear cargo platform... legs off one side.
after alot of searching, i find that few actually advertise a weight rating and the ones that do
fall short of the average person.
since the consequences of this failing seem exceedingly grim considering the locations of the support bars.... can anyone give a recommendation of a cargo platform that they might feel comfortable riding on, or have experience with passengers on?
im not actually planning to haul a person necessarily... but if it will do that.. it will do whatever I need it to without a chance of loosing my groceries in a pothole in the street.
thanks!
thanks!
Bike Pilot
Bikes: Oh, yes
I have found that most rear racks are fully capable of carrying a full grown person (sidesaddle is definitely best; most comfortable, easiest to get on/off, easiest to balance). The european ones tend to be more overbuilt than the ones we commonly get in the US, but the actual rated capacity of racks in the US is usually determined by lawyers, rather than by mechanical testing of the racks. It tends to have more to do with the amount of weight that the company feels most riders can handle without getting in trouble than with the amount of weight that will cause the rack to fail. Some racks are, of course, much stronger than others, but most of them are strong enough for anything you are likely to want to haul. Get the best one you can afford, and have fun!
The Drive Side is Within
My Madsen is rated for 500 lbs. "kg271" is molded into the side of the bucket. The rack version is probably capable of carrying even more. I think in the madsen's case, the 20" rear wheel adds to the overall strength of the bike.
The bicycle, the bicycle surely, should always be the vehicle of novelists and poets. Christopher Morley
Dutch Opa and Oma bikes have racks that handle that , heavy duty bikes, nice flat country, outside of Masstricht.
https://clevercycles.com/products/bic.../workcycles/#_
Gear Hub fan
Bikes: Civia Hyland Rohloff, Swobo Dixon, Colnago, Univega
Neither is a weight that I would like to try to balance on a bicycle personally, particularly while mounting or dismounting.
Gear Hubs Owned: Rohloff disc brake, SRAM iM9 disc brake, SRAM P5 freewheel, Sachs Torpedo 3 speed freewheel, NuVinci CVT, Shimano Alfine SG S-501, Sturmey Archer S5-2 Alloy. Other: 83 Colnago Super Record, Univega Via De Oro
Visit and join the Yahoo Geared Hub Bikes group for support and links.
https://groups.yahoo.com/group/Geared_hub_bikes/
![lol](images/smilies/lol.gif)
My preferred bicycle brand is.......WORKSMAN CYCLES
I dislike clipless pedals on any city bike since I feel they are unsafe.
Originally Posted by krazygluon
Steel: nearly a thousand years of metallurgical development
Aluminum: barely a hundred, which one would you rather have under your butt at 30mph?
Bikes: Trek 4300
On the racks I have seen, like the one on my bike, they are held on by two screws down by the wheel, one on each side. Are those two screws really able to support a couple HUNDRED pounds? It seem like they are the weak point of this setup.
