new to brifters
Liked 3,612 Times
new to brifters
long time rider but new to brifters. only used them on a couple short test rides. fnally got a new bike (3yrs old) w/ brifters (Tiagra). I'll be done swapping accesories and ready for test rides and adjustments to my fit this weekend. anyone remember their first rides with brifters? any tips or suggestions about techniques?
LET'S ROLL
The 1st couple of times I had a hard time remembering
if it was the big lever or the small lever to upshift/downshift.
Then I taught myself - small lever/smaller sprocket; big lever/bigger sprocket.
Works on both the left and right side
One day: www.youtube.com/watch?v=20X43026ukY&list=UUHyRS8bRu6zPoymgKaIoDLA&index=1
Starting over
Bikes: 1990 Trek 1500; 2006 Gary Fisher Marlin; 2011 Cannondale Synapse Alloy 105; 2012 Catrike Trail
That's the key, right there. For Shimano, anyway. The only other thing I learned later was that, at least on 105 stuff, you can trim the front derailleur with the left hand lever to avoid chain rub.
I was totally confused the first time I rode my STI bike. The way I learned is I pictured the rings and the cassette as they are on the bike and you have to push the chain up the hill from small to big. So when you use the left control you are pushing the chain onto the larger rings. In the back the right hand pushes the chain up the cassette. The smaller handle then lets it drop down the hill. As soon as I had that mental picture it was second nature shifting.
When I got a bike with Sora shifting with the thumb button the same mental picture worked.
As mentioned above get used to how the trim feature works also. If you google your shifter type with the word trim or trimming there are a lot of good write ups on how it should work and be adjusted.
Bikes: 2014 Felt z5, 2010 Trek 4300 Disc, 2008 Trek T1000 Tandem
Ever go back and forth from friction down tube to brifters and find yourself mashing on a brake lever and getting no shift?
Liked 644 Times
I remember my first ride on a brifter equipped bike. I told another rider that my rear derailleur is only going to last half as long because I'm shifting twice as much.
Liked 3,612 Times
haha, yikes. glad I asked. interesting stuff.
up shifting from lower gears to higher ones ,
particularly with the front derailleur chainring up shift
goes so much better
when you are spinning the pedals and not mashing heavy on them.
I remember my first brifters.... along with the clipless pedals. I only had one tipover. It will take a while for you to remember the shifting. Sometimes I have to think as I mostly use the middle ring on my front derailleur. Drop bars and brifters FTW!
Bianchi Goddess
Liked 3,110 Times
My first ride whould have been a test ride on someones elses bike (sniff sniff) since I could not afford them back then. Actually I don't think they had even come up with the brifter term then it was still Ergo and STI.
Just remember two things well three actually.
Don't get in the habit of shifting to an easier gear just because you can, sometimes your better off getting out od the saddle and grunting a bit.
It is OK to take your hands off the brifters to either signal a turn or a brief wave to another cyclist.
YES! Actually between DT and barends (both index and friction) Thumb, Rapidfire and evena *gasp* Stem Shifter I always seem to reaching the wrong way to shift.
Sugar "Kane" Kowalczyk
Liked 1,452 Times
And then you get SRAM (after Shimano)...
So, fill us in on SRAM. Even better?
Some people are like a Slinky ... not really good for anything, but you still can't help but smile when you shove them down the stairs.
Bike ≠ Car ≠ Ped.
Anyway, whenever I tell someone about shifting with brifters (Shimano, at least), I tell them what 1nterceptor said -- big lever=big gear, small lever=small gear. They get the hang of it pretty quickly. With Sram, it's big swing=big gear, small tap=small gear; Campy is big paddle=big gear, small lever=small gear.
Bike ≠ Car ≠ Ped.
Eh, sorta, except that you need to remember if you're at one end of the cassette. Since the same lever is used for shifting both directions, you might upshift instead of having your 11th downshift blocked.
I have Shimano (Tiagra and DA) on my bikes, but I really like how Campy works. One function per lever.
cowboy, steel horse, etc
Bikes: everywhere
Liked 8,020 Times
I'm always trying to shift invisible thumbshifters or gripshifts on my singlespeed MTB, though
Bikes: Vitus 979, KHS Montana Comp
No problems at switching between brifters on the new road bike, XTRs on the 1993 beater mountain bike/utility bike, and DT shifters on the 1983 Vitus 979.
Bikes: 2013 Haro FL Comp 29er MTB.
Liked 45 Times
SRAM double tap is different in that if you simply lightly tap the little lever it drops into the smaller cassette ring. Push the lever and it pushes it up the ring. On the other side a tap drops into the small ring a push moves it to the large ring. SRAM only trims in the small ring. Jump back on Shimano and you might find yourself trying to push the little lever to shift up and that doesn't work.
Some Campy ergo and Shimano Sora shifters use a thumb tab to drop into a smaller gear and the lever to push up to a larger sprocket. Easier to remember I think. The best part about Brifters in my opinion is it is easier to shift while on a hill and the ability to shift and not have to remove a hand from the bar.
Bike ≠ Car ≠ Ped.
I think that Red (pre-2012) trims on the big ring while Force and lower trim the small, but yeah, the point is that Sram only has trim on one ring and not the other. It's another limitation of the single lever concept. The new Red, though, has a FD that pivots around a vertical axis to avoid chain rub -- which is a pretty slick way around trim, I'd say.
Liked 45 Times
I have never learned to love campy but then I haven't tried their new quick shifters either.
Bikes: Baum Romano, Brompton S2, Homemade Bamboo!
Liked 204 Times
This is the only problem I had with the change from Shimano to SRAM. Now that I'm used to it, SRAM is great - but I think the Shimano is simpler and I can swap back very easily.
Bike ≠ Car ≠ Ped.
Between my SRAM and Dura Ace I like the SRAM for its mechanical like shift and the Dura Ace for smoothness. The Dura Ace shifts and you never "feel" it except by pedal effort. The SRAM clicks into position.
To be fair, the only Campy I've spent any time with was Chorus 11sp on a demo bike for a week. One trick that it had was that it could dump half the cassette with one push of the thumb lever, which was nice when I started going downhill. It also lets the paddle levers swing towards the bars like Sram does for easy shifting from the drops. Plus, the front trim has several stops, so it's almost like adjusting a friction shifter.
I think that, if I went away from Shimano, I'd want to go Campy. I'd only be concerned about compatibility (really not much of an issue for me since I haven't swapped parts among my bikes) and how the thumb lever doesn't allow me to just plop my hand on the brifter hoods any ol' way I want.
