View Poll Results: Which flashing setting do you use on your rear blinkey?
All flashing at the same time
![](images/polls/bar2-l.gif)
![](images/polls/bar2.gif)
![](images/polls/bar2-r.gif)
![](clear.gif)
36
46.15%
Each LED flashes in turn
![](images/polls/bar3-l.gif)
![](images/polls/bar3.gif)
![](images/polls/bar3-r.gif)
![](clear.gif)
20
25.64%
Steady light
![](images/polls/bar4-l.gif)
![](images/polls/bar4.gif)
![](images/polls/bar4-r.gif)
![](clear.gif)
21
26.92%
Dont use one
![](images/polls/bar5-l.gif)
![](images/polls/bar5.gif)
![](images/polls/bar5-r.gif)
![](clear.gif)
1
1.28%
Voters: 78. You may not vote on this poll
What flash setting do you use on your rear blinkey?
Hot in China
Bikes: Giant Lava
I have all four LEDs blink at the same time. I direct it just towards the cars, instead of straight back, and aim the center at about driver's eye height for about 30 m away.
What do you do?
z
What do you do?
z
Thunder Whisperer
Bikes: '06 Kona Smoke
Liked 6 Times
Currently only have two rear lights. The rack mounted one lacks any kind of strobe mode and the seat post one I run on the only strobe mode that it has.
Community guidelines
Bikes: Fuji Cross Comp, BMC SR02, Surly Krampas
On the bike:
- PBSF on strobe
- German steady read on rack
- Strobe
- Planet Bike Blinky on the little swivel dealy that keeps it level, on "blink"
PBSF Turbos on all bikes running in flash mode whenever on the road. Add a PBSF Turbo in steady mode if it is dark out.
What, me worry?
Bikes: Corratec / Jamis
Triple-led Dutch dynamo-driven light on rack which is always on always accompanied by 3 -or -9 led flashing lights either on seat-post or on rack bag (whenever installed).
I am a caffine girl
Bikes: 2012 Stumpjumper FSR Comp...2010 Scott CR1 CF...2007 Novara FS Float2.0...2009 Specialized Hardrock Disc...2009 Schwinn Le Tour GSr
3 Magicshine tail light. One pointed straight back, the other two are about 30 degree angled outward and set on blink mode.
German B&M 4D toplight.. it has no blinking mode,
just a very big red rack light with 180 degree visibility.
running off the hub dynamo, or if switched on, the battery.
senso plus .. senso mode is detecting motion and light.
the regular, (non plus, dynamo), battery version in daylight will
be off, but if you ride thru a tunnel, the flashing mode kicks in ..
then it's a half second interval..
turns off again in the daylight or in 4 minutes if you park your bike
and turn the room light off.
Bikes: Yes
Liked 4,107 Times
Normally, I use two rear lights, one flashing and one steady. If I only have one for some reason, I use it on flashing mode if there's enough light that my body might be visible -- otherwise I use it on steady.
I prefer a flashing mode that always has at least one LED illuminated.
My Bikes
My Bikes
Living the Dream
Bikes: 2015 AWOL Frameset with custom drivetrain, 20?? Windsor Tourist, 2010 Specialized Secteur
PBSF in steady, Radbot on default, Tate's BAL on steady, Blackburn Flea attached to a clip on my jacket on flash.
Getting a Hotshot this week. I'll experiment with it a little, but it will be on steady or slow flash.
During the day in traffic I'll put the radbot on psycho flash.
Bikes: Custom 531ST touring, Bilenky Viewpoint, Bianchi Milano, vintage Condor racer
Radbot 500 on the slow flash mode -- I want to be seen, not to be distracting. If riding with other bikes, I'll put it on steady.
I have a cheap (nevertheless bright) Zefal taillight. It has four settings -- off, steady, slow/steady flash, staccato/frenetic flash.
I go frenetic, every time; it's more bizarre, therefore more likely to catch attention.
Bikes: 2020 Masi Giramondo 700c; 2013 Lynskey Peloton; 1992 Giant Rincon; 1989 Dawes needs parts; 1985 Trek 660; 1985 Fuji Club; 1984 Schwinn Voyager; 1984 Miyata 612; 1977 Raleigh Competition GS
Liked 257 Times
My main light, a Blackburn Mars 4, I always turn on to steady. My bar end Soma Road Flares and my Cateye LD600 on the helmet are always flashing; the two different lights can't flash the same because they each have their own built in timing.
cowboy, steel horse, etc
Bikes: everywhere
Liked 8,012 Times
The PBSF flash routine isn't in the poll.
![Frown](images/smilies/frown.gif)
Thunder Whisperer
Liked 6 Times
On a side note, if that is the same as yours, did you get the combo pack like I did? And if so, how is your front light holding up? Mine changes modes or refuses to work period
Back on topic, I"m planning on getting another rear light- just as soon as I shore up the head light department
![Thumbs Up](images/smilies/thumb.gif)
