Question for the Sturmey Archer Gurus: can I convert a 4-sp to a 3-sp?
multimodal commuter
Quoted: 1908 Post(s)
Liked 574 Times
Okay, I don't know how to do it, but I know you can convert a four speed hub such as an FW (wide-range four speed hub) or the FG (wide range four speed hub with dynamo) to a five speed like an S5.
I know the advantage of the four - speed hub is that it works with one shifter, but the disadvantage is that that shifter is getting hard to find and wears out prematurely. I also know the disadvantage of the five speed hub is that it requires two shifters and may require parts, such as a bell crank, that are hard to find.
So, my question, is can you take a four speed hub and convert it to an ultra-wide range three speed hub? So you'd end up with a hub that has the 1, 3 and 5 gears of the five speed hub, but needs only one shifter-- the garden variety three-speed trigger?
Don't tell me I wouldn't like that, because the gears would be too widely spaced. This may be true; but that's not what I'm asking. I only want to know if it's possible. If it is possible, I'd probably run that hub with two cogs, spaced 4 teeth apart, so I'd have an ultra-wide range six-speed system.
So, esteemed Sturmey Archer gurus... what do you think?
Location: Rhode Island (an obscure suburb of Connecticut)
Bikes: one of each
Quoted: 8 Post(s)
Liked 12 Times
If you've got a 4 speed shifter, measure the clicks, then measure again on a 3 speed shifter, or I'll measure mine and we can compare.
Wrench Savant
Easy way: Block-out the shifting rod through the axle
Harder way: Get a three-speed shifter so you are only using 3 speeds (your choice, upper or lower 3)
Hardest way: pull the hub apart and monkey around...maybe take out one set of planetary gears perhaps.
Not sure it is worth the trouble.
Palmer
Quoted: 1699 Post(s)
Liked 1,870 Times
Palmer
Liked 1,870 Times
multimodal commuter
Liked 574 Times
If I first do a complete teardown and rebuild of an AW, then of an FW, and maybe also of an S-5, will I learn what I need to do this conversion?
Palmer
Liked 1,870 Times
I can't think of a reason it couldn't be done, which is not quite the same thing!
Here's the theory.
Here's the theory.
SE Wis
Quoted: 2752 Post(s)
Liked 3,412 Times
You've probably already found this.
https://www.users.globalnet.co.uk/~ha...samaintind.htm
I'm under the impression that s5/2 guts fit in an AW shell.
Membership Not Required
Bikes: Giant Excursion, Raleigh Sports, Raleigh R.S.W. Compact, Motobecane? and about 20 more! OMG
Quoted: 70 Post(s)
Liked 15 Times
From what I gather the conversion from 4 to 5 speed is very straight forward and you can use a Shimano 3 speed bell crank assembly on the left side. Shoot an email to Mark Stonich at BikeSmith Design, if he can't come up with an answer no one can.
Edit: I would want more gears and range not less...
Aaron
Aaron
Webshots is bailing out, if you find any of my posts with corrupt picture files and want to see them corrected please let me know. :(
ISO: A late 1980's Giant Iguana MTB frameset (or complete bike) 23" Red with yellow graphics.
"Cycling should be a way of life, not a hobby.
RIDE, YOU FOOL, RIDE!"_Nicodemus
"Steel: nearly a thousand years of metallurgical development
Aluminum: barely a hundred
Which one would you rather have under your butt at 30mph?"_krazygluon
1991 PBP Anciens
Bikes: 1954 Robin Hood, 1964 Dunelt, 1968 Raleigh Superbe, 1969 Robin Hood, 197? Gitane, 1973 Raleigh SuperCourse, 1981 Miyata 710, 1990 Miyata 600GT, 2007 Rivendell Bleriot
Quoted: 74 Post(s)
Liked 350 Times
I've converted an FW to a fixed gear 3 speed and it was fairly straight forward but ended up with a narrow range hub. I've discussed what you are thinking with Mark Stonich a couple years ago but as I'm suffering from Old Timers at the moment I can't recall how it went. But as Aaron said, if mark can't come up with it, no one can.
stefanpandele
Bicycle Mechanics
0
03-16-14 02:04 PM
Ivandarken
Classic & Vintage
1
05-08-10 06:32 PM
