Broken Cable Guide
Broken Cable Guide
Also posted to framebuilders but thought someone here may have some experience
I broke this cable guide in a bike stand and wondering how bad the fix for it is. I would like to preserve the original paint. Is it possible to use one of those micro torches and heat the broken one to remove it then either braze a new one on in the same manner without damaging the paint (except on the guide of course, I have a touch up paint that is close in color to paint the guide) or could the new one be JB Welded into place?
Where can I buy a single matching cable guide?
![](https://i758.photobucket.com/albums/xx224/wtgrantham/Parts%20For%20Sale/IMG_0433.jpg)
![](https://i758.photobucket.com/albums/xx224/wtgrantham/Parts%20For%20Sale/IMG_0436.jpg)
Half way there
Bikes: 69 Hercules, 73 Raleigh Sports, 74 Raliegh Competition, 78 Nishiki Professional, 79 Nishiki International, 83 Colnago Super, 83 Viner Junior
I don't know if anyone has enough magic to braze a new guide without damaging the paint. You could remove the broken one with a file or dremal tool (carefully). I'm afraid your options are to glue another one on or opt for a clamp on guide. This is not a highly stressed part so JB weld just may work fine.
Nova Cycle Supply has most all braze-ons.
https://www.cycle-frames.com/bicycle-...GUIDES-c-1029/
Good luck
Good luck
Old fart
Liked 3,482 Times
Yes, they're readily available:
![](https://www.cycle-frames.com/bicycle-frame-tubing/images/P/CIN_303_NEW-06.jpg)
https://www.cycle-frames.com/bicycle-...E-2-LOOPS.html
A fuel/oxygen torch would be best for this job. You will likely want to repaint afterward.
that's the route i would go. i would buy a $3 cable guide/clip and wait for some other reason to get your frame fixed (repaint). you could also pain the clip red...
incazzare.
JB weld the old one back on.
I'm half serious, in that I would probably try this, but I would expect it to not work.
1964 JRJ (Bob Jackson), 1973 Wes Mason, 1974 Raleigh Gran Sport, 1986 Schwinn High Sierra, 2000ish Colian (Colin Laing), 2011 Dick Chafe, 2013 Velo Orange Pass Hunter
None of you think I could use one of those Micro Torches to just heat the base of the old guide and bust it loose without scarring the paint? Then if i could do that could I clamp the new guide into place and just heat the base of the new clip enough to run a little silver solder or brass under it to get it to stick also without scarring the paint, or do you think the action of heating the clip will heat the tube too much damaging the paint???
Half way there
You would have to heat the frame tube to over 1000 degrees F to get the filler metal to flow into the joint. This heat will flow outwards through the tubing damaging the paint. You could get some scrap painted metal and try it to get a sense of what happens. If you could engineer a way to capture this waste heat (say with a liquid nitrogen jacket), you just may pull it off. But then you would have waste much time and materials to verify that it would work.
You are looking at a temp fix now (which may actually last for a while) until you decide that you need a new paint job. You could have just the top tube painted - or maybe find someone who could blend in a touch-up for the area that you mess up while brazing.
As stated above, remove the broken guide with a fileor Dremel then clean the are really good with Acetone. Replace the new guide with JB Weld and let it cure for at least 24 hours, and it will be fine. I've sealed diesel engine blocks with this stuff, it will hold a cable guide.
Half way there
Good luck.
And if you have a chance - please post some pics of the result.
-G
-G
