Dr. says I need a "gooch/ "Taint" friendly seat
Quoted: 722 Post(s)
Liked 353 Times
I am finding that numbness is becming more of a problem since using the trainer. I wanted to buy a new seat and found this ugly boy. Anyone here use one? They seem to be more for the tri scene but roadies use as well. If not this brand what "taint" friendly seats have you used and like.
https://www.ismseat.com/saddles/adamo-racing-ii
Should Be More Popular
Quoted: 22771 Post(s)
Liked 9,169 Times
That said, my solution was a wider saddle that actually fit my sitbones, and then tilted slightly nose-down. It's amazing how a few millimeters of nosedown tilt can change your comfort level.
Try standing more? Especially on a trainer--I go numb if i sit too long as well.
Specialized toupe works well for me. They have other saddles with central cutouts in different shapes, widths and padding.
Trainer riding discourages one from standing which makes the problem worse.
Bikes: raleigh carbon competition, trek 6500 hardtail
not a gimmick, awesome saddle. have one on the road bike will never ride anything else
Bikes: 2011 Serotta Ottrott, Serotta TI Road Bike, Serotta TI MTB,Ritchey Breakaway Ti Cross, Trek Rumblefish Pro, Cannondale Tandem
+1 to a proper fitting before spending money on a saddle that might not fix the problem.
Your sit bones may too wide or narrow for your seat or the one you're looking at, the seat could be positioned forward or aft, your stem could be long or short, etc etc. There are a number of reasons the pressure could be distributed incorrectly causing the numbness.
I rode 15,000 miles on a Specialize Toupe over a couple of years and didn't have any numbness or discomfort. I bought a Serotta frame in August and had a dynamic fit so I could make sure the size was correct (no +10 70mm stem or seat all the way fore/aft etc on a custom bike for me).
My fitter measured my sit bones and flexibility and said I could/should try the Fizik Aliante as the width was perfect. He gave me a test saddle and I was worried there would be numbness as the Toupe had a cutout and the Aliante doesn't. He also warned it might take a while for me to get used to a new seat. The only difference I've noticed is never getting any soft tissue pinches from the edge of the cutout (ouch!) since there isn't one.
I've ridden 3000 plus miles and 4-5 centuries on the new saddle and no issues. I replaced the saddles on my other bikes with the same one to be consistent. My riding style is "sit and spin" I very seldom stand, even on hills.
I will confess to being in a 15-yr marriage where I was getting my butt chewed out pretty often so my rear may just have lost all sensation completely
Good luck with finding a solution!
Zoom zoom zoom zoom bonk
Bikes: Giant Defy, Trek 1.7c, BMC GF02, Fuji Tahoe, Scott Sub 35, Kona Rove, Trek Verve+2
Quoted: 558 Post(s)
Liked 735 Times
Did the doc really say "gooch / Taint" ?
Quoted: 1067 Post(s)
Liked 259 Times
I don't mind the ISM saddles for a TT bike but prefer SMP for a road bike. These have a very large central cut out. Only thing I don't like about them is that they are quite curved so you tend to be limited to one position and can't really move forward or back.
Slower Member
Bikes: 2009 Giant Defy 1
+1 on getting a good fit too.
toupe. or any firm/ less padding seat should help, excessive padding on seats is bad for taints.
yada yada
Bikes: Felt F5, Surly CrossCheck
Quoted: 722 Post(s)
Liked 353 Times
Have you seen the latest in top notch cycling research technology?
This is disturbing...but I hope helpful.
https://forum.slowtwitch.com/cgi-bin/...i?post=3042683
Think about riding outdoors, if properly dressed it is a warm and fun activity.
If you insist on riding indoors, think about the Kirk Kinetic Rock n Roll. This has the fluid resistance unit mounted on rubber bushings allowing movement to occur and creating a much better indoor ride. When I ride indoors, which is rare, I use the Kirk and find it has increased my riding time indoors 100% and with no numbness.
Curmudgeon
Bikes: 64cm TREK 2.3, 68.5 cm Schwinn, and 22.5 inch Trek 4500
If, as you say, the problem comes with the trainer, then you have identified the problem. It is not the seat but the trainer. The problem with the trainer is that it is rigid and immobile. This creates a situation not found when on the road, steady, unrelieved pressure with resultant numbness. As one respondent said, get out of the saddle, every 5 minutes or so and do a stretch of riding while standing.
I don't think I'd buy a new trainer, but standing periodically to remove the pressure point is important because of the trainer's rigidity. Also, if you're dead set on spending cash, buy some winter clothing and go outside.
Bikes: 12 Bianchi Oltre VDCM,11 Bianchi Cavaria, 13 Bianchi Cavaria,12 Bianchi infinito, couple vintage Bianchi's and a 1980 alan super record
The rock and roll won't help. I just sold one at a huge loss because with any type of interval training it beats the heck out of that area from bouncing, but I do tend to agree that a trainer magnifies the problem.
If you are bouncing that much you may need to work on your pedal stroke. The movement of the Kirk helped me a lot with numbness. Sorry it did not help you.
