Flat Tire Questions
Flat Tire Questions
I went on a ride about a week ago, didn't go far but just wanted to get out for a little bit while I had the time. Everything went well, no flat when I finished my ride. When I went for a ride a few days ago I found my back tire to be flat, wouldn't take any air at all. I took off the tire and changed the tube, everything seems to be fine but I haven't ridden it yet. I noticed on my old tube the hole is right at the base of the stem, and it looks like something cut the tube because there is a little flap of rubber. My question is---is it possible that there is a burr or something on the rim that could have cut the tube? Have any of you got a flat tire from the rim, but not like a pinch hole? I got the other tube on the rim before I thought to look and see if something was there. Seeing as this is my first flat replacement I'm a little hesitant to go out on a ride because I don't have a seat bag to put a tube and some tire irons in.
Thanks!
Thanks!
Galveston County Texas
Bikes: 02 GTO, 2011 Magnum
Liked 1,255 Times
You might want to remove the tire and tube and check the rim for burrs.
Flats are part of road riding.
Spare tube, CO2 and or small pump should be carried with you.
Fred "The Real Fred"
I wouldn't ride a flat tire any distance at all, unless some emergency required it. You can damage the tire and the wheel in a short distance.
I suggest you bring the following with you on all rides longer than 100 feet: tube, pump (or CO2 can), tire tools.
King Hoternot
Bikes: 2015 Cannondale Evo Hi mod
bad....very bad. unclip, pick your bike up and start walking. replacing your cleats would be way cheaper than a new rear weel (or whichever tire is flat). like already suggested, take tube out and run fingers along the inside rim and check. But I have had this happen also. For me it was a matter of being to aggresive with the stem when I was trying to attach my floor pump to it. it happens, just check your equiptment and throw in a new tube.
Bikes: 08 LHT and 13 giant defy 2 composite
Also make sure you don't overtighten the nut on the outside of the valve stem.This can pull the tube into the hole and cut your tube.
OK thanks guys I checked again and there were no sharp objects in the rim. Hopefully I didn't miss it if there is something there. And hopefully my tire won't go flat on my ride today!
Bikes: 2011 Scott S30, 2012 Tarmac SL3
Many years ago I got a flat because the tube was mounted in the wrong location so that the stem was pushed sideways in the hole. Not sure if that can happen with modern rims, but that's one thing I've been careful about ever since. The valve nut can be helpful to keep the stem straight while mounting/inflating the tube.
Bikes: Raleigh R600 105/DA, Specialized Allez Elite 105
Please try not to ride to the LBS on just rim. You could destroy your tire. It's possible, I've done it. Broken axle once too. You get looks like this .
Take the nut and valve cap off.
Have your LBS re-tape and check your rim for anything like you are describing, they will set you straight. Buy the best TAPE they have and you won't have to replace that tape ever in your ownership of that wheelset.
There's really nothing I could tell you, even with pictures, video, lengthy descriptions, etc, because we would have to literally feel the rim and look everywhere.
Actually the tubes that came with my bike didn't have a nut on the stem but the new tube I put in did. So overtightening the nut wasn't the problem of my flat...it wasn't even a possibility. Either way, the tube I put on stayed inflated and rode well so it seems like my flat problems have been solved until the next one!
Bikes: Surly Long Haul Trucker, Gary Fisher Hoo Koo E Koo, Dahon Mu P 24 , Ritchey Breakaway Cross, Rodriguez Tandem, Wheeler MTB
When you add air to the tube, have you been using a regular floor pump, or a smaller hand type pump? The smaller pumps allow too much movement of the valve stem while pumping, and IMO can cut the tube near the base of the stem.
And you really should have a kit to fix a flat, it'll save you so much time in the long run. And please don't ride on a flat tire if it is at all possible to avoid, it'll cost you big time.
NEVERMIND i DIDNT READ YOUR RESPONSE TO THAT STATEMENT
2010 Kestrel RT900SL, 800k carbon, chorus/record, speedplay, zonda
2000 litespeed Unicoi Ti, XTR,XT, Campy crank, time atac, carbon forks
I eat carbide.
Bikes: Lots. Van Dessel and Squid Dealer
Liked 1,310 Times
You tore the valve off. Happens. Pay attention to what you're doing. Happens more with cheap tubes.
PSIMET Wheels, PSIMET Racing, PSIMET Neutral Race Support, and 11 Jackson Coffee
Podcast - YouTube Channel
Video about PSIMET Wheels
Bikes: 2010 Specialized Allez
