Just picked up a Spin Doctor torque wrench from Performance........thoughts
I read some good/bad reviews, most bad reviews were because there is no explanation of what to look for when you have reached the proper torque. Some say there is no click and the head moves, and if you don't notice it you will continue to tighten, thus catastrophic failure will occur.
I tried it out in the store on one of their bikes. It does have a pretty audible click and the head does move. To make sure you can just go back a few inches, begin to tighten again and it will click again. I understand that it should explain what to look/listen for in the directions, but I don't think it's cause for a bad review.
slow up hills
Bikes: Giant TCR, Redline CX, Ritchey Breakaway, Spec S-works epic
you want advice on something you already bought?
sweet
sweet
blah blah blah
Bikes: too many
If it has some not so great reviews, return it, then take that money and go to Sears and get a Craftsman wrench. If you don’t want to spend too much go the Harbor Freight. I picked one up from there a few years back for my car and it works great.
Bikes: CAAD9-1, Windsor Cliff 29er
There have been a lot of torque wrench threads lately. I'll say it again, Park Tools Beam type torque wrench. There is no doubt as to when you've reached the proper torque.
I have to wonder if these people really ever used a torque wrench that clicks, the heads move on all of them then clicks and releases pressure, they all work that way. I have the feeling that they see the head move and get scared and stop short of the click.
My friend swore his little Richey was tightening more than it was suppose to till I took 2 different torque wrenches and he tested them an discovered nothing was wrong with his.
It may not be fancy but it gets me were I need to go.
https://www.jtgraphics.net/cyclist_bicycles.htm
Bikes: 2010 Mercier Kilo WT, 2011 Specialized Tarmac Pro SL3 Red
This is the reason i use beam type torque wrenches. I have a small one from Park for small jobs like handlebars, brakes, seat collar, stems, etc. and a large Craftsman for the big jobs like cranks, BB, and cassette tightening.
On the Move
Bikes: Lots
Thought: You just paid too much by not getting the same version from Performance's stepchild, Nashbar. But, you also got to try it out in the PBS store and support the brick and mortar shop in the process, so its all good.
There is zero doubt of when the set torque is reached on this wrench.
I just got the big Park beam one (TW2) for crank/bb stuff. Works great and I don't have to worry about calibration or failed clicking or anything else. I have a Ritchey Torque Key for the stem/fork bolts.
Should Be More Popular
Quoted: 22715 Post(s)
Liked 9,080 Times
Tandem Vincitur
Bikes: BMC Pro Machine SLC01, Specialized Globe, Burley Rock 'N Roll tandem, Calfee Dragonfly tandem.
And the one I got from Harbor Freight doesn't work hardly at all.
The one I like and use the most is a Wiha 28554 TorqueVario-S Handle, Newton Meter Scale 2.0- 8.0Nm not cheap but worth every penny, you also want to get these 2 adapters for a full range of uses Wiha 28582 Square Drive Adapter For 1/4-Inch Sockets and Wiha 28581 Bit Holder Adapter For 1/4-Inch Drive Bits.
That said I also have a Nm clicking Torque wrench and a beam type all work great and for even bigger stuff I have a larger 1/4 and 1/2 clickers.
For me the best tool for small apps. Wiha 28554 TorqueVario-S Handle, Newton Meter Scale 2.0- 8.0Nm
All my other torque wrench's which I check calibration every few years
And do set your torque wrench's back to zero when not in use and in storage to keep the calibration from going off with out even using it.
Well i just used my Spin Doctor wrench. And........my bike blew up, I fell and got a concussion, someone stole my car, and my house was repossessed
Seriously though, it seems to have worked great. The click and feel was very noticeable even at 4Nm. I am very pleased. I am going to check it's accuracy with someone else's wrench, if it's off I will just return it. I did set it back to zero before putting it away.
One thing though, my seatpost calls for 5Nm max, some have said that seems low. I did feel low, I did use Finish Line carbon assembly gel to. It creaked for a second when I sat on it, but it didn't slip when I pedaled on my trainer.
It will be fine as long as you used that finish Line carbon past and torque to 5 Nm all is good ride!
