Gates belt drive weight savings, where do they get 10 ounces
I have seen several posts stating that the gates belt drive saves 10 ounces over a conventional chain drive.
Here are some numbers that one of the forum subscribers put together and I think they paint a more accurate picture.
Gates sync belt ring. 95 grams X 2 = 190 grams
Gates carbon drive belt 105 grams
Total weight of the Gates system = 295 grams
42 tooth Hegoa Chain ring. 35 grams X 2 = 70 grams
Campy Record 11 chain 337 grams
Total weight of chain drive system = 407 grams
407 - 295 = 112 grams or 3.95 ounces.
So if the numbers are correct the weight savings is 4 ounces rather than 10. If you only compare the weight of the belt vs. the weight of the chain then the weight reduction approaches 8/10 ounces, however you have to account for the weight of the Gates sprockets.
I had been giving some thought to the Gates belt drive but do not see that it has any real advantage over the tried, try and efficient chain drive system for us. Especially when you look at the cost of the system and replacement costs. I think the jury is still out on what the Gates system is doing to bottom bearing wear.
Bikes: Custom 650B tandem by Bob Brown, 650B tandem converted from Santana Arriva, Santana Noventa, Boulder Bicycle 700C, Gunnar Sport
Quoted: 23 Post(s)
I agree. Field repair is also an issue since a special tool is required to remount a belt if it comes off.
Oldie. Boy, howdy!
Bikes: 2005 Trek T2000 tandem, Giant TCR, Eddie Merckx Majestic Ti, Fuji Team, Giant Revel 29er, Windsor Clockwork (Orange) fixie, and a BikTrix Juggernaut Ultra 1000 fat tire eBike
Hmmm. They're probably comparing against what the AVERAGE tandem runs, which, considering the percentage of entry level vs performance tandems, would be a generic 1/8 or 3/32 chain.
But you're right in that they ought to compare against a top of the line 10 or 11 speed chain. After all, the guy who is predisposed to go Gates is probably already a weight weenie and running the lightest gear he can. Like your 11 speed Campy Record.
BICYCLE - [[I]bahy-si-kuhl] - Noun :> A medical device used to correct the common geriatric condition of OFS, (Old, Fat & Slow), in a manner that does not induce brain-decaying boredom like walking or running.
Bikes: 2015 Calfee Tetra tandem,2016 Calfee Tetra Adventure Tandem, Ventana ECDM 26 mtn tandem, Ventana ECDM 29r full suspension Mtn tandem ,Ventana Fat tire tandem, Calfee Dragon Fly, Santa Cruz Carbon 5010, 907 Whiteout fat tire
Quoted: 57 Post(s)
Liked 6 Times
The only tool you need to remount a belt is what ever tool you need to loosen the eccentric as you are not supposed to force it on like you can a chain. We have had ours for about 4000 miles without any issues whatsoever. It got noisy once after riding in very dusty gravel construction area and a squirt form the water bottle solved the noise. As we travel with our tandem often it has been on and off the bike a number of times and I simply coil it up for travel like a new comes from Gates. I don't think there are any great mechanical advantage but we sure like no dirty chain to deal with.
Bikes: Paketa V2r, VECdM29er, a bunch of singles gathering dust.
Yes, the weight savings appear to be only in the belt. I didn't weight ours, but the Gates pulleys did not feel lighter than sprokets.
We have almost 10,000 miles on our belt with no issues whatsoever, but then how often is a timing chain replaced anyway. It is nice to be able to lay the bike down in the back of the Durango on the left side. Plus their is no chain type lash between cranks, both cranks feel directly connected. I would guess the belt is not quite as efficient as a chain since the belt is stiff.
Quoted: 77 Post(s)
Liked 19 Times
No greasy/oily stuff on our tandem chains.
We've used the hot wax (canning wax/paraffin) method for the past 35+ years.
Have ridden a tandem porototype with the belt years back; was not overly impre$$ed.
Just our input/experience.
Want to save weight? Carry one less waterbottle!
Rudy and Kay/zonatandem
Bikes: Trek T2000, Ventana ElConquistador, ElSanto, STP400, 5500, JubileeSport, Scattante...
IIRC the weight was compared to a very heavy KMC chain that was standard on CoMmotion tandems.
Tandem Vincitur
Bikes: BMC Pro Machine SLC01, Specialized Globe, Burley Rock 'N Roll tandem, Calfee Dragonfly tandem.
Actually, there is no Super Record chain. The Campy 11-speed chains are Chorus and Record.
I agree that the biggest advantage of a sync belt on a tandem is the cleanliness. A sync chain is long and exposed, and makes the tandem a constant threat to get oil stains on anything it gets near. That feeling of wariness and dread with the tandem is diminished significantly with the belt drive, as the right drivetrain is shorter, less exposed, and the left side of the tandem is completely safe.
Bikes: 2005 S-Works SR Equipped,1978 Tom Ritchie Road bike, Kuwahara Tandem
Yes. Campy does not make a SR chain, but they do make a SR groupo. Onegun was refering to lightweight gear not just the chain.
Likes to Ride Far
Correct, I think this was discussed a couple of years ago, and this was the best answer. Gates originally designed the belt to work with a Co-Motion; the upgrade that Co-Motion offered was from a pair of FSA timing rings and KMC 8-speed chain to the belt setup. Co-Motion therefore published the weight difference between these two setups, which is completely justified. If Gates are now using this weight difference in their advertising without saying what the setup used for comparison is, then it could be a bit misleading.
Bikes: Comotion Primera
Quoted: 5 Post(s)
10 oz might be Real
When I built up our Comotion Speedster (size Small), I was surprised that I needed more than one chain's length to meet the length requirement for the timing chain only. Seemed like almost two chains worth, but not sure - it was long ago. Different bikes will have different lengths of timing chain, but I remember being disappointed from the extra weight that I did not account for. Thinking of riding the tandem again, and trying to lighten up, so Gates drive might do it for me.
This thread might be dead by now, but it is something to consider.
Bikes: 2022 Calfee Tetra, 2023 Giant TCR
Quoted: 120 Post(s)
407 - 295 = 112 grams or 3.95 ounces..
When the TandemGeek tested the older Gates belt (non-CDX), he found that it was 170g lighter than the lightweight daVinci chain setup:
https://tandemgeek.wordpress.com/201...belt-vs-chain/
The CDX rings are lighter, and should be as light or lighter than most aluminum rings. Co-Motion claims a weight savings of 283g but this is a bit optimistic. It's reasonable to save 200-230g.
The incremental cost is not that big. Precision Tandem sells the CDX belt for $100. A high-quality chain from Campy or Shimano is $50-80 each (10 or 11sp). You need two for the timing chain so the cost is basically the same as a Gates belt. Plus the Gates will easily last 2-4 times longer than a chain.
Precision sells a complete CDX system for $265. A conventional timing chain system is around $160 depending on your choice of rings. So the Gates belt drive will save you at least 200g for a premium of about $100. It's also quieter, cleaner, and needs less maintenance. How many bike upgrades provide the same amount of benefit for $100?
As Alexpress already pointed out, the Gates belt doesn't requires special tools.
I recently replaced our timing chain and chain rings with the Gates CDX carbon drive belt system.
The old 9 speed SRAM chain weighed 405g, and the old chainrings weighed 85g for the pair.
The new belt is 110 g, new CDX rings are 155g for the pair. So the 225g difference = 8 oz lighter. But if you are as cautious as I am, a spare belt adds 4 oz back.
Quoted: 120 Post(s)
If you check the belt regularly, it should last much longer than a timing chain. One reviewer managed to get over 10,000 km from his CDX belt:
https://www.cyclingabout.com/review-...e-centertrack/
I'm not aware of any tandem team being stranded from a broken CDX belt. Belts have been around for awhile and are commonly used on cars and motorcycles. But it doesn't hurt to carry a spare belt if you're touring.
just another gosling
Quoted: 3917 Post(s)
Liked 1,969 Times
I never take a spare belt when touring. It'd be easy to buy a pair of rings and a couple chains at a bike shop in the extremely unlikely event that the belt failed. And a tandem can always get to a bike shop!
Results matter
Results matter
Bikes: Road, Hybrid, Tandem, Mountain, Gravel
So that's 6,200 miles.
We have 10,800 miles on our belt drive and starting our fifth year with it.
Not one problem, issue, squeak, jumping track, or any maintenance!
And we don't carry a spare.
I'm sure there are teams out there with more miles on one.
Belt drive is the future. Just look at how many new tandems come standard with them.
To be clear, the 405 grams I posted was for enough chain to make a complete timing chain, constructed out of portions of 2 SRAM 9 speed chains, spanning the same length as was replaced with a 250 tooth Gates belt
Quoted: 29 Post(s)
A typical timing chain has between 152 and 162 links. I wonder how a 116 link chain would reach around both cranks and join up, even if 243g.
On my tandem 1 and a bit KMC X11SL chains would weigh 339.3 grams.
Quoted: 120 Post(s)
The X11Sl retails for $90, but is often on sale for $70. Since you need to buy a pair, the KMC timing chain will cost $140. I suppose that you can keep the extra links for a 2nd set, but it seems like a hassle for no particular benefit.
I only use them on my single bike. Since the tandem is 10 speed I use X10SL on the rear and plain X10 for the timing chain. A few extra grams doesn't matter to me. I only use the X10SL on the rear because I feel it shifts better.
Bikes: Co-Motion Primera Co-Pilot, Trek Madone 3.1
Quoted: 13 Post(s)
Generally consistent with what I found when I converted: the "sprockets" are heavier for the Gates system but the belt is *much* lighter giving a lower overall number. Don't care to argue about the magnitude of how much lighter personally. I find a number of other benefits to the belt system in addition to the lower weight.
Yes the bike will ride the same either way. Like most bike bling you will very likely not be able to tell the difference in how the bike rides. But it WILL look cool and make you feel way better riding the bike. And, not speaking for all tandem teams here, but if I cannot look good riding the bike at least I want my bike to look good with me riding it
Clipless in Coeur d'Alene
The most important benefit for me is how little time I've spent in maintaining the belt setup over the last few years... likely near the same amount of time it took to write this note.
Put that in your greasy chain bag.
