Less expensive carbon fiber water bottle cages?
Anyone have any recommendations for carbon fiber water bottle cages that are less than $45? My LBS only has $45, $50, and $60 carbon fiber water bottle cages and $6.95 alloy cages. I'd like to budget something in the range of $25 or so, but I haven't seen anything at that price point. Anyone have any suggestions? Preferred colors would be black or white.
Bikes: Specialized Roubaix SL3, Lynskey Cooper CX
I bought a pair of Bell carbon cages from WalMart for around $8 each about a year ago. If you want something fancier looking, or a knock-off of one of those $60 cages, look at eBay.... there's a ton on there.
I tried looking on eBay- I did a search for carbon cage or carbon fiber cage, or carbon fiber water bottle, etc, but no luck. Suggested search terms?
Godbotherer
Bikes: 1986 Cannondale SR300 (full SRAM Apex) 1996 Cannondale R800 (Full SRAM Rival), 1997 Cannondale R200 (Shimano Tiagra), 2012 Cannondale CAAD 10-5, 1992 Bridgestone RB-1 (SRAM Force)
Godbotherer
https://shop.ebay.ca/?_from=R40&_trks...All-Categories for ebay.ca
https://shop.ebay.com/?_from=R40&_trk...All-Categories for plain old U S of A
if you can narrow it down to a part number or specific item name that's better and be sure to check the "Include Description" checkbox.
For anyone that doesn't know, another trick is if you want to capture things like 'fiber' versus 'fibre' don't forget you can do fib*.
There's a whole section just for bottles and cages. Sporting Goods > Outdoor Sports > Cycling > Accessories > Water Bottles & Cages. Navigate your way there, then just search for 'carbon'.
Still can't climb
go with plastic. light and secure.
coasting, few quotes are worthy of him, and of those, even fewer printable in a family forum......quote 3alarmer
No @coasting, you should stay 100% as you are right now, don't change a thing....quote Heathpack
Bikes: Giant Defy Advanced 1 (2011), Santa Cruz Superlight (2000), Jamis Coda Comp (2009)
Arundel makes a nylon-reinforced plastic version of it's Dave-O called the Sport Bottle Cage. Looks the same as a CF Dave-O, only 20 grams heavier, but cost only ~$15.
Who is Lance Armstrong?
Bikes: 2018 CAAD 12
I'm not a racer, but I can't see these weighing me down at all compared to their carbon counterparts.
Come on you Spurs!
Bikes: Trek 2.1, BMC Roadracer SL01
I got a couple of them off ebay for around $22, shipping included.
There was a thread about this with links to ebay, not long ago.
Gentlemen.
Bikes: S-Works e5 Aerotech with 2009 Veloce and a Fulcrum 5s
Bikes: '09 Felt F55, '84 Masi Cran Criterium, (2)'86 Schwinn Pelotons, '86 Look Equippe Hinault, '09 Globe Live 3 (dogtaxi), '94 Greg Lemond, '99 GT Pulse Kinesis
Liked 270 Times
I don't understand cf bottle cages at all. The plastic are much more durable & cheap, and if you get black, no one will be able to tell the difference.
Zipp Carbon Cage - 25 grams - $59.95 on Excelsports
Velocity Plastic Cage - 29 grams - $7.91 on Amazon
The weight saving is about the mass of one nickel. The monetary savings is literally more than a thousand times that.
Are any of the carbon cages strong enough to hold larger water bottles? For daily riding over a period of years?
I've had the same plastic cages on my bike for more than 25,000 miles and they still work perfectly.
Godbotherer
I don't get it either. I didn't even KNOW there were carbon cages until I grabbed those Bell jobbies. And at the time I thought they were just some cheap lightweight plastic until I noticed the carbon 'weave' on my way to checkout. Oh well.
If it breaks I have this old Giant branded ABS cage that's probably. . . 20 years old.
Bikes: 2011 Gaint Defy 1, 1997 GT Rebound
I bought two cf bottle cages on eBay for something like $24 a few months ago. It came from China and took about 2 1/2 weeks to arrive. The best part is that it doesn't have a name brand plastered all over it. It's just a plain cf bottle cage and I couldn't be happier.
They're also light as mentioned before, and cost about $20.
They don't have a faux carbon finish though.
From my post here.
I got black cages for my black bike, but I've removed them since I'm experimenting with using CamelBaks instead.
cdr
Note. The recess for the mounting screw head isn't deep so you need to use button-head or truss-head screws. Regular socket-cap screws will interfere with the bottles.
Liked 5,416 Times
I like the rib cages. I've raced on courses so bumpy people were losing bar plugs, breaking saddles, and loosening bars/levers, but I didn't lose bottles out of my rib cages.
From my post here.
cdr
From my post here.
cdr
Steel is real...and comfy.
