Getting a new bar and stem, But have no spacesr currently on my setup. help!
hey im getting a new bar and stem, But have no spacers currently on my setup. will there be a problem? if there is what do i have to do to make it fit? please help
hobo
possibly, depends on the stack height of the stem you're getting compared to how much steerer tube you have above the headset. Assuming this is NOT a carbon steerer tube.... If the new stem and old stem are the same stack height, then you should be fine. If it's less than what you have, you'll need a small spacer in order to be able to preload the headset when you put it all back together. If it's more than the current stem, then you'll have issues since you probably won't be able to tighten the stem, depending on stem bolt locations and just how much of a different we're talking. The only way around this is to replace the entire bike or give up cycling completely.
Former Hoarder
![Thumbs Up](images/smilies/thumb.gif)
![Smilie](images/smilies/smile.gif)
erikdstock
Bicycle Mechanics
6
02-21-13 05:14 PM
kirke
Classic & Vintage
8
12-20-09 06:32 AM
