Trikes - How Practical?
A typical journey I make on my DF is to ride into the local town, park the bike and spend an hour in the library.
How does that translate with a trike? Can you tie them to a lamppost and leave them?
How do you leave yours when shopping, etc?
Steve
Steve
Honorable Member
I run my cable lock through the front chain ring and around a pole. Wouldn't last long in New York, but it works just fine down here. Funny,,,,I tie mine up to the library here for an hour also. Takes a while to browse the CD's.
Let me extend the intent of the above question?
I am wanting to get in a 'bent' and am leaning toward a trike. Looking for some of that additional relaxed ride. But I will be using it to commute between home and work a couple times per week as the weather permits. {I am in MN so there are some months that will prevent that.} That is about 22 miles one way.
I have seen several comments about being seen by the traffic so won't re-ask that question.
There are several people that speak highly about CarTrike? What about GreenSpeed - is that an overpriced version of the same thing?
I have reviewed a lot of web sites to learn what is available. Does anyone buy a trike without having a test ride; there are so few shops around that carry these trikes so the variety opportunity for demo rides just doesn't exist. - or do I live in the wrong part of the country?
Any suggestions about what to look for as I continue my search?
Super Modest
Liked 4,796 Times
Just a side note to the topic. Anyone wanting to see what can be done on a trike should read the following tour diary of a woman who is in the midst of riding a trike to Alaska and back from No. Carolina:
https://www.crazyguyonabike.com/journ...20041021103440
She's ridden 11,865 miles since February of this year.
Keep the chain tight!
Doomsled
Bikes: Performer JC-70
Good point, Trsnrtr. The Greenspeed GRT was designed to circumnavigate Austrailia. That's 9,000+ miles with 88lbs of gear! If that's not practical I don't know what is!!!
Check out www.bentrideronline.com/messageboard They have an entire forum devoted to trikes. People who use them daily for commuting, touring, etc.
I don't think you can go wrong with any of the major brands. If you had them all in a row, you would probably find preferences but those preferences will not likely be all on one trike.
Chip
TT and Logo
I ride Greenspeed GT3, which I purchased in June after just two afternoons of looking. I liked the Cattrike and the WW, which were a bit cheaper. The dealer steered me towards the Greenspeed by extolling its quality. The machine is wonderful. I would certainly give the Cattrike another look, but the WW no chain tubes and a somewhat convoluted chain route that I've read can be cause for concern. I'm unable to do my own repairs and the Greenspeed has proved dependable in a way that is necessary for me. Whether the other trikes would have required service or been less dependable, I cannot say.
I do think, however, given the inherent complexity of a tadpole tricycle's frontend and that they're all virtually custom built, spending an extra $800-1000 on getting what you're most comfortable with is money well spent.
Good luck and welcome to the bent community!!
I have a Hase Lepus from Germany (frog!) and a Trice Classic made in the UK (Tadpole!).
They are both fantastic but both ride very differently, the Lepus being a more slow and relaxing ride if a little heavier. Only negative to commuting on trikes is the parking space they take up can be annoying to other people. On the plus side, if anybody tries to steal it.... THEY WILL BE NOTICED!!!
Bikes: homebuilt tadpole trike
BigAl: If you're in or near the Twin Cities, you've got resources nearby that can help you shop for a trike and the means to become an all-season commuter on it. Trikes are definitely the way to go in snow.
https://mnhpva.org/
https://groups.yahoo.com/group/recumbentsmn/
https://www.calhouncycle.com/
Just on general principles, here's a link to the Icebike site -- a font of info on winter cycling.
https://www.icebike.com/
https://mnhpva.org/
Bikes: Electra Townie crank forward, Specialized flat bar road bike.
Another viewpoint, not so "pro trike": I had "trike fever" back in the early summer. Now I am not too interested and the reason is visibility. Me seeing from that low on the ground and me being SEEN (by cars) that low on the ground.
Yeah, I know what trike devotees will say, but I would not feel comfortable in any way shape or form with cars behind, beside, or in front of me and their hubcaps at my eye level. If that doesn't bother some folks, then great. As for me, no thanks. That is too darn scary for my liking.
If all you're going to ride is a rail trail, they might be great. Or if you ride way out in the country where there is little traffic. Otherwise, I think it's very dangerous.
But I am a wuss...I don't ride my DFs in areas of heavy traffic...heck, I even am fearful in my SUV! Drivers are just "nuts" today and could care less if they cut in front of you, brake suddenly, run up on your bumper. No thanks~
Chili
Tour Easy SS
Chili
Tour Easy SS
Originally Posted by DJB14
but the WW no chain tubes and a somewhat convoluted chain route that I've read can be cause for concern. I do think, however, given the inherent complexity of a tadpole tricycle's frontend and that they're all virtually custom built, spending an extra $800-1000 on getting what you're most comfortable with is money well spent.
CS
Originally Posted by cjs1948
There is NO issue with WW chain routing by our experience on two trikes. In fact I have tubed the chain on my third trike to keep its oil off me and the frame. Because of WW controlled chain routing neither is an issue.
CS
CS
here is my trike experience
1. buddy had a greenspeed. more money, slow, low and I don't get the point. why make something heavier, harder to haul, more complicated etc.....unless you need the trike for disability.
2. rode GRR in colorado mountain ride. no trikes, OH yea, one guy was trike nuts and hauled the bike up all the passes on top of car. I take that back. Another guy had a trike, no use of legs. He hand powered his trike to the top only to haul it down the mountain do to lack of control. My hero.
3. I see no trikes in any compititions of any kind, reg bike or HPV.
I would suggest getting bent, two wheel style.
Doomsled
I'm also interested in going car free. 3 wheels is more stable than 2 (tadpole). Much better for riding on rotted autumn leaves and ice.
Bruce
Compulsive Upgrader
Bikes: 2002 Kona Deluxe (road), 2001 Cove Stiffee (mtb)
Originally Posted by funbun
The lane lines are lower on the ground than I would be and people seem to read them just fine.
I've been commuting on my Speed since I bought it in late October in Toronto which takes me through the downtown lake front area. I don't have a problem with traffic. In fact once I put on a mirror and mounted the flag higher, I think the visibility is fine. I also have my lights on and wear reflective clothing to further enhance my visibility.
Its about attitude really. If you act scared and worried on the road, motorists will pick up on this. If you ride with a purpose, strong and appear to know what you are doing they react differently. Nothing is 100% but I think this is one of many keys to getting around, no matter what you ride. I also think some motorists assume there is something "wrong" (read: disability, sorry not meant to offend) with me and I am forced to ride my easy chair into work. So the reaction is sympathetic in a manner of speaking.
I had one woman, tailgate me for a block down a narrow street with vehicles parked along the right side, lay on her horn and yell at me that I was stupid, about a week ago. Bad day at work, whatever, I got really pissed and chased her down the street until she parked. I told her to learn how share the road, and remember to read the quote in first page in the driver's manual, "Driving is a priviledge, not a right." She looked at me like I had two heads. I just shook my head and continued home. Whatever. Getting off topic anyways.
Heck ride what makes you comfortable. I think it can be done as long as you take the steps to make the ride a safe and enjoyable as possible.
"No drug, not even alcohol, causes the fundamental ills of society. If we're looking for the source of our troubles, we shouldn't test people for drugs. We should test them for stupidity, ignorance, greed, and love of power." -P.J. O'Rourke
ez3 usx
Bikes: ez3 usx
i have a 3 wheel ez3usx and i lock it with a wire cable around the frame.i have locked it to door handles at the grocery and anything i can get my cable around.so far i have better than handicapped parking,and with no sticker.
Bikes: BikeE AT--Gary Fisher DF
I'm still recovering from the broken femur I suffered on Oct 31, when my BikeE went over hard on some wet leaves. I'm very much looking forward to test riding some trikes as soon as I'm able to pedal again.
I don't own or use cars, and depend on my bike for basic transportation. Because of this, it is necessary for me to be out in all kinds of weather and conditions. Only ice has stopped me in the past, and I would either get a ride from a friend with a car, or call in "sick" to work. I certainly never want to go through the agony of this kind of injury ever again. I don't care how practical a trike may or may not be, it's really subjective after all. Friends and family thought I was crazy when I bought the BikeE. I just want reasonable, healthy, dependable transportation to get me around town, and throw on a bus, train or plane, when I want a vacation. I'm favoring the SUN EZ3 USX. Can't wait to test ride one!! Anyone know of a dealer in the Northeast US around Philadelphia area?
I ride only trikes and, fortunately, didn't have to break anything to get my clue. My two-wheelers left one at a time because the trikes were so much more enjoyable to ride.
Chip
TT and Logo
ez3 usx
Bikes: ez3 usx
i have a ex3 usx and it's a blast with the electric hub motor i put on it.i'd highly recommend it for a bike for your recovery,however i doubt you would want to get out of it after your done licking your wounds.my bike is more comfortable than some recliners i have been in.mmm...wonder how my bike wouild look parked in the family room with a puter next to it?i like to ride the trails they have in ohio.i blast past everyone with the motor and it's not relly noticable.one lady cruised up on a 10 speed thing and said that bike is fast.made me laugh,,,i finally told her i had a electric motor on it.she told me she thouight she was just out of shape,,,was so funny but i guess you had to be there and see her in her spandex.i have decided to install a irrigation system on my bike for not only cooling,but to make it look like i have been peddling.i don't mind the extra weight of this machine over something that might go faster i just got this bike and i am going to hang as much stuff on it as i can to make it as safe and comfortable and high tech as i can.my guess is there are a lot of fog's(fat old geezers) out there who will be doing the same from the response i have gotten so far riding my i don't know what to call it really.bike i guess but what a ride.
go for the trike you can loose your behind in the seat so comfortable for me anyways
happy trails and good luck dodging the squirrels wet leaves and other dangerous wet patches...oh no mrbill black ice,,,i'm thinking of studded tires
I'm very mindful of "You getz what you payz for;" Greenspeed or Hase Kettwiesel are my trikes of choice. For some reason, I like the "delta" types like Hase and Sun better; higher seat, better visibility, better turning radius. Money will be an issue for sure, but the good news is I won't be able to pedal anything till spring at the earliest, so I have plenty of time to do the research and test rides, and to save up the money. May I call on you for specific advise when I am closer to purchase time?
Perhaps you need to look at a Greenspeed GT3 when it come time to take it with you--it folds. The Sun trike, while a perfectly fine ride, is pretty long and weighs 65 lbs.
Chip
TT and Logo
Chip
TT and Logo
Chip
