270LBS Rider Bike decisions...
Bikes: Trek 4500, Fuji Royale, Specialized allez comp
I'm so happy I found this board!
Here is my problem... I weighed in at a whopping 320lbs (a lot of fat with a ton of muscle from Amatuer powerlifting about a decade ago) when I bought my Trek 4500 MTB about this time last year... I had capped my budget at $500 because, I wasn't sure how I would take to Cycling...Well the BUG bit me! Shortly after Buying the Trek I had realized that I should have DEFINITELY spent more and purchased a better bike. I also found myself enjoying the road a lot more than the trails, so now I want to move on to performance road. I want to purchase a bike that I won't have to upgrade as my Skill and Ability get better, at least for a few years. I know I have a passion for riding so I want to purchase once. I lost 50lbs over the last year on my MTB but, that's not what I'm buying for... I want to go fast and for long durations on local club rides and to push my physical limits and see how far I can take this new love.
After doing some research online and at LBS' I am definitely leaning toward Campy components, which really limits my options... I was thinking of buying the '05 Cannondale R900 which comes equipped with the Voloce group... well most of it anyway. My budget is about $1800. All the LBS' I talked to recommend that I purchase a complete bike rather than build up a frameset. Would the C'dale R900 with Caad 8 frame hold up with a 270lbs guy with extremely strong legs? What other bikes would you recommend?
Are the Campy Veloce components compatable with Centaur and Chorus when I get upgrade lust?
Back to being a Clyde....
Bikes: Giant OCR1(specialized carbon seatpost,Terry Fly sadle, Syntace C2): Leader TT frame, Easton EC70fork, Aerolite bars, nashbar bullhorn, Titan Wheels: Fuji Track Pro(2003)
I would suggest that you take a relatively serious test ride on every imaginable type of frame.
I did the similar thing in that I bought a hybrid to ride on to lose weight(40 lb goal) and within a month I realised that I had made a mistake. I went back to my LBS and LUCKILY they gave me a full refund on the bike..but since they were going the extra mile I bought my road bike there. It was late in the season, so the offerings in my size were limited so I got an aluminum frame without ever riding steel, carbon or Ti. As I get farther into my training, I am getting upgrade-itis.
What is your inseam? 44 in? You might have to go custom to get a bike to fit you. I would think about 180 cranks also.
I'm 5'10" short legs and long torso My inseam is only 31 inches I used a few different online fit Calcs and I have yet to see a production frame with the top tube length that they recommend.
What road bike did you purchase?
DEADBEEF
Location: Catching his breath alongside a road near Seattle, WA USA
Bikes: 1999 K2 OzM, 2001 Aegis Aro Svelte
Liked 6 Times
The frame should be okay but I would pay close attention to the wheels. You might want to consider having the bikeshop swap out those low spoke count wheels for beefier ones. If I were you, I'd be looking at 36 spoke with triple-cross lacing and box-section rims. I know this will be heavier but you'll thank yourself for not having to retrue (or worse... rebuild) them so often. Ask your LBS what they'd recommend for heavy duty wheels.
1999 K2 OzM![](https://www.neebu.net/~khuon/cycling/bikes/K2_OzM-sm.JPG)
"Be liberal in what you accept, and conservative in what you send." -- Jon Postel, RFC1122
1999 K2 OzM
![](https://www.neebu.net/~khuon/cycling/bikes/Aegis_Aro_Svelte_Di2-sm.jpg)
Meow!
Bikes: Trek 2100 Road Bike, Full DA10, Cervelo P2K TT bike, Full DA10, Giant Boulder Steel Commuter
I am running areo rims (bontrager) and I am having no problem with them. The rim is very strong and should take the extra 35 pounds over me( Of course that is an expensive option). There are alot of cheeper wheels out there that are also strong that you can look into. BTW how tall are you? I am 6'6 and I need a 63 cm frame.
Good Luck
BTW I love cannondales...
Good Luck
Just your average club rider... :)
gentleman of leisure
incipit-
that's awesome that you got the roadie bug - and i wouldn't worry: a budget of $1800 is pretty much perfect - lots of flexibility there.
i'd agree to look at getting wheels with more spokes than normal - i have a friend almost exactly your size and he ended up getting a an offbrand steel road frame (not avail in your size anymore i'm afraid): https://bikesdirect.com/products/moto.../legacypro.htm
i really don't think shimano vs. campy is something you need to decide this early as a way to limit your options. the fit of the bike is the most important thing, followed by it's overall value (the price considering what time of frame/wheels/components it has). it is inconvenient that you're a clyde, but on the bright side being 5'10" still leaves you with a lot of frames to try out. i would guess that as big as you are you'd probably want to start with 54cm frames. this is an incredibly common size, which is good. so go to as many LBS's as you can and ride pretty much any 54cm or whatever you end up feeling is are the closest sizes. even riding cheaper or super high-end bikes can be educational. take notes on frame material, wheelsets, component groups and prices.
if it were me, i'd get a steel frame. i did an extended test ride of a R600 and found it to be a bit harsh - i ended up buying a lesser-known italian steel frame from gvhbikes that is not quite as responsive as i'd like but makes me feel _way less beat up after longer rides.
gvhbikes has an incredibly sexy Pegoretti Palosanto w/Shimano Ultegra 9spd for $2095 in their special deals section. a bit more than you wanted to spend, but you could get him to lace up some spokier wheels and you'd do really well.
but i'm getting ahead of myself - you need to ride some bikes. see if you can take extended test rides of the ones that are your front runners. it's hard to tell from a tiny loop in a parking lot how a frame is really gonna feel. try to find a hill and get out of the saddle and mash up it.
good luck!
good luck!
I agree with Boze. Why limit yourself to your potential bike by requiring Campy gears? I've ridding Campy and Shimano equipt bikes and not once did I prefer one bike over the other because of the components. Let's face it, both Campy and Shimano make great products, so let the bike drive your purchase and not the company that makes the gears. Now, how crisp (and light) you want your gears to work is based on which level of components you want on your bike. This is true for both companies.
Also, you said you've done research and are leaning toward Campy, but have you test ridden a bike with gears made from both companies? If you haven't, you really should, but make sure it's a fair comparision. Don't test ride a bike with Campy Record and Shimano Sora and say that Shimano gears sucks. It wouldn't a fair comparision. I'm not pro Shimano or Campy, just don't want you to be misguided and limit yourself.
BTW, welcome the sport!
![Smilie](images/smilies/smile.gif)
Take a look at the steel Jamis bikes from Quest on up, maybe Fuji Roubaix Pro. Even with upgraded wheels and a Thomson seatpost, you can get an Ultegra level bike for under $1500. For a few extra $, the 04 Fuji Pro is a 10 speed Dura Ace level alum bike with a Thomson seatpost and Ritchey Deep V pro rims. 18 lbs. Not my favorite frame material, but you could someday replace the frame if you thought it was necessary. The components on this bike are wicked. I saw it on sale for about $2000, but it was at Performance and you get 10% back in store credit, so $1800.
Performance Bike shops, if they are near you, let you finance your bike for free if you pay it off in a year or less. Some other shops do similar.
I have an 03 Quest. Love it.
I think that you want steel. Why don't you look at the Bianchi Veloce? Reynolds 631 tubing and full Campagnolo Veloce group for around $1400.
Alternately, the new LeMond Sarthe is made of TrueTemper OSX Platinum steel tubing with full Veloce for the same price.
It is largely dependent on your build/proportions/flexibility, but I imagine the Bianchi would likely suit you better. Both are very nice bikes, though.
I am 215lbs and have a R800 which came with the same wheels as the new R900. I felt uncomfortable with the wheels, everything felt loose. I switched to Open Pros, 32 spoke, and am very happy. The CAAD 7 is a very light, delicate frame. Its a little thicker than tinfoil and seems strong but you have to be careful with it. Rick
I am also 6' with a short inseam and have a 58cm frame which they measure c-c, my trek size is 60cm which is measured c-t.
Staying Upright
Bikes: Waterford, Cannondale
![Big Grin](images/smilies/biggrin.gif)
I'm 5'10", currently 238 (down 12 lbs. since 12 weeks ago!) but I have long arms & torso, shorter inseam at 30". I'm comfortable on a "traditional" 54cm frame (more specifically a Trek or Cannondale 54cm frame) although a longer stem feels more comfortable, and 56cm just a tad large to stand over but once in riding position is comfortable with the longer frame length for torso and arms. I ended up buying an '04 Lemond Zurich, 55cm which fits me to a "T"; has less standover (because of the frame design) and riding length is perfect, like the 56cm traditional frame.
I'm riding on the stock 700x23 Bontrager tires that came with the bike and haven't had a problem, and the wheels are still true. The Lemond is Carbon/Steel frame.
Good luck in your quest!
MUCH easier on the road. 36 or (even better) 40 spoke wheels
on premuim hubs will go a long way towards a very good road
bike. Also look for a lugged STEEL frame of name brand make.
There is a reason all the custom builders build lugged steel
bikes, mate.
Bikes: Albert Eisentraut custom w/DA, Kestrel RT 700 w/Ultegra, Jamis Tangier
After doing some research online and at LBS' I am definitely leaning toward Campy components, which really limits my options... I was thinking of buying the '05 Cannondale R900 which comes equipped with the Voloce group... well most of it anyway. My budget is about $1800. All the LBS' I talked to recommend that I purchase a complete bike rather than build up a frameset. Are the Campy Veloce components compatable with Centaur and Chorus when I get upgrade lust?
As for bikes, what length of top tube were you thinking you needed and how does that compare (length and feeling-wise) to your current bike? Although I don't personally like compact frames, this is where, if budget is an issue, you can go up in size to get a longer TT while not sacrificing standover although position of seat height relative to bars will change as you go up. You might look at some steel/mixed material bikes like Lemonds that have longer top tubes than other brands of similar frame size. If you plan to ride distances and want to do so in comfort, I think you would find aluminum to not dampen road shock as well as steel or mixed material bikes.
Let us know what you work out and welcome to the road!
Maybe check out some titanium frames and build up from there. Probably your best bet to build a high quality very durable bike. There are many very inexpensive Ti frames out there right now for under $700.00. Habanero comes to mind and he'll even custom build for you. You can build the rest of the bike at performance. A full Ultegra group is inexpensive there. If you shop around, you can build a great bike for you for your price range, and you won't have to worry about durability.
One thing I'd be cautious with Campy about is cranks. They still use the tapered, squared spindle, and with your size, I'd question how well it will hold up to you.
Just my .02 cents
Just my .02 cents
Well, That is why I'm here also...Doing research. I was leaning toward Campy mainly due to the shifter style... They just clicked with me...no pun intended. I just didn't like the Shimano syle shifters as much as the campy's. I was looking into Bianchi at one LBS but, he said he preferred the C'dale to the veloce but talked a bit about the new model they offer for '05 but for the life of me I can't remember the name. He didn't have any Bianchi's in shop but, he said he could order one for me. A couple of different guys I talked at the LBS to suggested upgrading the wheels as well, They all steered me toward the Mavic Ksyrium Elites but, said it would hike the price up $400... which would place me at the 2k mark.
How are the Litespeed framesets? I've seen a lot of deals online with litespeed frames, kind of cheap for full Ultegra I thought... my problem is out of the five shops I've been to all of them are filled with C'dale, Trek & Giant but not much else... Being a newbie I have no Idea about the other manufacturers out there that make a quality frameset.
...A couple of different guys I talked at the LBS to suggested upgrading the wheels as well, They all steered me toward the Mavic Ksyrium Elites but, said it would hike the price up $400... which would place me at the 2k mark.
Good luck.
DEADBEEF
Liked 6 Times
1999 K2 OzM
You can get your Campy, I'd just suggest getting an ISIS type crank instead of a Campy crank. Less chance of you ripping apart the spindle. Campy Centaur is good quality for the buck. I agree with the steel frame suggestion, but would probably still lean towards the titanium. Litespeed is obviously a good framebuilder. A Habanero or a TST are much less expensive and of really good quality. I just bought a 56 cm TST frame for $500.00. That's a really good price for a quality Titanium frame. I hear a lot of people rave about the Habaneros. I've always rode Italian steel before and really liked my last Olmo frameset. There are tons of frames out there. It's impossible to list 'em all, and say which is better than another.
I think by the time you beefed up any bike you'd get at an LBS, you'd be better off building one of your own, to your specs.
steelrider, khuon and glevii are all correct.
a habañero would be an excellent choice in a value ti frame to build up. and going with steel over a straight alum frame like the cDale would also make sense.
i feel your pain about only finding run-of-the-mill Trek, Giant and Cannondale at your LBSs. none of them make steel bikes anymore so it's like we're all asking you to do the impossible. call around though - if you can find someplace with _some kind of steel and ti bikes in your size then go ride them and just make a note of the size that fit you best. then you can order online if you want or stay with the LBS if you find something at the right price that works.
one other thing - my friend who's your size complained of feeling like he was leaning on his hands too much until he had his stem flipped so the rise was up. a little change like that can change your impression of a bike so make sure to get a skilled salesperson who can set the bike up correctly. some folks are of the opinion that once somebody does this for you it means you should buy the bike there even if it isn't the best price, but i disagree.
you gotta find some bikes other than those by the big three and get some sizes you like and prices they offered and we'll go from there.
One Bike shop I visited which also seemed to be the best helping and most knowledgable of the ones I had been to is Carl Hart Bicycles They carry Aegis, Bianchi, Cervelo, Colnago, Fuji, Felt, Klien, LeMond and a host of other companies along with the other run of the mill brands I discussed earlier... Only problem I saw was that they want top dollar for everything. I won't be be purchasing anything until right after the holidays, so I will pay them a visit and concentrate on the off brands... one thing though, the last time I was there they didn't have much in stock as far as the other brands go... only a few High Dollar models here and there. Nothing in competition with the models we were discussing.
Bikes: bianchi
One thing you may want to consider is to hold off on the road bike (or at least get an inexpensive used one) until you loose another 50 pounds or so. I think that what people find comfortable when they are big is very different than what they find comfortable after loosing a lot of weight.
If you are hard to fit, try a custom frame builder. It is possible to put together a custom TIG-welded bike for a reasonable amount of money. A custom frame would be the ultimate reward for loosing more weight.
Another 50lbs I will be REALLY lean... I have a lot of muscle on my frame.
I would think that the only thing that would change much is my flexability... My limbs, torso. shoulder width and inseem would remain the same so, wouldn't bike dimension recommendations be the same or EXTREMELY similar? I would really just be able to upgrade to a lighter wheelset, but at 220 I think I would still require a pretty durable wheel...no?
