Two LBS shops fight over my 29er bike size (I'm 6'3")...
Bikes: 2013 Specialized Tarmac
I am purchasing a 29er but my two local bike shops are telling me two different stories. I am 6'3" with a 35" inseam and Store #1 is telling me to get a 23" while Store #2 is telling me to buy a 21". I will be using this bike for fast/crazy single track in the summer and will use it as my commuter in the winter. Store #1's argument is that if I am commuting on it I want a 23" frame because it will fit perfect and Store #2's argument is that a 23" frame will be too big and sloppy. The problem is that neither have a 23" 29er in stock . The 21" at both stores feels great but for a long commute I have no idea how much I will love or hate the smaller bike.
Suggestions? Ideas? Opinions?
I'm new to MTBing, but I say go with the smaller frame. You can always throw a higher rise stem on it and a seat post that will put you high and a little further from the bars. To me, a better ride in a higher risk situation is more important, and more fun while MTBing is more important. This is assuming that you aren't going to be tackling the single-track during the winter while you have the commuter stem and post on it. And those quick small things won't be a big deal to swap once in six months when the season changes and the use of the bike changes.
The Left Coast, USA
I bought and built a couple of 29ers. My personal preference is smaller for a 29er, a least one size down. Sloppy is exactly right, a big 29er frame is like navigating a boat.
Bikes: 13' Ragley Marley, 12' Pivot Firebird, 13' Pivot Point, 89' Bridgestone RB-1
21" definitely. At 6'4" I have a hardtail with 22" and a fs thats a 21". The 21" feels perfect. I have really long arms and i still feel a little stretched on the 22" frame. 23" I think would just be way to big IMO.
Single-serving poster
For commuting a 21" will be nicer, you don't want to be stretched out and aggressive. If you can keep your spine straight, neck not too craned and don't feel like you're digging for clams with your hands when you're on the 21" then it's probably an ok fit.
2 Fat 2 Furious
Bikes: 2009 Specialized Rockhopper Comp Disc, 2009 Specialized Tricross Sport RIP
The 21" is a little small for me in a few ways but I'm glad I don't have the worry of how high my voice will go if I do jump off the bike.
cowboy, steel horse, etc
Bikes: everywhere
Liked 8,021 Times
Fred at large
You CANNOT fit a bike by seat tube length. A bike is fitted to you by TOP tube length.
For your size I'd say that you need to start with a top tube of around 22 1/2" long and a 110mm stem. You can add or subtract stem length to finalize the fit.
Given that length, I'd say you need either an 18 or 19 in frame depending on the mfg and their geometry specs.
As for the LBS, [b]I believe{/b] that they are using pre-jurrasic fitting charts. Before modern geometries were standardized, bikes had longer seat tubes and shorter top tubes (per size). Seats were set close to the top tube with a short seatpost and stems were around 110mm. Look at pictures to see how bikes were set up.
Today we use much longer seat posts so seat tubes are shorter. Top tubes are the longer in relation to the seat tube length than older frames. So, fitting requires that the TOP TUBE be the length which determines the frame size.
Of course it's in the LBS's interest to sell you a bike that is too big. You'll soon have to buy a new bike to replace the poorly fitted one. Which means the LBS gets to sell you TWO bikes instead of just one.
^ wow, thank you for that info. I am going to look up the geometry for the bike im looking at (trek mamba). Thanks so much for the post.
Aka the measurement on a site called the EFF - Effective top-tube length. Although i am leaning towards reach and stack now, due to the varieties in head tube and seat-tube angles.
Bikes: everywhere
Liked 8,021 Times
It's usually ETT, actually.
Kona likes to call it TTH for some reason. No idea what "H" stands for.
Moar cowbell
Bikes: Bike list is not a resume. Nobody cares.
Liked 6 Times
H for horizontal - - measured horizontally to an extrapolated intersection with the seat tube centerline.
RST Suspension | Canfield Bikes | 7iDP Protection | Maxxis | Renthal | Hayes | VonZipper Optics | GoPro
Originally Posted by Mark Twain
"Don't argue with stupid people; they will drag you down to their level and then beat you with experience."
