Anybody use the protype sugino 75 BB?
THE STUFFED
Bikes: R. Sachs Road; EAI Bareknuckle; S-Works Enduro
Liked 20 Times
Anyone here? I'm talking about the one that goes for only $35 at ben's. More specially I want some information about it's durability on the long run compared to the loose ball one's from sugino. My friend has one but he just has a bike to have one. I'm thinking of choosing a cartridge BB because the bike its going on is going to be exposed to the elements. If you ask, why 75's on a bike you're going to beat around campus on? I just recently got my 4th and cheapest set of 75's, ever.
THE STUFFED
Liked 20 Times
And this isn't your typical beater, it's another coghouse 727TR, my 1st one which is a tad bit small for my liking.
Bikes: 91 bridgestone rb-2, Univega viva sport, 04 masi Nouva Strada,Dave Scott Ironman, Changes like every month
75s will "work" on any number of sealed bbs. But if you've owned 4 sets you probably already know that. The particular bb you're talking about is the 103 mm model made for the rd cranks. It may place the crank too close to or contacting your frame, especially with your apparently heavily worn cranks (especially if the part that interfaces with the axle is worn). I used a shimano 110 for a while, worked OK. Now I use a campy Mirage, which is a surprisingly much better bb. Cheap cartridge bbs are just that, cheap.
They are never really that smooth to begin with and they never get much better. That said if you're not riding in truly crappy, salty conditions they are serviceable for quite some time.
Can we end this thread now?
THE STUFFED
Liked 20 Times
I don't know but I think I might actually give that BB a try.... my other 3 sets are mated to 75 BB's, including 1 to a superlap on my pcept.... on another hand I might just have a friend remove the 75 BB from cdale track I have as a table ornament back home and mail it to me here.
prototype 75? Can you help show a picture? I know that theres a Sugino sealed cartridge bb for around $35-45, meant more for their messenger crankiest. Then there's the Sugino 75 looseball bb meant specifically for Sugino 75 crank arms. The tapers are different.
Veteran Racer
Bikes: 32 frames + 80 wheels
Liked 767 Times
https://www.benscycle.net/index.php?m...oducts_id=9460
Comanche Racing
Bikes: Presto NJS build, Specialized Allez Pro w/ full Dura Ace and Ksyrium SLs, 1990something Specialized Sirrus
I use a sugino JIS BB on mine. Not my choice...cranks came used w/ my older bike and already had JIS installed, so I guess I have to stick with it now. Works fine, though, and I've put a lot of miles on it. I donno what length it is, but it gives an almost perfect chainline.
TrackMonkey7
Track Cycling: Velodrome Racing and Training Area
8
12-13-13 06:36 PM
