SRAM Red group with Shimano Cassette?
Bikes: 2004 Felt F35R // 2010 Scott Addict RC
I just finished building my new bike and I'm using full Red except the cassette. I'm currently using a used DA7800 cassette that my buddy gave me. Turns out the 4 large cogs are worn out because it's not grabbing when I use it. I decided to buy an ultegra 6700 to replace it and had my mechanic replace it. He then told me that it's not shifting to the largest cog because the gear ratio of SRAM and Shimano is a bit different. Ive read on the forum that people uses the same setup with no problem. He suggested me that I better get the SRAM cassette and just return the ultegra cassette to avoid the trouble.
My setup is 53/39 and 12-25 with brand new KMC chain. When he is shifting it on 53 and 25, thats when it's skipping and just goes back to 23. I'm thinking could it be because of the cross chain? Or I should be able to use all the gear regardless of the setup?
My mechanic didnt charged me after doing all of this btw Would like to hear some input.
Liked 278 Times
You should be able to use the all the gears and cross chaining should never even be an issue. Have him check the gap between the upper pulley and the largest cog (no cross chaining for this calibration), it should be 6mm. Adjust the "B" screw on the RD to the right spec. Most mechanics that are used to Shimano standards set the gap at "just enough" for the chain to clear the largest cog and the upper jockey wheel, which is great if you are using a Shimano RD (I still do this on my Shimano equipped bikes, may have changed). Check also that the jockey wheels and each cog is aligning properly with each gear change.
Zircon Encrusted Tweezer
Bikes: Pivot Switchblade, SantaCruz Tallboy, SantaCruz Solo, Specialized Fatboy, Trek ProjectOne Madone, Fuji Altamira CX 1.1, Lemond Zurich
I run a 50/34 with a 105 11-25, KMC chain, no problems (or noise) cross-chaining
I have an Ultegra 12-23 on an otherwise Rival bike with a 39/53 crank and it shifts fine to the 23-53 if I want it to. Any chance that you have a really small frame? I could see a short chain stay making tuning more difficult but I don't know that it would make it impossible.
Cookies!
Bikes: Red Huffy, CAAD10 Rival
I have a question for someone who knows about this stuff.
I thought that SRAM had 1:1 pull, such that each shift of the lever moves the cable the same distance. And this same distance is accounted for by the cog spacing (and how far the derailleur moves each time). And I thought that Shimano had a different pull distance for each gear shift, and thus different spacing. Is this incorrect?
I eat carbide.
Bikes: Lots. Van Dessel and Squid Dealer
Liked 1,308 Times
'so ...you can use a shimano or SRAm cassette and have no problems. You just "can't" use a Shimano shifter with a SRAM Derail and visa-versa.
PSIMET Wheels, PSIMET Racing, PSIMET Neutral Race Support, and 11 Jackson Coffee
Podcast - YouTube Channel
Video about PSIMET Wheels
OP, you mentioned all SRAM Red.......I have SRAM Red on my Focus and Force of my Tarmac. The only component that is pure crap is the Red FD ! I have replaced it with a Force which works great and have contacted SRAM who said they will replace the Red FD with another Red but with a steel cage.
On the Tarmac I also have the Red cassette 11-25 which works great, faultlessly but since it's machined from a solid block (extremely light and expensive!) it also rings like a bell! In the middle cogs it produces a ringing metal sound that I found really annoying for a while... Now I am used to it.
But to answer your initial question, any 10 speed cassette will work! Your mechanic is not much of one......
Thank you guys for the inputs. I've decided to take my bike to my other mechanic and had him look at it. Took him less than 5 mins and everything works flawlessly and didn't even bother to charge me. I knew I've read everywhere that cassettes are interchangeable, that's why I was kinda questioning his statement. I'm now using ultegra 6700 cassette ![Smilie](images/smilies/smile.gif)
As for the FD, I'm stil using Red and have no problem with the shifting. I'm using braze-on if that would matter somehow.
my brain hurts!
Bikes: Numerous bicycles.
If your "mechanic" told you that, he's not a mechanic in my book. That kind of stuff should be common knowledge. I'd go somewhere where they knew what the f they were talking about.
MinnMan
Bicycle Mechanics
3
05-01-19 01:10 PM
mihlbach
Bicycle Mechanics
9
06-10-12 10:11 PM
vins0010
Bicycle Mechanics
7
06-05-11 11:32 AM
Barrettscv
15
08-14-10 08:38 PM
