Ultra Torque Crank In Swiss Thread Frame?
Bikes: 61 Bianchi Specialissima 71 Peugeot G50 7? P'geot PX10 74 Raleigh GranSport 75 P'geot UO8 78? Raleigh Team Pro 82 P'geot PSV 86 P'geot PX 91 Bridgestone MB0 92 B'stone XO1 97 Rans VRex 92 Cannondale R1000 94 B'stone MB5 97 Vitus 997
Liked 49 Times
Hey, I did search, found no glimmer of promise, and am wondering if you will extinguish my hopes entirely.
If you have a frame with Swiss threading in the BB, is there any way to use a Campagnolo Ultra Torque crank?
Bikes: Daccordi 50 Anni no. 160 + 600 Tricolour, Mercian Strada Speciale 531c + SRAM Force/Rotor, Airnimal Chameleon + SRAM Force/Hope, Cannondale M600 Beast of the East, Own custom build 29er Joker 853 Ace of Hubs, 1953 curly Hetchins Experto Crede
Received wisdom - Velospace had some clues - Get the BB re-threaded to English. Then you can use an English Ultra Torque BB. LBS or a framebuilder will have the right tools. As an engineer I can rationalise this to be workable (English 1.37" (34.8mm) x 24tpi is not too far different from Swiss 35mm x 1mm (25.4tpi), thanks Sheldon) because not much metal will get removed, BUT I have not done this myself, so maybe someone else will respond to confirm. Some alternatives (sorry for mentioning as I guess you may already know) are Phil Wood BB with Swiss cups OR Velo Orange threadless BB to use with a classic square taper chainset.
Liked 1,099 Times
Received wisdom - Velospace had some clues - Get the BB re-threaded to English. Then you can use an English Ultra Torque BB.....I can rationalise this to be workable (English 1.37" (34.8mm) x 24tpi is not too far different from Swiss 35mm x 1mm (25.4tpi)... because not much metal will get removed...
The more common way to salvage a damaged or unusual bottom bracket shell is to ream and retap it to Italian (36 mmx24tpi, right hand threads on both sides).
If you look at the dimensions, Swiss cups are LARGER in diameter than English cups so even if you could make the thread pitch the same, the English cups will be a very loose fit. I don't think it will work.
Liked 49 Times
Ah, veeery interesting. So there is hope! Thank you all.
Swiss thread typically is 35 by 1 french metric, but right cup is LH thread.
[ref. Sutherlands]
Stick with square taper cranks and Phil has Swiss mounting rings to fit their BB..
[ref. Sutherlands]
Down to the shop, get out the frame taps , then Take it out to 36mm, Italian ,
as then you might have a better thread condition when you are done,
26tpi is finer than 1 per mm + given BSC, 1.370" is 34.8mm.. ,so smaller..
or just get a frameset that is Italian or BSC thread .. sell the collectable as is..
